I would like to replace the plastic wheels with metal ones, also size.
This is a bit tricky. These cars had roughly 33" size wheels on the tread under them from the factory. But this was due to the deep flanges. They should have 36" wheels, but to install these, you’ll need to either trim or bend the brake shoes enough to clear them. I used Jaybee back in the day. They’re back after a lengthy hiatus, so may be available again. Other 36" wheels should work and others with experience may be able to suggest which ones.
I would dump the trucks and replace them with better quality ones.
I agree. I replace with good quality trucks with screw located at the correct pivot point .
I also add weight for the proper weight and install long shank Kadee couplers on the car bodies .
Hi David,
Good answers from the crew.
Just something to consider regarding the “skates” for your cars: How much did you want to invest in your cars? I only bring this up since, at one time or another, most of us are on a hobby budget.
If you want to hop up your cars (closer coupling, better detailed-more accurate trucks, body mounting couplers) then go for truck replacements. You will have to do a little work to adapt replacment trucks.
However, if you’re on a budget, or just want your units to roll decently, you can save a few dollars by purchasing Proto 36" wheel sets and install them in the current trucks. MB Klein has quite a number in stock:
http://www.modeltrainstuff.com/Walthers-Proto-HO-920-2302-36-Wheelsets-p/920-2302.htm
I still have a small fleet of Rivarossi Budds that I bought back in the 80s. Although I metalized them I decided not to invest too much into them once the Walthers units hit the market back in the early 2000’s.
The Proto 2000 36" wheel sets fit in the Rivorassi trucks’ journals with no issues (other than either bending the brake clasps upwards. I just remove them). You can see the metal Proto wheels sets in the stock Riv trucks on my units below):
With the metal wheel sets and added weight, my Rivs actually track well when mixed in with my Walthers units.
I acknowledge that the stock trucks are a bit crude in appearance by today’s standards but, again, this is just a “budgetary option”. Once weathered, they don’t look too bad at all.
Yes I am on a budget and being so I am not going to replace the trucks at this time. The suggesting of the wheels from Walthers and MTS seem to be the perfect solution.
thanks for the tips,
Dave
Dave,
Glad it was helpful.
If you haven’t done so, consider adding weight in addition to the metal wheel sets. You’ll notice a difference in how nicely the cars roll even with stock trucks!
You can fill the car floor pockets with bird shot or BB pellets until they’re flush with the floor. Smother them with Elmer’s glue so that they will stay in place. Then place your interior on top of the floor.
Keep a food scale handy. Eight to ten ounces is a decent weight range for 85ft HO passenger cars. A friend of mine liked to weigh his cars down like bricks! He eventually realized that his locomotives were going to wind up with hot hernias!
If you prefer, use flat steel bars or plates that stretch from bulkhead-end to bulk head-end. Avoid using flat weights that stretch just between the trucks or bolsters as your floor can sag in the long term.
My recollection is that the AHM/Rivarossi cars were designed with their own wheels in mind (which I also recall were smaller than 33" - closer to 30") and that replacing them with accurate 36" wheelsets involved more than just shaving away the cast-on brake shoes, because the car height now also became “wrong.”
Ditto for IHC cars. IHC at least offers metal versions of their plastic wheels, meaning they are 31" and thus inaccurate but at least are drop in replacements needing no other work.
http://www.ihc-hobby.com/category/33157122
They offer similar drop in metal replacements for AHM/Rivarossi cars
http://www.ihc-hobby.com/category/33157122?page_570515168=1
This means the wheel size would be wrong but no other work would be needed, which might be important to some.
Dave Nelson
Yes, the AHM trucks used wheels somewhere around 33". I don’t have any, so I can’t check. As I recall, they also had slightly short axles, so some replacements might bind in those trucks. I believe Intermountain wheelsets come in a variety of axle lengths, so they may be a good choice if you can find the right ones. If you’re deternmined to reuse the original AHM trucks, you might check the height of the car above the rails to see whether 33" or 36" replacements would work best.
As mentioned, the best solution would be to install better trucks.
I do remember reading years back (early 2000’s) that the AHM-IHC-Riv cars used 31" NEM wheel sets (which were infamously labeled as “pizza cutters”).
Below is a Walthers Budd unit (left) and a Rivarossi Budd unit (right). The wheel sets on the Riv were replaced with Proto 2000 wheel sets. No problema as far as height.
However, one oddball annoyance posed by the Riv units is that the truck bolster is almost 1/16" tall, making the body sit a bit high, as seen here:
Simple solution is to shave down the bolster and install a flat washer that’s 1/32" thick (plastic or metal) to prevent the body from waddling like a penguin. The final height should be something like this:
I had trouble fitting standard length axles in my Rivarossi passenger cars and ended up getting Reboxx wheels with 1.020" axles. The axle length in Rivarossi cars is apparently all over the place, so it would be best to test fit an axle in each of your cars to make sure they’ll work first.
I used Kadee 36" wheels on my Rivarossi cars, which required shaving the brake shoes on the trucks just a bit: A new #11 blade easily took car of that.
I added underbody details, some basic interiors (seats and partitions), and about 8oz. of weight:
Found my box of Jay-Bee leftovers. No axles, as they went on the cars I have, so can’t help with part #s on those.
However, Jay-Bee did make coupler mounting pads sized to deal with the small changes in coupler mount heights caused by applying the correct size wheels. I have the following for Kadee coupler mounting:
#111 Rivarossi 1920 except Bag/RPO
#112 Rivarossi 1930
#117 AHM corrugated
There is enough to do 3 cars in each package. MSRP was $2.75, circa 1990 IIRC. These allowed body mounting the couplers at the correct height once all else was squared away. Could be fabbed from small bits of plastic sheeting, but the J-B items make it easy and quick.
David,
here’s a shot where you can see the metal wheels more clearly. This is a Rivarossi unit that I upgraded back in 2008 ( I think).
After cutting off the skirts, I paint stripped and metalized it. Afterwards, added the MV lenses, added BB pellets for weight, installed metal Proto wheel sets, and painted the interior. I remember that on a “push test” it rolled smoothly.
Since the Rivs are basically generic Budds, I use them as “fillers” for my SCL and ACL 1960’s era streamliners.
I replaced the 31" wheels on three sets of IHC cars with KD 33" wheels, using a Truck Tuner to optimise the journals. They coast very nicely.
Hal
Is there any passenger truck that can replace the IHC/Rivarossi passenger trucks? I put in the 36" Kadee wheels, reamed out both sides (one side is tough to get the reamer in due to the plastic that holds the McHenry coupler). Still rolls rough. Took the x-acto knife to train the bake shoes. Broke two, had to take the other to off (geez I can’t believe I did that).
If I’m going to get them to roll with ease, I think I should put new trucks on them. Also, I’ll use the Kadee conversion kit for couplers.
Thanks to everyone who replies!
Neal
what to use would depend on how pickey you are about staying close to proto. i used walthers pullman type 2411 pt#933-1086 , back in the days when i had money(before retiring) walthers had a kick but specal sale on them and i ordered 25 sets (only got 22 all they had in stock) used them on all my Riv/AHM/Ihc cars.
Hi J.C.,
I found the new Walthers match for them. Will try a pair and see how it goes…
Thanks!
Neal
should have told you in other post these require a new mounting pad as mounting hole is not centered,like original truck.
I picked up four IHC heavyweight cars recently, and replaced the wheels with Intermountain 33" ones. However, the trucks were so fragile that two snapped while just removing the wheels. I experimented some more with the broken trucks and easily cracked it elsewhere. How people can shoehorn in 36" metal wheels is beyond me, as they bind and any attempt to modify the trucks will lead to irrepairable fractures.
Now, I need to find a pair of replacement trucks. IHC sells them for $8 EACH truck! I only paid $9 for the car itself!
I wish there was an easy heavyweight truck swap for these IHC/AHM cars!
