I just installed a TCS CN decoder in an Atlas GP35. The test run resulted in the rear light comming on and the loco running full open forward with no control. The loco does not care what number is assigned in my Zephyr - even 00. It will not read CVs on the program track and if you try to write to it anyway, it inches forward everytime I hit the write CV button.
I have check the wiring at least four times and have done continuity checks on all wires. I have checked and found no shorts. Both front and rear boards make good contact with the frame halves. I have tried to factory reset it but that does not work anyway because the programming track will not read the decoder.
Any help will be appreciated as this is my first full decoder install.
This is quite interesting. I have the exact same problem with a tcs decoder given to me that I decided to install (it was used, from a club member) but I did not think the burn in the insulation was a problem. It did the exact same thing that you described. I emailed him and he told me that it was a soldering iron burn and he had given it to me along with some junk locomotive parts of mine. It was in no way his fault or being cheap. I should have known better than to install that decoder under such circumstances. Does yours have a soldering burn? Either way, great news! If it is under one year old, TCS will give you a replacement for FREE. And if that one breaks or doesn’t work, you can get a free replacement for that one too, and so on… You go to here: https://tcsdcc.com/warranty, watch the video, follow the instructions, and I believe that is all. Good luck!
The runaway issue sometimes happens on certain decoders. The remedy is to turn off dual-mode in CV29 and operate your decoder in DCC-mode only. This can be achieved by reading the value for CV29 with your DCC system and subtracting 4 from it.
If you are having trouble reading your CVs, the default value for CV29 is 6. Change it to 2 (6-4=2) and your problem should go away. Increasing CV29 by one will also reverse the direction of your locomotive. This is a convenient way to correct that if it initially runs backwards.
Folks,
What tstage said is correct. Runaways are possible with DCC decoders unders certain circumstances; usually a short or a rapido series of shorts and/or power interruptions. The solution is to program every decoder to be DCC-only by turning off DC Analog mode. This is controlled by CV29, the configuration variable that controls a group of things. One of those options is DC Analog Mode.
For most applications: for a 2-digit loco (from 01 to 127), change CV29 to a value of 02. For a 4-digit loco (from 128 to 9999), change CV29 to a value of 34.
The reason why the decoders run away under analog mode is that DCC is a square wave digital signal. Think of a sine wave in AC power, changing from + to - (at 60 Hz in the US), but instead of a constantly changing voltage (from -X to +X and back again), it does it abruptly. The resulting wave form looks square as the voltage shifts in mere milliseconds from + to - and back. The length of time the square wave lasts before switching back again indicates if it is a “0” or a “1” bit. This is how DCC talks to the decoders. With DCC, the power is the signal, which is one of the reasons why it is superior to analog systems.
Well, when you have a short circuit, voltage drops to zero. Remember that voltage is the difference in energy between two conductors, and when both conductors are touching (shorting), the difference is zero because they are now both the same.
When the short is removed, the DCC square wave immediately starts up again, but the first initial burst of that very square wave before it can start switching back and forth is, technically, DC. Some decoders are so sensitive that they can pick up that initial burst of the square wave and think they are seeing DC analog voltage.
If DC analog mode is turned on, the decoders are programmed to take whatever voltage is in the rail and put it strai
Paul3, I cannot access any CV. I tried 29, 8. 1, all of them. How does the loco see anything when I can enter any loco number and it does the same thing? Is it see ing sqaure wave rise for any DCC loco? I think the decoder has a problem I will not be able to solve.
That leads me to believe either the decoder is fried or the motor tabs are touching the frame (or both, if the motor tabs are contacting the motor terminals on the decoder AND the frame, it’s putting track voltage back into the output of the decoder which pretty much fries any of them.
why should the loco take off at full speed in DC mode if DCC is alternating and has an average DC voltage close to zero?
is it possible that one motor terminal is connected to a rail (or frame as Randy siggested) and the other to decoder ground; wouldn’t the motor see a DC voltage ~half the time?
could the decoder be fried such that the two h-bridge paths providing rectified DC are on?
I have checked the continuity between the and gray and orange motor wires at the decoder board and the two motor halves and they are all open with no shorts.
Best bet would be to try another decoder. If it works, then it was the decoder that was bad; if not, it’s something with the engine. (I’m assuming the engine ran OK on DC power before the decoder installation??)
Most definitely. It seems most of the time, the drive transistors fail shorted, same with the function drivers, which is why a blown function tends to be on all the time and you can’t shut it off. If two of the 4 H bridge transis
