why not 2"x4" benchwork
Not necessarily. Deflection is minimized primarily (but not only) by depth of the structural member. A 2x4 will resist deflection better than a 1x4. If the L-girder is comprised of a 1x4 with, say, a 1x2 or 1x3 on top, it might be equal to or better than the 2x4 because of the extra depth (I haven’t troubled to do the calculation). But I believe a 1x3 with a 1x2 or 1x3 on top will deflect more than a 2x4 (on edge, of course).
Long, thin spans of anything that’s loaded laterally and not braced! Legs are loaded longitudinally, in compression.
The ribbon of 1-by doesn’t help much in combatting side thrust, and makes the space under the benchwork useless for roll-out storage units. I personally prefer angled braces - less material, less wasted space and you can’t distort a triangle unless the fasteners fail.
Unless there’s some aesthetic objection to wall fastenings, narrow shelves are a lot easier to deal with if they’re on shelf brackets. Mine are, even though they support multiple levels of track.
As a firm believer in the KISS principle, I cringe every time I hear that! One reason I like steel studs is that the screwing flanges are either built in or can be created in seconds with tin snips and vice grips.
[quote]
Don’t forget, the table top itself provides great rigidity to the structure when it is finally&nbs
I have to disagree again. A beam’s effectiveness is based on two things: strength and deflection.
Strength is a function of a beam’s section modulus. The higher the S value, the lower the stress in the beam. So a beam with a higher value of S is stronger and can carry more weight.
Deflection is a function of a beam’s moment of inertia. The higher the value of I, the lower the deflection.
Here’s a comparison between An L-girder ripped from a 1x4, a 2x4 set on edge, and a 2x4 laid flat:
I S
L-Girder 1.42 .95
2x4 Vertical 5.36 1.42
2x4 Flat
[quote user=“mononguy63”]
I S
L-Girder 1.42 .95
2x4 Flat 0.99&
[quote user=“Doughless”]
I S
L-Girder 1.42 .95
2x4 Flat
Rob,
Having built layouts since the mid-'50s, I have used a number of different benchwork construction methods. My large Chicago basement Lionel layout (8x20) was built with “begged, borrowed, & late night acquisitions” as there was little money for buying wood. I used 2x4s for legs.
My second larger HO layout (16x8), built in a Joliet Illinois basement in the early '70s used 2x4 legs & 1x4/6 for bracing. That layout was a “rock”, and portions of the benchwork survived two moves and served as a workbench frame thru 2007!
My last two HO layouts (11x15) have been built with 2x2 legs and 1x2-4 bracing. These layouts were built in a spare climate controlled room here south Texas, and have worked out beautifully.
Ok, that’s some of my layout history, and let me give some of the reasons for doing what I did. I used 2x4s on basement layouts because they were available, and I didn’t have the “fancy” tools that I have now. By that I mean cordless drills for deck screw fasteners, various powered saws, clamps, and the like. The base was very strong and durable and seemed to be OK for a basement layout.
Here in a finished room, I considered 2x4s to be too heavy and gross overkill for the layout base. I used 2x2s, and have 52 of them for legs under my 11x15 layout which pretty much fills the room - except for the center. Note that straight 2x2s have to be hunted at the local lumber yards, but they are easier to handle, lighter, and if properly braced, they are very strong. I weigh 225 and can go anywhere on the layout without fear of breaking anything (including me).
Hey, use what works - or what you can get. Just make it sturdy and solid and ENJOY !!!
Mobilman44
It’s sort of like using a sledgehammer when a tack hammer would do. I do however prefer 2X4’s with a lap joint that will be flush with the L-girder horizontal members. This also makes for easy corner angle brace attachment. I guess I just didn’t feel comfortable with 2X2, which would mean sawing a 2X4 lengthwise anyways as local lumberyards here don’t carry 2X2’s. My benchwork will more than support my 180 pound weight.
Verrrry interesting!
Would someone include a photo of their L girder and frame…and maybe why the wiring etc. is simpler with this lighter lumber. I am about to get to building another layout and, sorry, haven’t done the research yet. And I am a iffy carpenter.
I do not subscribe or have access to train mags for ideas, but I will be searching for online info soon.
Thanks
By “legs,” I envision the vertical pieces that hold the layout off the floor. Are you talking about the same things? Fifty-two legs for an 11x15? That’s a forest! [:D] It would certainly hold the layout up, though. My layout is 9x17 and has two sides supported directly off of the wall and only seven other legs.
When the time came to assemble my mountain division, I needed a table eight feet wide by 36 feet long. To support it I fashioned two “T” girders 36 feet long using two 1X4’s and supported them with five 2X4 legs seven feet apart. On top of this structure I laid 1X4 joists and screwed them to the T girder flanges on 24" centers and laid half inch plywood on top of that. My specifications would be considered underbuilt by most model railroaders but it supports my 200 lbs just fine. 2x4’s and 2x3’s in the form of reject studs can be had in the trash pile and/or dumpster at any building site so the price is right. Just make sure to go in daylight and ask the boss carpenter for permission to raid his trash pile.
A useful technique for fabricating L girders I have used was to rip them from a straight 2 x 4. This left an L member 1.5" wide by 3.5" high with a piece of .75 x 2 left over. I could then use the left over piece for risers or what have you. I didn’t have to glue and screw together any members to make the L members. I used these for both legs and beams to construct the benchwork frame. Using L girders definitely makes the assembly of other benchwork members easier and results in a very stiff piece of benchwork.
One drawback of this can be that the benchwork is rather deep and can create a situation of “banged heads” if it is rather low. In my younger days I could put up with that but as I get older and less flexible it is more of a problem. Still, if I had to do it over I would give careful consideration to the same technique.
The original premise behind L girder construction was that it did not require a great deal of precision and/or carpentry skill to assemble. Remember, this was before the general availability of the relatively inexpensive power tools we have today. No one had a power drill, battery operated screwdrivers hadn’t been invented yet, you were lucky if you had a scroll saw, and a lot of folks were trying to cut plywood with a keyhole saw.
L girder construction only had one purpose, and that was to support a model railroad. I think I read someplace that it was just about useless for any other purpose, but that it was excellent for what it was supposed to do. It was also economical in its use of wood.
Someone mentioned that they cringe when they hear about a person ripping a sheet of plywood into 3 inch pieces to assemble a table. The purpose of doing this is because a 1 X 3 made from a multi-ply piece of wood is less expensive than an equivalent dimensional 1 X 3, is straighter, is a true size (not 3/4 X 1-1/2), and is more dimensionally stable. The guy I railroad with has a 32 X 70 room with a room addition about 32 X 32. The railroad has multiple levels. All of his benchwork is open grid made from 3 inch strips of plywood. I can assure you that it is plenty strong.
The use of a 2 X 4 in model railroad table construction is overkill, unless someone is giving you the wood. Even then I think I would think twice about using it. But the bottom line is that one can use whatever they want, even 4 X 4 and 2 X 6 if they want. I think I remember seeing where someone actually had built a railroad scene on a piece of old log. So, whatever works for you.
Exactly what I built for my first step. 6’x20’ with 2"x4"s and 3/4" plywood. Basically, a floor about 3ft over the floor. Tons of storage space below, and strudy enough to support people working on the two layouts. The layout above will use alot of OLD 2x4s gathered from various undisclosed locations and most likely half inch plywood. They may be overkill, but they’re on hand. Strong? Yeah, the “table” might as well be a granite outcropping.
I have seen a lot of 2x4 bench work and the sections I salvaged from my old railroad are in fact 2’x4’ isit over kill yes except you have the option to get up on top of the bench work and do work in hard to reach places where others who have used 1x4 don’t plus most 1x4 you buy now is warped as a pretzel so another option is to cut what ever size u want from 3/4" plywood
2"x4"… not even for legs… not even if free. I rip studs free-hand with a power saw for 2"x2" legs; takes about a minute.
Gee… why use a 2"x4" when a 4"x4" will work just as well?!? [swg]
Jim
I will not use them for a house, I will not use them for a mouse. Not on a box, not with a fox. Not in the rain, not for my trains. On the other hand, Sam-I-Am has convinced me to eat Green Eggs and Ham.
Moonguy63,
Yes, there are 52 - 2x2 legs under my 11x15 layout. They are spaced about 3 feet apart going east/west, and about 2 feet apart going north/south. The layout is NOT attached to the walls, so obviously their are also legs around the perimeter. And, as I have a 2 percent grade that runs around to a lower level to staging tracks, more legs than otherwise necessary are needed. And yes, there is room for this 65 year old, 5’10", 225 lb guy to wind himself under the layout to reach all of the underside.
I’ve posted a number of pictures in this forum under “layout update” and that will give you a better picture of what I did.
Mobilman44
I inherited a partially finished layout with 2"x4" construction. While I was working on finishing it, every time I went to drill a new hole (especially big 1"+ holes) I wondered what the original builder was thinking. Every time I went to add a control plate, indicator light, or other thing to the outside frame and had to cut through all that, I wondered what the original builder was thinking. It seemed that every time I tried to drill a hole from the top I ran into a 2"x4". I had to offset more turnout motors than normal, etc. It is amazing how much extra material that extra 1" of board puts in-the-way under the board when working on stuff. Just from that experience I swore off 2"x4"s as a construction material.
Maxman, I didn’t quote you (too long) but there are a few spots where I would differ:
Electric power drills were available at Sears in the early '50s - I know because I bought one. Not sure when hand circular saws were first sold, but it was quite a while ago.
My cringe in reference to ripping up a plywood sheet for dimension lumber referred to the amount of work involved and sawdust generated, not to the strength of the result. By the time a typical amateur sawyer finishes cutting up a sheet of plywood, I would have the equivalent steel stud benchwork erected and would be installing risers.
I remember a bit in MRR a long time ago where the cash-strapped modeler asked his friends to give him any scrap wood they found. Some of it was heavy hardwood, so hard that he had to drill starter holes for nails. (Just the use of nails dates the article - and me!) Once the layout was built and scenic cover had been applied, who could tell what had gone into the benchwork?
If someone wants super strength, they should look into Glue-Lam engineered joists…
Aside to Mark Pierce - a sun-proof garage is infinitely better than working on the Edwards flight line…
I use 2x4 and 5/8 ply. Overkill? Maybe. Heavy? Don’t know, the concrete floor shows no signs of stress. Portability? Where will I take my home layout and why? Wood quality? I pick 'em out myself and I don’t buy the crap.
I’ve had lots of layouts built with 1x4 L girder, it’s fine, they work and I’ve never had one collapse. 2x4s work just as well, and as mentioned, when it’s all said and done nobody’s going to see it anyway.
