Why so long to convert to electrical from steam heat on Passenger Trains?
Early steam connections used hoses that were adequate for the relatively low pressures found prior to superheating. As boiler pressures rose reducers were applied, keeping the inlet pressure below about 150 lb, which prevented hose burst until the later pipe connections became widespread. Boilers used on diesels and electrics were “flash” type, with steam production dependant on use more than on pressure - in fact most roads allowed some steam to leak out the end of the train so the lines didn’t freeze up. The key rating for train boilers was “pounds per hour” which was both a measurement of steam production and water use - a gallon of water produces around 8 pounds of steam. EMD B-B units were generally equipped with model 4625 units (2500 lbs/hr), with E-units often equipped with model 4740 (4000 lbs/hr). Amtrak’s SDP40Fs were equipped with a pair of 4625s each. Water capacity was a big problem since it cut into fuel capacity. F units in passenger service were often paired with the boiler only in the “B” unit, since it was difficult to provide enough water capacity in the “A”. The FP7 was a partial answer. In any case water use was greater than fuel use in the winter. Many western roads, and some eastern ones, built steam generator cars out of anything from old tenders to ex-Army troop sleepers, or set up steam generators in part of a baggage car. UP’s “City of Everywhere” often rolled into Chicago with nearly 30 cars in the late 1960s, trailing a baggage boiler car.
Except for B-units and FP7s, most units with boilers stowed water in a partitioned fuel tank under the frame. Amtrak and EMD’s decision to use above-frame tanks on SDP40Fs probably doomed them, as sloshing water on curves as the tanks emptied could quickly overwhelm the lateral stiffness of the trucks.
Perusing through Wright’s book on the Espee Daylight, ran across a notation that the first trainsets used steam ejector A/C. Later trainsets used the Waukesha engine driven A/C.
One of the 1901’s issue of The Electric Journal had an article on steam ejector cooling, stating it was good for a maximum of 50 degrees F between the “cold” side and “hot” side. Big advantage of steam ejector technology is that it did not use toxic gases that were the refrigerants available at that time.
and could rapidly change from cooling to heating and heating to cooling if required.
I should have added that my information came from a Register that was published in the seventies. By then only two roads used steam-powered air conditioning.
If you walked by a car with steam-powered air conditioning, you could get a light shower of water.
1950 Pullman car list shows the following with Steam Jet A/c:
Erie MKT Milw NYC Pullman SFe Sou StLSF UP
Pullmans were pool-service “Betterment” cars of various floor plans, along with a bunch of Tourist Sleepers. Erie’s, UP’s and Sou’s were heavyweights. Milw’s included the lightweight cars on the Olympian Hi, including Skytops. NYC had a couple of 10 sec ObsLg heavyweight cars.
John H White stated that the AT&SF and Seaboard were the only two long term users of steam ejector A/C, so the P.E.R appears to be validating White’s statement (except for the Southern vs Seaboard). My mention of the Espee Daylight was to indicate other roads dabbling in steam ejector A/C but moving on to something else.
The UP seems to have settled on electrically driven A/C for their Streamliners, head end power for the Winton 201A powered trains, then axle-driven generator power for everything later. The HEP equipped trains also had steam heat, and the last of the HEP equipped trains were confiured to use a combination of steam and electric heating - funny thing was that electric heating was more efficient despite the losses (engine and alternator) in converting diesel fuel to electricity. The UP appeared to want at least 400lbs/hr of steam capacity per car, which translates to 100+KW of electric power. Given the extra efficiency of electric heating, they might have been able to get away with 30 to 50 KW per car. That’s substantially more than the power needed by A/C and it probably didn’t make economic sense to size the HEP to heating load, especially since they were power
Love this topic, as my Uncle Tony was an old steam generator repair specialist. He worked on the California Zephyr back when the WP ran it into Oakland and heated the train with steam generator cars. These were baggage-dorm conversions with two mounted steam gennys , all with their own water and fuel tanks. The SF Super Chief used the same type conversions later on too.Some of them went to Auto-Train. The NY Central also had some cool looking black steam gen cars too. Does anyone know if they were used on the 20th Century Limited? I’m looking for NYC consist lists in the 50’s and 60’s. Help! thanks all.
The NYC did have steam generator cars, but the Century was assigned the best E-unit power which had boilers of sufficient capacity in my experience. However, there may have been times when one of these generator cars was added at times of extreme winter cold. Never saw this, but it certainly was possible.
One thing I have never seen a discussion of - Steam generators on diesels. How many cars could they supply acceptable steam volume and pressure for?
Was motive power assigned to trains based upon the number of engines necessary to maintain line speed or were the number of engines base upon the number of steam generators necessary to provide sufficent steam through the train?
This is one of those “it depends” questions. Assuming “normal” steam demand a Vapor 4625 steam generator (GPs, SDs, F7, FP7, FPA2, FPA4) could generate up to 2500 lbs of steam an hour, good for five or six average heating/cooling loads. On many trains there were several head end cars that were entirely unheated or only minimally heated, so the train could be longer than 5 or 6 cars, making engine power more important. A fairly common arrangement, especially on western railroads, was an A-B pair of F-units with a boiler in the B unit only, where there was room in the carbody to carry water. E-units and some PAs were often fitted with the larger Vapor 4740 SG( ~4000 lbs/hr), which could heat 8 or 9 cars. The point of no return was reached at about 18 cars, where steam could no longer be counted on to reach the rear of the train. Many railroads, from the New York Central to the Great Northern, built steam generator cars out of everything from old B-units (Southern, D&RGW) to locomotive tenders (many examples). Amtrak built S/G cars out of E8s, leaving the cabs intact, at least on the outside, during the period of HEP conversion. These were run in the winter to reduce the fuel load on the locomotives, to allow freight locomotives to be used in passenger service, or at the end of trains that were extremely long or ran in extreme condiditions. Several railroads (UP) installed S/Gs in Baggage or Baggage-Dorm cars specifically for end-of-train use. As far as I know only NP used water-baggage cars to allow more fuel to be carried on locomotives. On very cold days the S/G could use a lot of fuel.
I guess the more direct answer to you
As rcdrye touches on, the issue often wasn’t supplying the heat, it was carrying enough water. The steam generator in say an F7 A unit would probably be enough to heat a train that a single F7 could haul, but an F7A only had room for a small water tank…I think something like 300 gallons, while in a B unit you could get a 1500 gallon tank. (In a B unit, the steam generator and water supply was located where the cab would have been on an A unit.) So a local train with say 4-5 cars that could have been easily pulled by one F unit might have needed an A-B consist to keep the cars heated if the trip was of any distance. Otherwise, they would have to make stops to resupply the water tank.
That’s one reason GM developed the FP line, F units stretched to allow for a steam generator and large water supply.
Back to the original question…it’s important to understand that the transition from steam to diesels wasn’t ‘all or nothing’, and happened more quickly than anticipated in many cases.
When a railroad bought new streamlined cars c.1939, and E-units to pull them, those E-units were probably (except for some switchers) the only diesels the railroad had. If one of them went down, the railroad would use one of their passenger steam engines to fill in. It’s easier to put a steam generator in an E-unit than to put HEP in a steam engine. Keep in mind, some railroads (like New York Central) were running trains of streamlined cars with regularly assigned steam engines into the mid-1950’s.
Second, when a railroad bought new steam power, they assumed the engine’s service life would be about 30 years. A railroad receiving new 4-8-4 engines in WW2 didn’t anticipate that those engines might be scrapped before they reached 10 years of service. I think by the time the railroads realized steam would be virtually gone from mainline passenger service by the late 1950’s, they had already invested in a fleet of steam heated passenger cars. Easier and cheaper to keep using what you have, rather than re-do all the engines and all the cars.
The B&O purchased a series of F3 A & B units with steam generators for use in passenger service, specifically the all new Vista-Dome equipped streamlined Columbian. Once placed in actual service it was found that the engines could not consistantly provide steam from the coach yard at Chicago to Grand Central Station for boarding and then on to Garrett, IN for a crew change and watering. The engines frequently arrived Garrett out of water. Subsequently the B&O used E units for all passenger runs out of Chicago. The F3’s, with their passenger gearing were then assigned to the B&O’s Chicago Division for use in fast freight service - and the passenger gearing defined fast.
A typical F3 or F7 with a boiler had a split 1200 gallon tank - 800 fuel and 400 water. Some units had a hatch tank in place of the dynamic brake hatch that would hold 600 gallons (these ones usually had the full 1200 gallon fuel tank). FP7s had space for two more tanks totalling 1150 gallons - an FP7 with a hatch tank could hold 1750 gallons without sacrificing fuel capacity. The smaller vapor 4616 (1600 lb/hr) S/Gs had a 200 gallon tank under the S/G itself. F7B units had 1200 gallon water tanks. The “Torpedo boat” GP7 and GP9 configuration moved the air reservoirs to the roof to allow for more fuel and water capacity.
Interesting point on the expected life of steam locomotives. So what was the reasoning behind this? Was it thought that diesels would not be suitable for all situations, and a complement of steam power would be present on rosters for the forseable future? Or did the superior economics of the diesel exceed expectations, and the RR’s realized they must retire all steam regardless of the relative young age of the locomotives?
A lot of railroads recieved steam power during WWII when they wanted diesels but the manufacturing capacity was needed for other things. They presumed that these locomotives would continue to live on in their fleets until their economic usefuless was over. This came more rapidly than expected however as wages (and thus steam costs) rose very rapidly in the 1950s, which made replacement with diesels attractive.
p.s. Another reason it was easier for Amtrak to do it is that they were one organization. Railroads passenger cars sometimes ended up on another railroad for part of it’s journey, like say ATSF sleepers going from Chicago to New York City on a New York Central train. It wouldn’t do any good for Santa Fe to convert to electrical heat if NYC was still using steam - or vice versa.
They had to be compatible; either they all change, or nobody changes.
Into the late 1960s the Pullman pool was also in play - a PRR sleeper might end up on just about anybody else’s train for one or more trips. Conversion to HEP was also expensive. C&NW did it first for commuter trains, using former freight F7s and extra E8s, with Cummins engine/alternator packages, and then ordered the “400s” where any extra cars could be drafted from the commuter fleet. C&NW’s first bilevels (StLCC 1955) were also among the first cars converted to HEP from steam to match the 1958 P-S order. The first were probably C&NW’s diners and lounges which also got “hats” to match the bilevels’ profile.
