I’ve got a set of five ancient Mantua streamliner passenger cars. Three came in a “box of trains” from a yard sale when I was a young teen, and the other two were purchased more recently on eBay. Two of the originals came with interior lighting, and I’ve added lights to the others.
The wires from the trucks to the body on the ones with original lighting seems to have a cloth weave coating. I did mine with stranded wire. Those original-wire cars have never been a problem, but two of the wires on my own have failed after only a couple of years of pretty limited service.
What kind of wire do you use for this? Is that very flexible stuff available? What’s it called?
Thanks.
Mr. B,
A number of vendors offer special, small gauge extra flexible wire for this purpose. Typically, it’s around 30 gauge. Several selections here, for instance: http://www.ngineering.com/accessories.htm
But good wire for this may be closer than you think. The wire found in the typical computer mouse is excellent and very similar to that sold special for this purpose. That’s where I get most of mine. It’s easy to strip out and donor mice can usually be found around house or at something like the Goowill store. Doesn’t matter if they work or not, just that they still have their tails.
One of the best inexpensive sources of small gauge twisted strand wire for engine and car lighting, as well as structures, is the 28 or 30 AWG ribbon cabling found in desktop computers. Go to someplace that recycles computers (metals recycling yards) or a Goodwill store and you can find lots of these cables where old computers are recycled. Just use a scissor to cut the connectors off each each end, then use a sharp hobby knife to separate the wires singly or in pairs, as needed. I usually use a pair, and color one wire with red marker to help in my wiring tasks. They are easy to fit into engine shell spaces and are generally more than long enough for most applications at the HO level.
Of course, you can go to a local computer store- such as Tiger Direct (the old CompUSA chain) and BUY new ones- but, go for the less expensive route of harvesting them from computers being trashed.
Cedarwoodron
Plastic coated #30 will be stiff. You want rubber coated #30.
Lots of computer ribbon cable is plastic coated. You want max flexibility to connect loco trucks.
NWSL has #30, 7 strand and #30, 28 strand. The 28 strand is very flexible compared to 7 strand.
Been a long time since I used mouse wire but it may be around 28 strand as it is very flexible.
I’ve used wire from Miniatronics Incandescent Bulbs. There usually have more than you need, in some apps.
Frank
