I am just getting back in the Hobby after 35 years or so. After some research i have purchased an NCE Power Cab starter system. I am in the process of building an HO scale layout that will represent a division point. From the main yard area my power will have to reach 30 feet in one direction and 25 in the other.
My questions are:
1 What size wire do i need for theses size “bus” runs? The NCE is a 3 amp system
Should I connect the smaller feeder wires directly to that size bus or will I need an intermediate step?
I plan to run a smaller size wire off the main “bus” into the yard areas and run the feeders to that because of the number on connections. Is that a good idea?
I remember the horror of wiring a layout for DC in the late 60’s even with my Grandfathers help. This seems much easier.
Thanks for the input!
Jeff
I would use 14 gauge as your main bus wire. I personally use solid core wire as its easier to strip when I solder my feeders to it (the stranded tends to fray a little) however stranded is easier to “pull” into place
My feeders are all connected directly from rail to bus. no intermediate step. My feeders are stranded wire ( found a bundle of 2000 prefabbed 11" twisted pair red and black 18-20 gauge feeders(not sure exactly the guage)) . All i have to do is strip the ends, tin and drop them in. I tin all my feeders before they are installed.
I will used 20 or so guage solid wire when I run out of these prefab feeders
The reason I would use solid wire (I tin all my feeders so they act like solid wire) is that I create a L shape in the wire to create a mechanical joint against the rail. This keeps the feeder in place even before I solder the joint.
I would run a separate bus for your yard just in case you decide to make it a separate power district in the future. My yard has a separate bus as I several circuit breakers around the layout. I use these so that if the yard operator shorts it doesn’t shutdown the whole layout.
DCC has greatly simplified wiring.
I hope this info helps.
Between that COdy’s Office episode and the recent articles on wiring in MR< I REALLY hate that intermediate wire step - all to make it possible to use suitcase connectors. They coudl solder that #20 feeder right to the #12 bus and be done, but instead you have to get extra wire AND TWO suitcase connectors for each and every feeder wire. A complete waste.
Thanks for the explanation, Randy. I never could figure out the reason for the intermediate wire. i’ve been using 24 gauge wire from rail to bus for over ten years with no issues. Of course, I have always soldered my connections, and never thought about using connectors.
Errol
