Hello All,
I’ve recently converted my pike from DC to DCC using the Bachmann EZ Command system.
It is an oval with a stub Wye on one side of the oval inwards. A simple Wye used for turning locos.
Both the turnouts from the main line and the Wye have insulated frogs; Peco #2’s Insulfrogs on the main line to an Atlas Wye.
I’ve used insulated rail joiners on all rails on both legs of the Wye just past the turnouts on the mainline.
The Wye is fed with a MRC AD520 reversing loop module drawing power from the main line, wired per the mfg. specs.
Here’s the problem:
When both sets of points are thrown to the Wye when a loco passes over the insulated rail joiners; one set of trucks on the on the mainline, on set of trucks on the Wye, a short occurs.
If I only throw the incoming set of points to the Wye, leaving the other set of points on the mainline, there are no problems. The loco then moves to the Wye, it is thrown in the other direction, the points on the mainline are reversed and away we go.
The position of the points on the Wye don’t affect operation. Once the loco is on the Wye the sequence of switching the points on the mainline doesn’t matter.
I have even been able to run one loco on the mainline loop while performing this opposed switching operation to turn another loco simultaneously!?!
This means that my switching actions need to be precise and I cannot have both sets of points from the mainline towards the Wye at the same time or the above described short occurs. Yet both sets of points can be switched to the mainline with no problems. Again, the position of the Wye switch has no effect.
I’ve communicated this to MRC with not much success.
Does anyone have any suggestions on how I can wire this Wye so that both sets of points off the main line can be thrown simultaneously rather than sequentially.
Thank you.
