Wiring for a signal light
Picked this up cheap at a swap meet. It has four wires, two reds and two greens. It looks like the diagram is suggesting I join each pair of red and green wires together to create two leads going to the AC source. Can that be right? And if it is, does it matter which pair goes to negative and which set goes to positive?
Thanks for any help.
That looks like a ‘vintage’ pre-LED signal. probably has a red and green tinted 14V. incandescent grain of wheat bulb in there.
With the wiring shown you will have both bulbs lit continuously. If your source is AC there is no positive or negative.
You could wire a single pole double throw switch on one side of the leads to give you red OR green lamps illuminated.
Good Luck, Ed
@gmpullman Ed, thanks for that idea. I’ll do that but first I need an answer to my question. Am I to join red-green on each side? I don’t want to blow the bulbs.
Yes, you would join red/green on one leg and red/green on the other leg. Both lamps in parallel.
Check first with a 1.5 volt battery, if you see a faint glow from the filaments you’re OK, then move up to a 9V battery. They should be fairly bright.
The AC outputs of some ‘toy’ train transformers can be 16 to 18 volts sometimes. You’re probably better off to use a 12 volt regulated wall wart. Running 14 to 16 volt lamps on 12 volts will extend the life of the lamps. Plus signals shouldn’t be too bright anyway.
Regards, Ed
@gmpullman Thanks Ed. That’s helpful. I have some other non-LED lights on a wall wart and they work great, not too bright. I suppose I could just run some wires to the buss running off that wall wart, and interrupt one side with the STDP.
I don’t see much point in the ‘simplest possible wiring’. What I think you want is a double-pole push button switch with separate NO and NC contacts and wire it so the switch connects green in one position and red in the other. You could also use a double-pole double-throw switch with center off, which would throw one way for red, the other way for green, and both bulbs dark when centered.
