i have this problem an need help im so confused with this i have a layout that returns on its self like a dog bone but i say better lol well i wanna know how can i have my train run on the reverse loop without turning my system off also how in the world do i put pictures in here so ya can see what im talkin about o well if someone can help let me know thx
im using dcc an its ho scale the tracks are gapped at each end of each turnout so what else i need to do my dcc systek is atlas for now but i plan on getting digtrax or lenz witch is better for me cuz i can use the atlas control ( walk around ) thx again
You need to upload your images onto a webhost such as photobucket and then link to the full sized images here using the [img] tags.
Your loop should be gapped at each end, where the ends meet the one turnout. Then, feed that length of loop with its own feeders, but wired through a double-throw/double pole switch that reverses polarity. That’s if you want to do this on the cheap and manually…as many of us do. Or, spend $40-80, depending on what you get and from whom, for a digital electronic reverser that does it all for you. Same thing, wired in series into the feeders for the loop.
The first thing I’ll say is your track layout is going to be a nightmare to wire, with DC or DCC because you have two interconnected reverse loops. You need insulated rail joints at the frog end of all your switches that lead into these loops, and the loops need to be their own block. For DC, they’ll need their own reversing switch, for DCC, their own reversing unit.
But looking at the way the tracks are interweaved, I’d have to ask “why?”
the answer to the " why " is i want to turns trains around an not pick them up you know by hand so i want them to turn on there own also do isulate the turnout in front or at the back im confuse here very confuse [:(][:(]
I understand the “why” of a reverse loop, the question I posed is why you intertwined two of them. Doing this will be an operating headache, as well as a wiring headache, no matter whether you use DC or DCC. You’ll only be able to have one train in either of the loops at one time. They aren’t separate sections of track.
well first off my layout is in the attic n i want my trains to go all around the attic but then i said how can i get them to turn around without picking them up so i made the loop on top of each other its like a dog bone the only thing the loops are together one going one way the other going the other way but if i illiminate one loop then i cant turn that trains around it will stay just goin in one direction
You don’t seem to understand the question I’m posing, so I’ll explain a simple change. Your attic seems to have a long enough run to put a gradual grade in the part that runs between the loops. As your reply implies, put one loop on top of the other, not on the same level as each other. Stacked, not intertwined.
The other option is, you have a simple loop around the attic if you eliminate the two intertwined reverse loops shown in the top photo.
