Hey guys new to the site and new to the hobby! I am a railroader and looking to get some useful info that I’ve been searching for, for a while.
I’m a little confused on how exactly the wiring works. I am going with DCC and have started laying cork on my 12x8 L shaped benchwork.
I have been told by a few hobby shops now that a pre soldered joiner along with my NCE power cab starter system which is the controller I’ve decided to go with is all I need to get trains running is this correct? Also I don’t know if this falls in this category but soldering each joint will carry the signal better? But what about if I ever want to change anything isn’t it pretty well set in stone once soldered? I have custom line #6 turnouts if I do use just the pre soldered joiner will this carry the signal through each turnout lined for normal as well as lined in reverse Coming from 1 fixed location from my powercab?
Not sure what you mean by “pre soldered joiner”, but soldering rail joiners is a good idea, along with installing feeder wires, every 6’ or so along the railroad.
Nothing is set in stone, as far as model railroading goes. If you can solder, you can easily unsolder something you want to change.
As I understand it, Atlas sells joiners that have feeder wires already soldered to them. It is a waste of money. What I have done is soldered my 18 AWG feeders to the rail joiners and then soldered the joiners to the track. Joiners are also soldered to the track where there are no feeders. I have left some joiners unsoldered to provide for some contraction and expansion. Have never had any problems.
OK, now that Bearman reminded me of the Atlas “pre soldered” joiners, lets break this down.
Yes, that will get a train running, temporarily, but you’ll want to make more permanent connections as you build the layout, and install feeders along the way, and solder rail joiners, so the power isn’t just coming from one spot.
Yes, soldering the joiners will carry the signal (power) better. And as I said before, nothing is permanent on a model railroad. If you want to change something, unsolder it.
You can put your joiners at each end of a turnout, both ends of the through route, and on the end of the diverging route. But as I said before, you want more than one fixed location, you want feeders along the layout, and these feeders is what you can put on each end of the turnout.
There is some good reading on setting this all up, I’m sure someone will come along and link to some it.
You will learn about “bus” wires and “feeder” wires to spread the power of your controller over the entire layout, and not just coming from one location.
Randy also does this. I have tried it once, and found it unwieldy to connect the track, as the joiner is tethered to a wire. Do you have tips? What I did was to drill the hole for the feeder, then take a dremel with a burr and made the hole a long narrow oval about 3/8" deep so I could move the joiner fore and aft.
I am a believer of either a solder connection or a feeder to every piece of rail and my first layout was all soldered and I had big problems with rail kinking. I will probably solder a couple pieces of flex track when I get to laying the big curves, but so far I’d rather attach feeders directly to the rail.
Soldering is a skill that few are born with. Melted ties happen when you are new and not very skilled. Practice on a piece of sectional track.
I use to buy the pre soldered rail joiner made by Atlas but they were kind of expensive and the stranded wire was pretty thin and would sometimes break so I started just making my own. I just buy a bunch of Atlas rail joiners and solder a bunch of foot long pigtails onto them using solid 18 gauge wire. I make them with both red and white wire so I can tell them apart when hooking them up to the main ‘bus’ wires.
I suck at soldering so I make them on the workbench were I have more control. I never solder my track ever and I rarely have problems with getting good connections using only rail joiners. I use the pre soldered rail joiner about every ten or twelve feet.
A lot of people like to solder every piece of track to the next piece but that is a lot of time that I would rather spend doing something else. I just make sure I use new or like new rail joiners and make sure they are on tight. I also like to make sure that the rails actually touch.
Henry, Lone Wolf and Santa Fe does it more or less the way I do. I solder the feeder to the bottom of the joiner on my work bench and drill a hole at the end of the rail. Feed the feeder wire through the hole and then join the track sections and solder the joiners to the track. And you don’t have to solder the joiner inside the track, the outside alone works fine.
there’s no need to solder a separate feeder to every piece of rail. Solder together the rails at every other joint and solder a feeder to that joint. You will then have a feeder to two rails.
every other joint does not need to be soldered and a gap can be left for expansion/contraction of wood due to humidity more than temperature. Not sure if the gap is needed in the summer (humid) or winter dry.
soldering is not difficult. make sure the surfaces are clean. if both parts are pre-tinned you may only have to heat them together and hold in place to cool w/o needing to add additional solder.
The ones I solder wires to (I do this at the bench - I never buy the Atlas ones, they are insanely overpriced) are always fresh out of the pack.
For trial fitting of track, I keep a few around with no wires, that have been connected and unconnected several times, so they slode on easily. These are the kind that would be a problem if relied upon to conduct electricity, since they are a loose fit to start with adn any paint used on the rails will surely get down inside. But for frequently connecting track to mark and measure placement, the loose ones are the way to go.
So now that I know where the next piece of track goes - and thus the joiners - I can drill my holes for the feeder wires and stick a pair of wired joiners in place - NOT attached to either the already placed track or the piece I am about to add. THEN I connect the track with the joiners. SO the wires really don;t interfere with anything.
Using flex track, there aren’t THAT many joints, even on a bedroom size layout. I do put wired rail joiners on all 3 legs of Atlas turnouts.
Lots of people say this whole thing is unreliabe - especailly with additions like “wait until you paint the rail” or “wait until you ballast” - well, I did both on my last layout and never had the slightest dead spot. All that exposed shiny metal around where the points pivot on Atlas joiners? Yeah, that all got painted so I didn;t have shiny bits standing out. Joiners got painted over, a little extra heavy too, to make sure the paint covered the edges. No loss of power.
I have a hard time trusting things not to move, even when the layout was in occupied living space to temperature and humidty didn;t vary wildly. And it was on extruded foam which isn;t nearly as affected by humidity swings as wood. So I only soldered every OTHER rail joint, and never soldered a joiner to a turnout. Perhaps I’m overly paranoid, but it definitely mea
Okay so feeder wires every other peice of flex track(6’ give or take)will work well solder every other joint but not in turnouts.
and I know this might be a dumb of me to ask but just want to make sure! Can I use 1 bus wire for double track? And how exactly do you run it out from your controller around track? Is it a connected loop or just dead ends back at its point of origin? What size wire for bus and what size for feeders?
You guys make it sound so easy I hope that’s the reality of it haha
One bus is fine for 2 or more parallel tracks. Just wire them all the same. For each parallel track, one rail will be closer to the backgrop and one will be closer to the aisle. Or however you want to differentiate them in your head. The rail on every parallel track closest to the wall should go to the smae bus wire, and the rail closest to the aisle on each parallel track should go to the other bus wire. That way if one of the parallel tracks happens to be a siding off the other, there won;t be any shorting issues at the turnout.
So just a few more questions! I’ve been doing some more research and I’ve read about cp6 circut breakers are these necessary? I was just going to run the bus from my controller Around the main line… also read about blocks which I’m not even sure how you up… just looking for someone to really lay out what I need to do from start to finish. I have a 12 x 8 L shape layout - 1 yard is triple traxl one yard is double track and two more singles track yards. If someone could help me out that would be great!
It would probably be best if you posted a sketch of your proposed layout. This forum has specific rules on how to post a pic, otherwise no one sees your picture.
If you are a one man operation, having a bunch of power districts, so that the whole layout is not shut down by a short, isn’t that much of advantage on a small layout.
The bus ought to start near the middle of the layout and go to either end, rather than start at one end of the layout and having a 20 foot (12+8) run from the command station.
A 12’ x 8’ L-shaped layout is small enough to wire with a single pair of bus wires running right down the middle of the underside of the layout surface. Then, just wire the track feeders to the bus wires and connect the bus wires to the command station.
The only reason to use circuit breakers would be if you feel the need to create separate “power districts” which are essentially blocks of track. For example, each of your yards could be a separate power district. But, honestly, if you intend to be the sole operator, there is no need for separate power districts on such a small layout because the main reason for separate power districts is to isolate shorts so that the rest of the layout does not come to an unexpected halt.
When separate power districts are created, the section of track forming the power district is isolated by gapping each end of that section. Power to the input side of the circuit breaher can be provided by a pair of wires from the bus. Power to the track inside the power district is provided by a pair of wires from the output side of the circuit breaker.
