Wiring Up A TMCC Connection on a Conventional Layout
Hello:
Now please bear with me because I’m a newbie at this electronics. I normally run PW conventional engines. After inheriting some TMCC equipment ( Trainmaster Command Base and Cab-1 Remote-part # 6-12911 and a Powermaster Unit that has a switch for both 135 or 180 output part # 6-24130, I am confused on exactly to hook this up to my conventional track using an old Lionel Lockon. Does having a Powermaster mean I don’t use my old ZW? The command base has a Track U terminal which means I connect a wire from the Command base U terminal to a U terminal on the ZW, right? So must I also run a lead from the outside rail lockon connection to the same U post on the ZW? If not, how does one complete the circuit for power? I searched for videos to no avail. Any help and wiring instructions will be much appreciated.
Mickey
Okay if your trying to run a command engine The U on your transformer should go to your outside rails. The A,b,c, or D to the middle rail. The base unit should have a 3 prong plug adapter that will connect to it. ( that powers it. ) there should be a place to attach one wire on it. that needs a wire going to the track connector for outside rails or you can connect it to the U on your Transformer. Now before I go any further you should have fast acting fuse or other items that do that. Okay check out these manuals from Lionel
https://www.lionelsupport.com/media/servicedocuments/71-2911-250.pdf
https://www.lionelsupport.com/media/servicedocuments/71-2911-251.pdf
https://www.lionelsupport.com/media/servicedocuments/70-0000-000.pdf
If you don’t have any TMCC/Command equipment, the Command Base is not used.
The PM-1 PowerMaster w/ Cab-1 is used with conventional trains like a remote control handle of a ZW. There is no transformer in it, it is powered by an external source, for example the C or D handle of your ZW set to full throttle.
The manual to get you started with basic PM-1 conventional operation can be viewed HERE.
Here is the “video manual” for the 135/180 model PM-1 to get you started:
