There are other manufacturers as well but as far as I know, the Tichy are widely available and in a multiple of sizes.
Does your kit actually have functioning, threaded truss rods and you need the small brass nuts? Possibly Micro-Mark or others may have small brass nuts. Square may be trickier to find.
They would align with the truss rods and queen posts on the car. Some wood cars had steel end sills, older ones were wood with large iron or steel washers.
Not functional. I’ve looked on Tichy and the new owner of Grandt Line (San Juan Model Co) and elsewhere, and was hoping for something specific. But it looks like a normal NBW would be fine. Does anyone have an idea of what the size would be? Diameter of the rods, for example? I would guess an inch or two.
No, they are stay bolts. Boilers are one case where they are used, but they are not exclusive to boilers.
Definition of stay bolt. : a bolt or short rod commonly threaded throughout its length and used as a stay to connect opposite plates (as in a steam boiler) that are subjected to a pressure tending to force them apart.
Both Tichy and San Juan Car Co. (formerly Grandt Line) offer NBW castings in a variety of styles and sizes.
I used some on four of these modified Tyco reefers…
I do know of at least one HO modeller who made functioning turnbuckles on a model of an early 20th-century freight car - as I recall, there were six underbody truss rods, and at least two additional ones on each side of the carbody. Each one would have been threaded like the real ones - right-hand thread at one end, left-hand thread at the other.
Ed, I think you need to diagram exactly how the truss rods on one of these cars work, and what the various nuts and queen posts and such do. To defend calling a longitudinal truss rod a ‘stay bolt’ only starts with the observation that there is no actual ‘bolt’ involved, only the threaded end of a rod…
Even the case of transverse rods acting to ‘stay’ car sides would involve 'stay rods’.
If we have to have nits to pick, we can look at why normal radial staybolts are called that when they’re threaded on both ends and have no ‘bolt heads’. Indeed older construction used things like ‘girder stays’ and ‘palm stays’ and these are not bolts.
On the other hand a flexible staybolt is clearly a bolt with a head … and if you have any question, the better ones came from the Flannery Bolt Company in Pittsburgh, would they lie? … and generations of boilermakers have made and threaded staybolts without misunderstanding the thing or the tools used in connection with it. Somewhat less certain is the semantics involved with the ‘fillet-welded staybolt’ and some of the late German practice involving its ‘safe’ use – personally I’d prefer the term ‘welded stay’ for anything that is full-pen welded rather than threaded in.
People since the age of Winans have happily used the meaningless term ‘friction bearing’ as if it actually meant something – you could justify this by saying that many years of unquestionably professional use makes it ‘correct’, but it kinda doesn’t…
Probably, but as Overmod mentions, the whatchamacallits sticking out of the car’s endsills are simply the threaded ends of the truss rods - not really a bolt at all, even though they’re meant to accept a washer and a threaded nut on each end.
Note how the truss rod passes over the truck bolster at Body Truss-Rod Saddle #20 . Excellent design element to “carry” the weight. This car may pre-date turnbuckles.
I have drawings of an “upset” truss rod where the threaded ends were forged, or upset to increase their diameter at the threaded ends but found no actual reference to the thread diameter or pitch. At least 1" and possibly 1-1/8"?
Actually, as others have said, they’re nuts and washers with the end of the truss rod as the threaded part. I model the 1890s/early 1900s in O and I use .024" black monofilament line I got from Clover House, the premium dry transfer mfr., but they only list their #4295 .018" now. I have a nice coil of it, probably enough to last the rest of my life, but you may be able to find .020" somewhere else online. I make my own styrene washers and square nuts in the car end sills, center-drill them in place, then run the line in from both ends. Grandt Line has O scale turnbuckles in plastic that are D&RG (and other NG lines) prototype that just fit the monofilament. Prototype truss rods on vintage freight cars run about 1.25", which is close enough for me, since they work so well. I first CAed the “rod ends” in the Grandt turnbuckles, but they eventually came free, messing up the whole truss system. Now I use a method I saw in MR years ago: I run the “rod” into the turnbuckle and push it out from the center of the trunbuckle, then mushroom the end with my solder gun–quickly. It’s tricky and I’ve broken the turnbuckles a couple of times, but there are plenty of them in the Grandt Line package. (BTW, I’ve had no luck trying to order any of the parts online–waited months with no reply–and gave up, but if you find the part number on the site, you can often get them from an ebay seller.) Once both ends of the “rod” are in the turnbuckle, I thread
I use monofilament fishing line for the truss rods, as it’s less likely to stretch over time. I also use strip styrene, simply slipped into place, as tensioners inside the car. If it ever does get droopy, it’s easy to slip a slightly thicker piece into place. The clear line also allows a see-through look at the turnbuckles, and the truss rod portions readily accept most kinds of paint…
In the photo above, the turnbuckles are not yet affixed in their proper place, but are easily secured with a very small bit of ca. Here’s one of the slightly modified original cars…
…and the shortened carbodies…
This modified Model Die Casting boxcar better shows the tensioning set-up, and the fact that all four truss rods are done using a single length of line…
Tichy has excellent N-B-W castings, and it seems Grandt Line has as many NBW castings as Heinz has varieties, HO and O! (bolts and washers vary)
For those in HO, don’t forget that Kadee still sells their metal castings, which I find easy to deal with and less prone to disappearing somewhere on the floor.
Thanks all for the great information. I ended up using NBWs with 2.5" nuts from Tichy for the end stay bolts. The following link is to a photo of the results. (I did a poor job on the brake gear but you learn from your mistakes!)
