Curious about the approximate color of the Weeds Fine Turf product. I have used their blended green fine turf, but it is a bit on the light side. Is the weed mix any darker? Some of the photos of the blended fine green turf show a really dark color - but that isn’t what the actual product looks like. Just hoping what I see in the photos of the Weed Fine Turf is fairly accurate.
Thanks,
RH
I usually apply the various colours of ground cover at random, and often do the same when making trees…
…and if I don’t like it, it’s easy enough to go back over it with a re-do.
I tend to do the same with trees, but if you want darker colours, you could probably try altering small quantities of it using water-based acrylic paints…simply dump some of the ground cover into a suitable container, then add some paint, then spread it out to dry.
Another option would be to apply the ground cover of your choice,then airbrush it randomly using the water-based acrylics available at most Dollar Stores.
“Weeds” is just a darker green color.
I use Woodland Scenics blended turf as a base, then add assorted other colors, including weeds, to add variety to the landscape.
-Photographs by Kevin Parson
There are lots of greens in nature. Using a variety makes me happy.
-Kevin
