You put a locomotive on the track and you begin adding cars for it to pull. Sooner or later this locomotive will stop moving. When that happens you turn the power off and you start counting: one . . . . . two . . . . . three . . . . .four . . . . . When you run out of cars to count that’s how many cars this one engine can pull.
I suspect the original poster does not have any Z-scale equipment and thus can not do as you suggest.
That being said, there is no one correct answer to the question. I don’t have any Z-scale, but I do have N-scale, and I have engines that will pull as few as 5 or 6 cars and one that will pull more than 70. I am sure you would get the kind of variations in Z-scale from egnine to engine(although I doubt you could find one that could pull 70). If you have a particular locomotive or even a particular type of locomotive, someone may be able to answer your question more precisely.
I think the amount of cars a engine can pull depends on the same factors as in any scale, including Z. Here is a link to a MR file where they product tested a GP35: http://www.trains.com/mrr/default.aspx?c=a&id=519 mind you they do not say how many cars this tiny locomotive can pull except for a decent length of train. Go to http://www.cwrr.com/nmra/Layout-ZN.html and check out the layouts there and see what those locomotives are pulling.
Being a Z scaler (among other scales) I can answer from my own experiences.My MTL locos will pull 15 cars.around curves 17 on straight track.They could probly pull more but my layout is 2’x4’ so the curves come fast.
To be totally honest, one thing I really like in a review ( and appears to be missing from recent MR reviews ), is a general comparison of how the reviewed product performs in comparison to the class average - I feel it helps me stay away from poorer performing equipment
Look there Jimmydieselfan, my answer may have been just a little tongue-in-cheek and when I made it I should, perhaps, have been in Bed Springs giving perusal to the inside of my eyelids. Look, if you will, at the title of this thread and tell me what is wrong with my answer. Boyd did not specify two things that are essential to giving an exact answer to this question namely what Z-Scale engine are we talking about – are we talking about an F7 or are we talking, perhaps, about an SD40-2? – and what is the environment in which this engine is going to operate – do we have 2% ruling grades? or 8" radius curves? what type cars are we talking about? passenger cars? 89 foot flat cars with trailers? I’m not a Z-Scaler! How in the living h*** am I supposed to know how many cars a Z-Scale engine will pull? Half the time I don’t have the slightest idea how many cars my N-Scale locomotives are going to pull. Except in rare cases I always operate with a minimum of two diesels on the head-end of any train. I just keep adding units until my train moves and then I balance the consist.
I have a number of Kato’s original N-Scale SD40 offerings from the early ‘90s. One of these lokes will pull a string of 39 40’ cars; I have another one that struggles with 36. Don’t ask me why – [b]and please, lets not go o
As in any scale, it’s going to depend on a great many variables–the type of engine, the weight and balance of the locomotive, the motor efficiency, whether the MR is flat with wide curves, or grades with sharp curves–way too many variables to give a ‘blanket’ answer.
Just as an example, on my own HO model railroad, which has fairly generous radii and relatively realistic grades (average 2%), I have several smaller locomotives that will out-pull one of my larger locomotives. It has a lot to do with weight and more importantly, balance–where the weight is distributed most efficiently over the locomotive drivers.
So in any scale, I don’t think you’re going to find an absolute ‘blanket’ answer. Perhaps if you get more specific as to locomotive type and manufacturer, you’ll get a lot more positive input from fellow Z-scalers.
If you search around the net, I suspect you can find reviews (either by RR mags or “user” online reviews) that will answer your question based on what engines you’re looking at. Keep in mind that in the US I suspect most Z-scalers model the diesel era, so are often running mainline trains with 2-3-4 engine consists…so sometimes the key issue isn’t how many cars one engine can pull, but how well do three of the engines run together. In my non-Z experience some manufacturers diesels all run about the same speed out of the box on DC, while others vary widely even in models of the same engine. Of course in DCC this is less of an issue, but I suspect that the pct. of modellers using DCC in Z is lower than say HO just because of the difficulty of adding a decoder in such a small space.
I’m going to say that one can probably take at least 10 cars—judging from what I seen from a friends ‘office layout’.It is based on a UP mainline run using diesels. Mind, on a flat surface yet. On a 1% grade he had to take 2 cars off.
As for the kvetching about the OP—why answer the dang thing if’n you can’t believe the question? This thread might have already been answered a while back----then again I did this—[:-^]
It so happens that my own best advice is to find someone with the engine in question, if you don’t already have access to it yourself, and test it on something closely approximating the conditions you expect to subject it to. In that respect, the first response, as another from the same poster recently, is a sound one. It is also as artlessly stated as it was during that previous occasion. It is artless because it gives no consideration to the fact that the asker probably has enough intelligence to have done that very testing for himself…had he the engine in hand. In view of his question, it was most reasonable to assume he had no such opportunity, and was thus petitioning the readership. In view of that rather obvious conclusion, the response was of precious little utility.
To the OP, I am sorry you have been treated this way…most responders seem to feel the same way. I will merely lock this thread and leave it for you to seek private help via Private Message or email to those who directly answered your question. I wish you good luck, and I hope you will feel welcome and confident to post another question in time.
