I have a problem with the whistle controls on my Post War ZW transformer. The whistle controls would not activate any whistles/horns for as long as I can remember. I compared all the wiring with another ZW I have which works properly and they are both wired exactly the same. I installed diodes in both sides of the non working ZW and now the whistles function, but the controls are reversed. All whistle units have been tested and work fine with another ZW I have.
When I connect the “A” throttle to the track and apply power to the track and push the right whistle control forward, the whistle clicks but will only activate for a millisecond. When I push the left side “D” throttle lever forward, the whistle works great. The same holds true if I connect the “D” throttle to the track. It seems the “D” throttle control is powering the “A” whistle control and vice versa. Any help would be greatly appreciated. Thanks.
