I’m still in the process of installing a NWSL gearbox in my West Side T-12, and I think I will need to superglue it in place. I’m aware that acetone will dissolve superglue and I have a tin of it, but my worry is that it will also dissolve the plastic of the gearbox. Would this be the case?
Yes and no. Acetone is one of the more active petroleum distillates, Brother and sister to lacquer thinner, Toluene, Xylol, and MEK. Normally used as nail polish remover, which means it can dissolve nail polish which is a nitrocellulose lacquer. One the other hand, it won’t dissolve plastic immediately, I’d expect it to debond the CA long before it dissolve the plastic gearbox, especially if the gear box is made of tough engineering plastic rather than styrene.
There are debonders made to disolve CA (superglue). Different brands use different names, but should work an any brand. They are listed on the same page as the glue.
If the plastic really is Acetal like Delrin (a trademarked variety) acetone won’t hurt it for short term exposures. I use acetone to clean acetal parts I make in my machine shop all the time. I wouldn’t go for a 24 hour soak though because long term micro damage may not be noticable.
Basically, If the chemical in question is only sold in metal containers, it is generally a safe bet that it isn’t 100% plastic friendly. I can’t recall ever seeing acetone sold in anything but a metal can.
