There was a ALCO C430P proposed for New Jersey. Is there a drawing for this locomotive anywhere. Gary
There might be specs or drawings either at DOT somewhere or at NJT. Presumably this was a competitive tender for the GP40Ps, as that might fit the timeframe between Alco building the last of the C420 engines for the Long Island and exiting the domestic locomotive business. I think C430s were only made in '67 and '68 domestically.
There are two broad possibilities. One is the aforementioned ‘more modern’ version of what LIRR got, presumably to run on CNJ as that was the thing in New Jersey getting updated engines in the necessary timeframe. I find this the most likely thing at the time. The other is a FPA4-like analogue of the C636P, probably with Hi-Ad trucks tuned for higher speed – this would have been interesting if provided with similar equipment to the GP40Ps.
It might be interesting to see if Alco was actively tendering long enough to have a C636P alternative for DOT/NJT to go on the lightweight trains that were built with U34CHs. Six-motor Alcos had been notably successful in commuter testing (on PRR and I think CNJ in the latter Fifties), foundering only on the issue of capital allocation, so Schenectady might have had a leg up in initial bidding. Whether these would have the HEP-at-720-rpm arrangements like the U34CHs would be something that Allen Haven or Will Davis might have insight into. They would certainly be something to watch… except the cumulative smoke emission over the years the way NJT ran the big GEs might have been in the kiloton range!
Those eould have been hoods, like the GP40P and U34CH, and optimized for ‘alternative’ EL freight service… which may imply they would not get Hi-Ad trucks despite the primary service and the ‘purchasing subsidy’ from DOT. Certainly EL’s four-motor Centuries did not have them.
For what it might have looked like, take a look at the MLW M420W.
I don’t think the engines Gary’s asking about would have had wide cabs.
The production C430s (NYC and Reading had them in the East, the latter experience highly relevant to CNJ options) all had conventional cabs, and reasoning from the EMD ‘alternative’ the major difference to convert a C430 to comparable commuter passenger service would be to extend the long hood. I would suspect this would retain notches but they would be the shallow ones of late production.
It occurs to me that the design might have advanced far enough to have produced internal-machinery or weight-balance diagrams that may have ‘made it’ to the Alco historical society’s records.
Although not particularly relevant to this subject, here is what the C-636P would have looked like. This was taken from Alco diagrams and built in N-Scale. As previously said, a commuter version wouldn’t be anything like this,but what a beast.
Cheers
Steve
NZ
Speaking of the Alco diagrams, here’s one of them and a great deal besides:
https://web.archive.org/web/20150304071338if_/http://www.gilbennett.com/anatomy-of-a-painting.html!
Unfortunately the original Gil Bennett link to his famous painting of C636Ps has been taken down. But the discussion about his painting it survives in the Internet Archive for our enjoyment.
Five minutes comparing this diagram with one of an FPA-4 will tell you much of what you’d need to know about logically making a cab-unit C430P… note the space available for two steam generators that could easily be used for gensets, or removed if a GTA-9 equipped for HEP were provided…
wouldn’t it have been nice if LIRR had bought an order of C430 cabs and proceeded to build those converted FAs for the other end of the trains…!
Would the roadswitcher C430P have needed a high short hood to house the steam generator?
That is likely so, but there is a little more.
Both LIRR and Monon put the steam generators in high short hoods, but examine the arrangement on the former:
Now remember that the engine on a C430 will be longer by at least the two cylinders in a bank, and this would affect the cab position and hood length, both of which are somewhat extreme on a production C430.
http://i928.photobucket.com/albums/ad124/Fastfreight/alcoc430sidediamensions.jpg
If you translate the SG dimensions in the C636P diagram over to this you will see the first problem; if you look at where the long hood ends and compare it with a GP40P you can see a second: I don’t see a good way to build a SG passenger C430 without lengthening the frame, and doing so might upset the weight or balance to require at least one three-axle truck … at which point a “C634P” designed comparable to the U34CH, with 720rpm HEP from the alternator to save length and weight, begins to look like a reasonable option…
It remains to be seen where “anything else” in the abbreviated high short hood would be relocated if some form of steam generation could be devised to fit in it (remember where they put the toilet on the LIRR ‘passenger’ MP15s?)
The various six-motor Century designs included space behind the cab for a steam generator (or possible HEP?). I believe that NdeM received C628’s with steam generators.
As i recall they did, and the location is as indicated on the C636P diagram (I have not yet found diagrams for the NdeM engines but I recall the point being brought up in discussions)
Note however that we’re explicitly discussing a C430P. The freight version of this was already visibly shoehorned onto the C425-length frame, and while I don’t know for certain I would doubt that there is reserved space behind the cab without lengthening the frame.
On a commuter unit you might get away with using a smaller fuel tank, and of course with HEP, disposing of the tankage for SG water, to keep the weight within four-axle capacity. But that would impair potential use in freight service (which I expect for a C430P in that era to be long Alpha-Jet trains or equivalent, meriting large tank and carrying capacity as for the EL use of the ‘SDP45’ length of frame for some of its units). So a longer frame would be expected.
I love discussions like this. The C-430 rides on a longer frame than the C-424/425. Also different from the C-420. Lack of standardisation was one of Alco’s issues.
Cheers
Steve
NZ
A C430P for suburban service would have to be redesigned similar to GO Transit’s GP40TC’s, which were GP40’s on an SD frame to get the extra length needed to fit the HEP set.
Lack of standardization was not one of Alco’s issues. Consider that the C420 had a V-12 inside which allowed for the longer nose while the others had V-16’s.
Chihuahua Pacific #904 and NdeM 8322-8331 were the C628s built with steam generators. Data from Extra 2200 South #47 page 22.
Ed in Kentucky
CN rebuilt some RS-18s with HEP around the same time. The genset went in the high short hood, which was also extended to occupy the front walkway.
http://www.trainweb.org/oldtimetrains/photos/cnr_diesel/tempo.htm
Talk about shoehorning hoods on a frame…
Note the length required by the split tank arrangement.
I assume that 8324 is a C628P.
Like the C636P, the dynamic brakes which were a vertical stack behind the electrical compartment have been replaced by the steam generator and in turn, the dynamic brakes were moved to a “bathtub” arrangement over the engine, as indicated by the two rectangular air intakes over the engine.
This problem of both steam generators and dynamic brakes resulted in the “hammerhead” RS-3s where the hood did not allow a dynamic brake unit to be mounted over the engine.
Peter
I believe that the C430s with dynamic had a similar dynamic brake relocation, apparently with three slots (see this model:
https://www.bowser-trains.com/images/Loco/C430/24192.jpg
the GB&W model, which did not have DB, shows the difference on this side at least
https://www.bowser-trains.com/images/Loco/C430/24196.jpg
I always presumed this was because of the intercooler location, but the question then arises if there is room to package a SG there with the DB relocated.
As you are the premier authority on the C636, the intercooler arrangements were revised on that locomotive, and I wonder if there were drawings for a “C436” that would show the corresponding arrangement on a shorter frame.
The equipment layout in a C430 is exactly the same as that in a C630.
The C636 equipment differed in a number of respects from the C630, but it occupied exactly the same space. So a C 436 could have been built. But only about two thirds as many C430s were sold as C636s and the whole operation was winding down by that time.
There is no room for a steam heat boiler in a C430 apart from in the short hood.
Alternatively a C630 frame could have been used with four wheel trucks, since this provided a space which was usually used for dynamic brakes, but like the NdeM C628 could be used for a steam heat boiler, but requiring the dynamic brakes to be relocated.
While there is a superficial resemblance externally between a C630 and C636, the airflow was entirely different, the 636 taking the engine air in at the front, passing it through the frame under the engine and up to the turbocharger on the rear of the engine. The C630 (and earlier Century series) had a separate air intake at the re
I can’t lie… That looks like one impressive passenger unit. Had ALCO got around to building a prototype… It would’ve been something to see if it could go up against the FP45.
In itswn way as beautiful as the EMD E5 and E6, and yet says power as well as speed. A beautiful painting. too!
