I have read some things online claiming that the Alco PA is the most beautiful diesel locomotive ever.
Personally, I find them ugly. They look to me like a Bizarro World E7, or like the hellspawn of Satan and an E7. Or like an E7 that took steroids and showed up at a monster truck rally.
On the positive side, I do like the top curve over the driver’s side window.
I find myself coming around eventually with pretty much any unit. I was cold on the N&W Class J 4-8-4 at first, but came around and find it quite an attractive locomotive. No idea why that should be. Same with the C-Liner…eewwww! Now I quite fancy them. I was also averse, like you, to the PA at first, but now they seem to fit into the stable quite nicely.
I believe that it’s important to take it all in context. I enjoy the streamlined diesels from all of the manufacturers, be they EMD E and F units, Alco PA and FA units, and DL 109s, FM Erie builts and C-Liners, Baldwin Centipedes and Baby Faces, or even the more exotic stuff like the big-blow gas turbines. There were a few other oddballs that I cannot immediately recall, that fit with this group as well.
I think that learning the difference between the various offerings were a big part of my becoming a rail fan.
That said, I’m glad that my next door neighbor does not have one sitting out in his back yard rusting away.
GM&O 1900 was constructed by Ingalls Shipbuilding of Mobile, AL - their only attempt at building a locomotive. I believe the GM&O did operate it for 20 or 30 years.
The SCL engine was built by GE as their BQ23-7. This was an attempt to build a locomotive that could hold a full crew at the time cabooses were being eliminated but two man crew agreements had yet to be negotiated.
No doubt about it, the ALCO PA and the D&H “Blue Warbonnet” color scheme were made for each other. Honestly, I prefer the “Blue Warbonnet” over the Santa Fe’s more famous red one.
When you talk about ugly - this comes to mind…Closely followed by…
Could you please share the names and manufacturers of those two? I’m not familiar. The bottom one looks like a Euro train.
Pascagoula is only a good stone’s throw from Mobile on CSX’s NO&M Sub.
Early on: The GM&O’s #1900 was a personal favorite of mine. It was operated at one point, between the GM&O shops at Jackson,Tn., and Corinth, Ms.
AS Balt noted: (it was a product after WWII, of the Ingall’s Shipbuilding of Pascagoula,Ms). They had envisioned it and it’s siblings as a family of railroad engines.
They were to include, 1-S thru 4-S, the only one built was the 4-S. As built, it utilized as a power plant a marine-style engine, bySuperior Diesel& Compressors, @1650 hp with 1500 available hp. It was a speculative style build, and once operational, it was campaigned about the industry. Unfortunately, it languished for some time, until it was sold at a bargain price to the GM&O( around about #140K(?).
They(GM&O) used if for some time inthe Moblie,Al area. At one point, it
About the N&W J. Imagine seeing both the SOU RR PA-4 and a J sitting side by side in Bristol, Happened every evening and if #45 on time about 1730.A very good sight to see.
