I have given ordinary plaster a try as a coating over plaster cloth and found it set too fast, was difficult to control and didn’t care for the surface I got. I’m wondering if there are any recommendations for alternatives?
One example I thought I saw somewhere was someone using drywall mud. This actually sounds attractive since you can buy it already mixed and since I have worked with it to put up drywall, it does seem like it would be easier to work with and smooth and not set up so darn fast as plaster does.
Has anyone worked with drywall mud in this way; other alternatives to suggest?
Drywall mud will crack and crumble unless applied in thin coats. Someone suggested Durams Water Puddy once for thicker applications. I am not sure how thick as I have not used it myself.
I have had the same issue wanting to change a plaster cloth spot on the layout by building it up slightly. I ended up cutting very thin slices of foam with a bread knife and hot gluing it down, I then used Dap to hide the seams.
all I use is drywall mud.Just spread it on , in my case over carved foam, use a wet paint brush to smoth/shape. Can be carved after it starts to set or after it gets hard.Use craft paint to tint color.
It will crack if too thick,but ez to fix, and some cracks look like they belong there.
I’ve used it to landscape,hills ditch banks,roads sidewalks concreat walls and steps,loadingdocks ect. I tryed grade crossing, it will work but take a little messing with, ther are better ways
Its cheap, I think less mess then plaster,if it gets away on you ,setting too fast just sprinkle a little water . try it
Thin coats are all I need, unless you mean paper thin. But rather than go waste money on something thats not going to work, I’m soliciting idea’s for something other than plaster. I did try mixing in baking powder but the plaster still seemed to set up too darn fast. It’s a bit fussy to try to slather on to hill sides and then smooth it down before it’s set up. I tried using a paint brush but the plaster had bristle marks. I really want a smoother surface - some of the vertical parts will be, as geologists call it, “massive” standstone. In otherwords not layered but smooth.
On another forum, one guy said he used something called CelluClay which is offered on Amazon by Activa, the same brand that I got the 5 pound rolls of plaster cloth from. I do like the idea of something like drywall mud; something of that texture might be fairly easy to apply and smooth with a putty knife.
I’ve already got most of the basic land form shapes using the cardboard strips and plaster cloth so I don’t need any foam - just something to coat the plaster cloth to give a smooth surface and hide the plaster cloth.
Uncle Butch, I did have a spray bottle and did try spring water on the plaster to smooth it - that helps a little but ultimately the bulk of it is setting up and then funs over, it’s too late. Spraying water isn’t really enough. I need a layer somewhere from 1/8th to 1/4 inch thick to cover the plaster cloth, mostly 1/8th inch should do it - even less in on some parts.
Tried drywall mud and Like Batman said, put it on too thick and it cracks big time. Have used Sculptamold for smaller areas, works well and with a slower setting time than plaster, but costs more $. Have yet to try, but there are a lot of “ground goop” recipes out there that sound interesting. Mike Confalone uses a mixture of Celluclay, H2O and latex paint to make his “mud” and appears to have a long working time.
Sounds like drywall mud is off the menu assuming what I’m describing is “too thick”. I have a couple 3 lb bags of Sculptamold but was thinking I’d save it for other purposes rather than a broad coating of the plaster cloth.
Someone mentioned Mike Calaphone’s video’s for mud but to see those isn’t that a pay service? Besides, it the CelluClay is a good medium, and it is easier to work with, that may be a viable alternative to plaster if it can be be applied with a smooth texture; longer working time is a big plus.
I have not tried drywall mud, but can suggest Sculptamold. I love this stuff because the texture can be determined by how much water you add and how much you “fold” it with a spatula. Less water and less folding over (like making bread dough), the rougher/more granular the texture. Slightly more water and more mixing gives a very smooth texture. I use water temperature to control setting time. The colder the water, the slower it takes to set. I normally go with warm water and it takes about 5-10 to set firm and overnight to completely dry.
I also use an artist palatet knife to apply the Sculptamold to get very fine control to get thin layers or to add a glob to sculpt into rock formation.
I use 1:1 diluted earth colored flat latex house paint to brush paint the sculptamold. I usually wait until it dries overnight, but I can also paint 20 minutes after application. Not a problem if you are in a hurry.
The best part for me is that Sculptamold is 99% mess free. No nasty drips everywhere and cleanup is a snap with water.
I have this thing about messiness, so I was very happy to find a great way to scenic without any plaster.
Careful layering the mud or be sure and use the lightweight stuff, as it can get heavy fast.
Well, Joel went over similar ground I’ve been over before on Sculptamold.
I’ll just add this time that I’ve also used Celluclay and find Sculptamold generally to be far superior in all around ease of use, workability, and versatility. Where you might find Celluclay better is for those long talus slopes as it can be smoothed a little more easily for what you’re trying to achieve there.
Sculptamold leaves a bit of an oatmeal texture that can be dealt with if you need really smooth, but can take some fussier work and rework. I could take some closeup picks of the results to show as examples. One place that is more 2D is here, where I used gritty texture paint over Sculptamold, another solution to consider in getting those slopes looking right.
In my case these are mostly verticale and yours are much more realistically shaped slopes, but it would look better with more slope to tell you the truth.
I have seen several articles on “Glueshell” using white glue and paper towels. I would think that if your plaster cloth is already in place, you could just spread undiluted glue over it with a brush. If you don’t have the cloth in place, paper towels dipped in glue would work in its place. Not sure what grade of paper towel works best. I have some strong ones I got for nothing, so no need to experiment with store brands.
The one thing I have heard against glueshell is if you live in a very humid climate it may soften occasionally.
Though we usually think of larger quantites being less expensive, a couple of years ago at Wal-Marts Back to School sale, the 4oz bottles of Elmers was cheaper by the ounce than it was in gallon jugs. The other advantage was, once emptied, the smaller bottles can be used for dribbling varying strengths of glue/water mix for scenic work.
You know what might work? Smooth-it from Woodland Scenics. The stuff for building road surfaces? It’s very light plaster. I think much lighter than hydracol and other products mentioned. I would mix 1.5 :1 or 2:1.
Before you give up on the plaster, it sounds like you are mixing it thick and trying to spread it on. What we did back in the hardshell days, which I think would also be good here, is to mix the plaster about the consistency of pancake batter and paint it on with a brush.
I think you may have a problem trying to spread anything like Sculptamold on a first coat of plaster cloth as it would be easy to break through.
Yes. With the situation OP describes, I would apply any material with a brush. If its thick enough to apply with a knife, I think that’s too thick for bare plaster cloth. And using a brush will work smoother and faster, and dry faster, allowing multiple coats to not take a lot of time. Then finish with a knife, perhaps mud, to smooth out the brush marks if there still are any.
Maybe you can apply drywall mud with a knife to fill in or smooth out the plaster brush marks. As another has said, you can use water, a wet brush or knife, to keep the mud soft and smooth enough to work with it a while.
Mostly, I mix Sculptamold at the dry end of the scale, because that shortens drying time and limits moisture working it’s way into other stuff. But mix it wet enough and you could use a brush to apply. If wetter mix, longer to dry, but that’s the only issue I’ve noted. Personally, I’d still gently use a blade, but you’d have to be careful not to punch through the plaster gauze.
Something else occured to me. It sounds like the idea is to brush whatever it is on in vertical fashion. It might work better to start at the bottom with thin horizontal layers, letting each dry in turn as it builds towards the top. That way the entire span of the plaster cloth is not under stress all at once, but little by little. After that is accomplished, the go back over the base with the vertical strokes needed to achieve the long gritty slope. Since these will have a solid base underneath, this should make it easier to form and fashion these as desired.
