Atlas was kind to help me with the electrical short I’m encountering when connecting two Atlas Mark IV #8 turnouts together. They gave me detailed instructions about using a snap relay. Is that necessary for DCC? The Mark IV have non-powered frogs (it says that on the back of their package). How to wire the frogs so they get power? I found that to avoid a short, these turnouts need to get connected together with plastic joiners (yes, I checked with a multi-meter). The issue is there is then no power running through.
All the other layouts are fine since they connect to sidings.
Unless they vastly changed something, there is no need to use plastic joiners with an Atlas Cutsom Line turnout. The rails pass straight through and are unconnected. Like I said - lay 2 pieces of straight track on top of one another, one at an angle to the other, this is an Atlas turnout, the right side rail is the right side rail on all 3 legs, the left side rail is the left side rail on all 3 legs, and never do they touch. The frog is completely isoolated from any rails.
You do not NEED to power them, but as the frog gets longer, the dead zone gets longer and it i more likely that locos will stall when the wheels are on the frog area and it is not powered.
If you get shorts without plastic joiners - you probably have a reverse loop.
I thought we solved this on one of your last threads.
The frog rails, the 2 rails on the normal and diverging route that are next to the frog (red and blue), but separated by a tiny piece of plastic from the frog, should never be the same polarity as each other, out of the box. Nor should there be any continuity with the frog.
I can’t say for certain that there never would be a manufacturing defect that would create continuity, but I think it’s a highly unlikely failure mode. But what you are saying is you have this: ignore that the frog is hot.
For purposes of this discussion, you can ignore all the jumpers and “options”
I never used snap switches, so someone will come forward and tell me if I’m wrong, but they are just DPDT switches, meaning they can change the frog from red to blue and back again. Unless they are linked to some lights on a control panel, you are going to have to remember (every time) to throw them before the loco hits the frog or you will have a short.
It might be time for us to have a look at your track plan where this problem occurs.
Iwould apprecite some seasoned thoughts on the short. The red thumb tac are the locations of the short on the turnout. It might be easier to look at the pictures in a larger size by clicking them.
What makes you think there is a short at that location? The first two photos showing a 0 volt reading? You have both probes touching pieces of the frog that are all one chunk of metal, so there will always be 0 volts there. If you switch to Ohms/Continuity, it should beep with the probes there. The real test would be to touch the frog with one probe, and one of the other rails with the other probe - there should be no continuity and no voltage even with the power turned on.
Makes sense. Regardless of where the probes function, the train won’t move through two turnouts connected together. How to have power carried through the turnouts connected together so a train can go from one turnout to the other in DCC?
As I wrote, the Atlas rep’s suggestion–using a snap relay switch–didn’t make sense for DC.
I really hope those blue and yellow feeder wires aren’t permanent !
I don’t know what you track layout is like beyond both ends of the two switches, but you say you get a short when you connect the two switches together … sure you don’t have a pair of feeders reversed on one side and when you insert the two switches it causes a short ?
Ed. et al: Let me get you a sketch of the layout beyond the track. If many are having trouble with photobucket, what to use instead?
The turnouts don’t form a reverse loop, dog bone or anything that lavish. No question seeing the schematic might help. The challenge is figuring out how to get it out to everyone with photobucket being problematic.
I might just space out the turnouts so there’s some track between them. Thoughts?
Taking pictures from different orientations is the best way to confuse me.
The last two schematics show a point to point layout with DC dual cabs hooked up differently to the same layout.
I believe you are showing us the first and second turnout, where the problem occurs. I do not know where they are in the schematic, but that probably doesn’t matter.
Your problem begins at the frog and is on the straight route through the turnouts. (picture 2)
You would be better off using solid 22 ga wire for feeders. You have strands of wire on top the rails, and a wad of wire that will probably hit the flanges. I try to put most of my feeders on the outside of the rail to avoid that problem. You can also strip more of the wire, so you don’t have to deal with brightly colored wires above the ties.
That’s a long frog, I could see a loco stalling out there, but there should be power after that on the stock and frog rail and then the stock and point rail of the next turnout.
All the advice from this forum was not to use insulated rail joiners and all the advice you have received from outside the forum is to use them. I can’t see a feeder on the rail next to the red push pins. If you’ve installed insulated rail joiners and no feeder, that is a problem.
If the yellow feeder goes to the blue bus underneath the layout, that is a problem.
We have seen people simultaneosly attach DC and DCC to the layout, that’s a problem.
Are you using all those Atlas selector switches, or were they just part of the diagram?
I don’t remember what DCC system you are using, does your command station indicate a short? Are there circuit breakers installed?
Lets standardize on picture 2, with the 2 red pins.
I would start at the bottom and measure voltage from one rail to the other, directly opposite each other and continue on up the picture on the
Not sure what you are trying to accomplish here, but if you are joining two of these turnouts together to form a crossover, and this does not involve a reversing section, then you do not need to separate the two turnouts with plastic insulated rail joiners. Atlas Mark IV turnouts are not power routing, and the dead metal frogs are totally isolated from the adjacent rails.
Trains stopping when crossing a pair of turnouts is probably just no power - with the size of the #8 frog, 2 in a row is probably about the right spacing for the front truck and trailing truck to each be on a (dead) frog at the same time - no power.
Then I’ve sent Kass down the wrong rabbit hole, having read too much into his insistence that plastic joiners were needed.
“Won’t run through the turnout” may mean exactly the scenario Randy describes, or it may mean what I thought: it doesn’t run anywhere between the two red pins.
Kass does won’t run mean it stalls and starts as wheels hit then clear the frogs?
Moving on to powering the frogs, how are you throwing the turnouts? Atlas switch machines?
I’m coming to this party a bit late, but I do have first hand knowledge of the Atlas 8s. I installed eight of them to complete 4 crossovers on my HO DCC layout. The “8s” are outstanding and I was thrilled when Atlas came out with them.
However, as the frog is not powered, slow moving locos would often stop on them. Some continued on, but the sound would go thru a “reboot”.
The answer was the Atlas snap relay, and I wired one relay to each pair. That solved the problem, and as the installation was ten years ago they have stood the test of time.
One added “bonus” to this is that a train will come to a sudden stop if the turnout is sitting in the wrong direction. So this means that when the operator forgets to flip the turnout, he will end up with a stopped train, rather than a string of derailed locos and cars…
One more thing…all my previous HO layouts were DC. While DC locos tend to be less sensitive than DCC locos, some would still stop at the dead frog.
