OK maybe I am the last person on earth to know about this website but this last weekend an avid trolley modeler I know informed me of a website I never heard of
http://www.pacificlocomotive.com/index.html
It is hard to describe what this outfit does but basically they use modern computer technolog to create castings made to order.
Here is their description in their own words, minus the photos which are mostly of steam locomotive drivers.
Pacific Locomotive Works can custom make you any kind of casting for your model train, plane, boat or automobile. We produce them on the lost-wax process by building them on a wax-based 3-D printer. First, you must have some idea of what you want, in this case, an O-Scale model train wheel of the 80" Baldwin Disk…
We then build the model in the computer using a 3-D modeler such as SolidWorks, Mechanical Desktop or Pro/E. The model is exported as an .STL file…
We load the model onto the 3-D printer, and adjust the resolution of the slices it builds with, in this case, 0.0005". Yes, that is five ten-thousanths of an inch per layer. WHat we get is this…
Finally, the wax models are sent to one of our foundries for casting, in this case it is cast of brass…
Forgive the surface texture, the digital camera is unforgiving!
Here is an inside view of our SolidScape T-66 3-D printer. This machine was originally designed for the custom jewelry market. The machine uses different types of wax to build the models layer by layer. The red wax is used just to support the model, the green wax is what the model is actually made of. The machine has a resolution of 0.0005", which is pretty fine. You will need a resolution of less than 0.001" for jewelry or any scale models.
Final castings for 80" PRR K-4s spokes wheels. Notice how fine the castings are, and they are also scale. The surface of the hub and counterweights are slightly rough, as they are the firs
