Folks:
There are a LOT of good motors that cost very little.
The Helix Humper motors are automotive can motors, which see a lot of use powering rear-view mirrors and stuff like that. You can buy motors that seem virtually identical from Jameco for very cheap…about $2 or so. These are very good quality motors, which have been thoroughly tested and used by this guy:
http://www.geocities.com/budb3/arts/xmpl/bwb6.html (Example)
http://www.geocities.com/budb3/arts/motor/stltrq.html (Evaluation, note the listing for one of the Jameco motors in the table.)
Jameco listing of the motor in question:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=231731&
It’s well worth browsing their catalog…they’re a good source of other components, too.
Don’t knock tape deck motors 'til you’ve tried 'em, either. They can be very good, reliable, strong, and quiet motors. Nobody with a mechanical bent should let a broken piece of machinery with potentially useful parts hit the trash can unsalvaged.
VCRs are an especially good source of motors.
Another good, dirt-cheap method is simply to disassemble an old, tired open-frame motor, make sure its bearings are decent, give it a good clean & lube, and replace the magnet with a NdFeb cube or stack of bars. You can do this for the cost of your free labor, a bit of oil, and perhaps $1-$2 for the magnet, and no need to change any drives or mounts. It’s about as close to a free lunch as you can get in this department. I don’t trust free lunches either, but when the risk is $2, I’d say it’s worth a shot. Remember, a “can motor” is just that…a motor in a can. There’s nothing magic about a can. It just holds beans. If they’re good beans, they’d be good outside the can, too.
