Hi everyone. I’m a bit of a newbie to O gauge or at least 3 rail so please be sympathetic! I’ve imported a few Lionel Thomas sets into Britain for my wifes business (all Thomas the Tank engine!) The G scale sets were great and we were really impressed with the O gauge sets at first. Our problem was the CW80. I know there is a lot already written about it but our big problem was neither it or the trains like operating at 50hz (european voltage frequency). Basically the CW80 melts down as soon as it is connected to 110volts at 50hz( through a voltage converter from 220volts). 3 rail O gauge seems pretty rare here and the only importer in England throws the CW80’s in the bin as soon as they arrive in each set. Most european dealers seem to favour trying to use a 50hz 18 volt supply available here and then try and find a controller.
My big question is -does anyone know if Lionel trains use DC motors in the AC trains. It would seem much easier to simply remove the circuit board in the loco and then use a European G scale supply (LGB or similar), and bypass the wiring from the pick-ups straight to the motor?
Apparently if the trains are run on 50hz 16volts AC they will eventually burn out the control board anyway. It means losing the whistle/horn but at least it may work.
Has anyone seen a locomotive damaged by 50 hertz? I think one would have to go out of his way to build one that would run on 60 hertz but fail on 50. Lionel once sold transformers for 60, 50, 40, and 25 hertz, as well as exceedingly dangerous DC reducers.
In any case, you should be okay just running the motors directly on DC. You can even do this with wound-field universal motors with very little modification. An advantage is that the units of a multiple-unit lashup will not get out of sync with each other. A disadvantage is that, with 3 rails unlike 2 rails, you can’t turn a unit around without making it run in the other direction.
I’d have to concede that of the trains I have had start to show problems with 50hz , all of them have also at some time been run with no modification on DC. Even if they only ran for a few seconds I suppose they are as likely to be damaged by that as 50hz AC for a long time!
I may try and wire one up, bypassing the board to put DC straight into the motor this weekend.
Any Märklin transformer does a fine job running Lionel trains. The engine will not suffer any damage if it’s controlled by 50Hz AC and Märklin stuff is pretty common in Europe. The only thing not working on 50Hz AC is the TMCC Lionel uses in it’s digitally controlled trains.
There are other ways to get 110 volts 60Hz AC, you need a 220 to 12 volts DC transformer and then a 12 volts DC to 110 volts AC convertor. That convertor can give 60Hz but it’s not a sine wave, since electronically reproduced. I have this information from another Lionel fan in the UK, so don’t bite me if it doesn’t work…[:D]
Also whistle and bell controllers, MTH’s Z750, Z1000 and Z4000, Lionels postwar and new ZW’s will work fine behind a 220-110 volts transformer on 50Hz. (in series with the transformer that comes with the controller) But Märklin 32 VA transformers also work without problems (and are dirtcheap to get on almost any trainshow)
On a märklin tranformer, MTH Protosound 1 and 2 work, Locosound works, any conventional Lionel runs (with or without railsounds), without damage or any other problems.
On my layout, 2 32VA Märklin units with additional whistle and bell controllers and a momentum break switch for the direction (not necessary, but easier to work with) are doing a fine yob since 4 years without ANY electronical or mechanical faillure.
So my advise is: use the CW80 as a paperweight and get some decent (postwar) Märklin stuff to power your train. My next solution will be a controller (Z750, shipped without the transformer belonging to it, since it’s useless here) with a normal 3 amp 220-18 volt transformer from Conrad.
He runs his universal-motor trains on DC using the e-unit for reversing. If you’re interested, I can tell you how to convert those entirely to DC, with no reversing unit and the direction controlled entirely by the polarity.
Lionel’s reversing scheme is however very different from Maerklin’s. Instead of a high-voltage pulse, Lionel shuts the track voltage off. Obviously you can do that just as well with a Maerklin transformer too.
I thought of Brien right away too - hopefully he will chime in. How do you connect a DC transformer to 3 rail track - Could I try this with an unmodified engine, I wonder - just to try it?
You certainly could with a traditional locomotive, as long as you don’t mind the whistle’s (if any) blowing continuously. I hesitate to say the same about a modern one (since there may be a CW80 of locomotives out there), but I would bet you can.
Kenny, you’re new to the forum and maybe new to the hobby so on both accounts welcome.
I run mostly the cheaper mid-1980’s to mid-1990’s K-Line and Lionel locos. Many of these diesels did not come with horns. And the ones that did, well those horns leave loads to be desired. All of these locos came with truck mounted DC can motors, and have a natural tendency to “growl” if they have dual DC motors. Single motored diesels and steam locos do not make this noise.
It was this noise element, that by accident I started messing around with DC power. I now run my whole layout on rectified DC current from a normal Lionel 1033 transformer, the best one Lionel has ever made IMHO. I do pull the circuit boards out of the locos and rewire them as you mentioned. The DC can motored diesels with dual motors DO run much smoother, more constistanly speed wise on curves and run quieter.
There are plusses and minuses to everything. Losing the circuit board on smaller diesels like the mid-1990’s issued Lionel Industrial Swithcers allowed me to add a lot more weight, so now these little guys can pull almost as good as anything else… I’ve had them pull as many as 25 cars, but 8-12 cars are zero problem for them now. I don’t like the cheap diesel horns, and I don’t mind off-board sound… on a small layout you don’t notice as much anyways. I rewired a Lionel steam whistle from a tender into a Plasticville Hobo Shack and I have my own custom made diesel horn. Plus I have the MRC 312 Sound Station which I wired additional speakers into, so I have plenty of sounds. I don’t and will never run TMCC or DCS, so that wasn’t even a consideration. If TMCC equipped locos become the same price level as normal locos, and the system itself drops significantly in price, I might consider. But given Lionel’s history, that will never ever happen.
I have too many problems with the computer I am sitting at to ever be interested in having computers on my train layout. And cont
Out of the box, Lionel trains will run on DC but in many cases the horns or whistles will blow continuously. They need to be disconnected.
Many of the new Lionel engines come with DC can motors and the incoming AC current is rectified to DC at the reverse board. You can eliminate the AC reverse board and re-wire the DC motors so they draw DC current directly from the track. By doing this your engines will work off a DC power pack just like your G scale trains. You reverse the engine’s direction by reversing the polarity at the pack. This will also allow multi engine lashups as track polarity controls engine direction. You will need a large DC pack for this as 3 rail trains draw a lot of amps. This set-up won’t work with horns and whistles.
Lionel also uses what many call AC motors. As others say these can run on AC or DC and are really called universal motors or field wound motors. Engines still require reverse boards whether you are running AC or DC. You cannot reverse their direction by reversing the polarity at the power pack.
My preference would be to use an old postwar transformer without the electronics plugged into a european inverter.
Roughly speaking and as far as I know, in Europe you will find two types of Lionel operators. Those that use Märklin transformers and some buttons to operate horns and whistles. And those that do that regenerate 110 V, 60 Hz at home and use that as feedstock for CW80 transformers.
Since, I predominantly run pre-war trains and MPC-era trains, I simply use a Märklin transformer, much in the way Daan described.
If you would be interested in generating 110 V, 60 Hz at home, you have to read earlier posts of Nick12DMC on this forum or to get an earlier copy of Shorttrack. This is the club journal of the Lionel collectors club UK ( http://www.fastnet.co.uk/lionelclubuk/ ), which I happen to be a member of as well. Both sources are written by the same person (Nick) and give the same information.
So far, I never met a Lionel-operator in Europe that runs the trains on DC current, but as I understand of the good explanation of Brianel, this should be possible as well.
Have fun and perhaps you would like to visit the annual Lionel train shows in Ilkley once.
"There are other ways to get 110 volts 60Hz AC, you need a 220 to 12 volts DC transformer and then a 12 volts DC to 110 volts AC convertor. That convertor can give 60Hz but it’s not a sine wave, since electronically reproduced. I have this information from another Lionel fan in the UK, so don’t bite me if it doesn’t work… "
It can be Pure Sine Wave if you use a Pure Sine Inverter. [;)]I recomend only using pure sine inverters in the above set-up.
Hi Kenny,
The Inverter set-up as discribed costs around £140 this gives you 300 Watts of US spec. 110V 60Hz AC power. If you use a Pure sine wave inverter this is of the same or better quality than you would get from a US wall outlet. This works a CW-80 with ease. I run a 275Watt ZW from mine with no problems. A 18V AC UK spec power unit is £100 and another £50 for a MTH controller and you still won’t solve the 60hz issue. All round its better and cheaper just to go with the Inverter. You could get the price down to around £115 if you got the 150 watt pure sine inverter which would still have ample power for CW-80.
50Hz does seem to fry the CW-80’s circuits. The continuous whistle and bell sounds are the instant clue your using 50Hz. The fan packing up appears to be the next sign of serious problems.
My guess is (and is just that, a guess) that the more modern Lionel items have not allowed for running on 50Hz power. When several Club members switched to the Inverter set-up it was noted that a lot of things ran quieter and cooler on 60Hz. This may increase there operating life.
Along with the CW-80 other Lionel items that have known 50Hz problems are Trainsounds and certain TMCC board versions. All these need 60Hz to work correctly.
The Pure sine inverter solves all these problems and
The only reason I can emagine having problems on 50Hz would be if the power inside the locomotive electronic e-unit and sound board is not sufficiently flattened out after rectifying. Almost everything inside the modern engines works on DC, sound systems, couplers and motors.
If they run hot or don’t function properly I guess replacing the capicitor behind the rectifier unit for a bigger type will eliminate that problem. In DC it doesn’t matter if you run on 50Hz or 60Hz as long as the capicitor flattens out the dips and peaks behind the rectifier bridge it should be ok. I don’t have railsounds yet, but one is under way from the usa. I’ll see how it works, but since a 9 volt battery can be placed to keep up the power while changing direction, I guess problems with it will vanish as soon as the battery is placed. There is no better way to flatten out DC current then a battery (big capicitor).
TMCC gives problems because it depends on a radio signal to give signals, as far as I know 50Hz interferres with that. But with none of my locomotives I had any problem on 50Hz, and I run with MTH with and without protosounds, Williams, Lionel and K-line.
I however had to place a 5 watt 20 volt light in parallel to the tracks (I found out that it had a good effect on the protosound units). No problems with running hot or electronics acting up. I’ll see how the railsound train will work and see if I can tackle the (possible) problems with it.
“Lionel also uses what many call AC motors. As others say these can run on AC or DC and are really called universal motors or field wound motors. Engines still require reverse boards whether you are running AC or DC. You cannot reverse their direction by reversing the polarity at the power pack.”
Not quite true if you’re willing to do a minimal modification. A bridge rectifier in place of the e-unit to rectify only the armature voltage will make a universal motor sensitive to the DC polarity so that it can be reversed that way–whereupon it can no longer be called a “universal” motor.
“What also could be a problem is the lower overall voltage if 60Hz is converted to DC. The same voltage on 50Hz DC will be 1/6th higher after rectifying it.”
I don’t think so, Daan. If you’re using it full-wave, the average rectified voltage is the same for the same RMS voltage in at either frequency. If you’re using a big capacitor to get rid of the ripple, the peak rectified voltage is also the same. Only if you use some capacitance but not enough completely to eliminate the ripple will the voltage vary with the frequency, but the other way around–less ripple at 60 hertz.
Don’t forget that Trainsounds is a diffrent system to Railsounds. Railsounds has the battery which as you say makes the system more likely to be fine on 50Hz (I don’t have any Railsound items ether). Trainsounds uses AC track power and has no battery hook up provided. Trainsounds malfuntions on 50Hz and the symptoms are the same as for the CW-80.
Note that I am just talking about Lionel. MTH equipment is a whole diffrent ball game. They have taken power frequency into account in their designs. DCS has a switchable 50Hz mode. You should have few problems with these.
My thought on the whole 50Hz issue is not to try and convert or replace any Lionel equipment. Lionel power supplies are so much cheaper and higher powered than the UK replacement. That £100 unit I mentioned is only 5 amp and is custom made for the UK dealer. Lionel 135 Watt Power House ( around 7 amps) is about £30. The saving on buying two just paid for your inverter and you have more power and you can run anything as intended, no nasty surprises when items arrive in the mail and don’t work. Try explaning this to children for example.
The nice thing about the inverter is its pretty simple to set up (two wires and a earth connection) and is plug and play. This does not put off newbies.
hobbes You should be able to find a voltage convertor to take you 220 to 110 @ 60hz. I have a universal travel charger that will do just that. I don’t know if Radio Shack still has them but you should be able to find an appropriate one at a travel store. Check to see what the output is. Some of them are only for small electronic devices, but there are ones for high power consumption and motor operation.
cnw1995 I used a Tech II DC transformer to test engines, One terminal goes to the outside rails, the outher to the inside. Works quite well. It’s a much lighter transformer to carry around in case you want to test things at train shows.
By reading it from a voltmeter there is no difference. But a voltmeter rectifies and equals first before the reading is made. The peaks on 50 Hz are bigger with a more gentle sinus wave, where 60Hz has lower peaks but faster angles on the sinus wave. It doesn’t matter to the reading of your voltmeter, but it could make a difference in electronics. It’s like comparing a bigger bore engine on low revs to a smaller engine on high revs giving both the same amounts of power, but on different ways. (reading the reply you refer to over I see the nonsense in it by the way… that only excists in a bridge rectifier without any capicitor behind it and all boards have capicitors…)
What matters is what happens in the electronics with it, and one of the things that could happen is that the capicitor fails to even out the ripples on 50Hz. If that’s the case, electronics don’t like that and will run hot. (but I doubt it’s that simple)
Anyway, back to the base. If you want to run a basic Lionel starter set with only a horn (or whistle) on a layout, what is cheapest and what works. Märklin transformers (the 32 VA version) is on swapmeets for about 15 euro’s here. It works, but as soon as you want to go TMCC or Trainsound, you can get the nice setup wich is mentioned before. It gives pure sine wave 60Hz @ 300 watts. Power enough for a european size layout.
The fun part about both solutions is that you can interchange whenever you like. You don’t need to buy the nice (and
Those small voltage converters are step-down transformers. They only alter the voltage. Remember this important rule: Transformers do no alter frequency. If you put 50Hz in you get 50Hz out.
If someone has made a frequency converter that is the same size as a voltage converter they will soon be making pots of money![8D]
