I have a RS2 loco proto 1000 new I converted it over to dcc installing a digitrak dh126 decoder now the problem it has no speed or pulling power do I have the wrong decoder or do I need to change a setting and if it is a setting where would I start. I also have a digitrak 100 system.
Can you give us some more information? Do you mean the loco doesn’t move or only moves very slow? when you say it has no pulling power do you mean the wheels turn but the loco won’t pull the train? Or do you mean when you hook cars up I’d just sits there? Of do you mean that it can only pull two or three cars? Did you remove weights to make room for the decoder? Can you read the current CV settings?
I’m no DCC wizard but those on this forum that are will probably want to know this information.
If you did the decoder install yourself, you might want to check to see if any of the track pickup wires or one of the wires from the decoder is binding the drive wheels.
The older Proto RS2s wth the Athearn style drive had the very commmon split gear problem be sure that is not the issue. All 6 of my RS2s those had that problem.If this is a newer Walthers drive it shouldn’t be an issue.
I agree with Tom on checking binded up fly wheels.
I did a similar conversion (Tsunami inside a proto 1000 RS2). I also had issues similar to yours. A 5 minute diagnostic told me the decoder was pressing on the fly wheel preventing free movement. Try running it with the shell removed and see if that fixes your problem.
The space is a little cramped in there. I recommend the cab as a potential decoder install point.
Once you get it installed though, that little RS2 will be smooth as butter and run day and night for you. They are among my favorite (and I’m a steam guy!)
I removed the motor and hooked a dc transformer motor ran fine no load. I am running with the shell off the loco moves slowly at full throttle when two or three cars are attached it sits there I push It it will start to move then stop. After reading what everyone as written I’m thinking removing the wheels and hook wires to the pickups see what happens what do you guys think.
Thanks again
I’d remove the decoder orange and grey and hook the rails back to motor and see if it works in DC mode. If it works OK on DC then you know that it’s a decoder problem.
Mel
Check this out George. It’s for a TCS decoder, but the brand of decoder doesn’t matter. There are 3 traces you have to cut on the board, and decoder wires are soldered to the board.
