Could steam make a comeback?
Hi everybody, please forgive me if this has been asked already( i looked in the search area and did not see it) or is kinda dumb, what i am wondering is this, with the price of oil going up so much, the fact that we have a buttload of coal in this country, and also the fact that steel is much better now and so are manufacturing techniques would it be possible or feasible for steam locomotives to make economic sense? please let me know your thoughts on this, thanks much.
No, Way too labor intinsive.
And yes, we beat this topic to death way too often.[;)]
…Yes, the topic has been kicked around all over the place.
As an outsider, I believe a modern steam engine of value could be designed and built. One that could provide 21th century performance. But…at what cost…and who would pay for it…and how much labor and facilities would have to be available to support it…???
As mentioned above, we have more modern materials now and advanced production processes maybe not possible in the last century…and some of that might make a difference.
Might have to have it built {if design and testing were successful}, overseas somewhere…We seem to have given up on most heavy manufacturing here in this country.
Electric is probably much more efficient per BTU especially using regenerative braking.
…I see the price of gasoline continues to escalate…Within the past several hours I noted gasoline has risen to $3.29 now. And yes, I know it’s higher in some parts of the country, but this is starting to reach up and onward.
By the spring traveling time, who knows how far it’s headed up…Crude is again setting records today. Perhaps it is time to really have some major talks in this country which direction we need to go…More oil…develop alternative sources of energy, but start getting serious and get the discussions rolling.
Absolutely not. The labor, environmental, fuel, and operating costs are stratospheric. There is no magic technology waiting in the wings that will make steam locomotives, reciprocating or turbine, cost-effective with either synthetic diesel fuel or electrification. It is far cheaper to either burn the coal to generate steam in a generating station and electrify railroads, or gasify the coal to make diesel fuel in a Fischer-Tropsch process. Several large-scale F-T plant to produce diesel fuel are in design at this time; they are competitive with conventional diesel fuel at $80/barrel.
RWM
…We will, {this time}, have to see some change in energy type and sources.
Our far eastern “friends” don’t seem to mind the escalating crude costs now…According to them, no use to pump more.
Something will have to be done different…Believe we might be entering an era when those thoughts will start to emerge as something we now have to do.
Well, I don’t know about fuel costs being stratospheric. At $60/ton 11,500 BTU coal, and at $3.65 per gallon diesel (last week’s U.S. average), adjusted for 6% efficiency coal, 32% efficiency diesel, the current adjusted cost for 100,000 BTUs of coal is $4.35 and the equivalent cost of 100,000 BTUs of diesel is $8.21.
Wyoming coal, of course, sells for considerably less than $60/ton, running between $10 and $15 per ton. The U.S. average is only $25/ton. The average delivered price in the U.S. varies from $14/ton in Montana to $84/ton in Massachusetts, with the U.S. average at about $42. At power plants, it averages $35/ton; for other uses, about $52/ton.
At the U.S. average delivered cost, the BTU equivalent cost of coal is $3.04 vs. $8.21 for diesel fuel. In places like Montana, delivered cost would price equivalent coal at $1.01 compared to the $8.21 cost of diesel fuel.
The following is from a student paper which looks at the issue in some detail:
“A coal-fueled locomotive could achieve a 64.2% average cost savings over the current petroleum diesel-fueled locomotive. This comparison is based on ton-miles per dollar of fuel consumed in calendar year 2006. US Class I railroads burned 4.2 billion gallons of diesel fuel in 2006, costing $8.1 billion. The dollar value of coal that would accomplish the same amount of “work” is only $3.0 billion, according to calculations. This is a cost savings of $5.1 billion in the single year of 2006. That is an incredible cost savings over the use of diesel fuel, which is largely imported, compared to coal, which is mined locally in the US. Those 4.2 billion gallons of diesel fuel comprise 6.6% of the nation’s diesel fuel use. That quantity of diesel fuel could be replaced by 72.3 million tons of coal, equivalent to only 6.2% of the 1.16 billion ton yearly production of coal.”
I don’t think Wyoming coal would be very useful in a locomotive, though. IIRC, the Boone & Scenic Valley got a free load of Powder River coal several years back when the CNW had to empty a coal gon to repair it. I seem to recall that it wouldn’t burn even when mixed with their standard coal.
Don’t the power plants using Powder River coal have to grind it almost to a powdery consistency to use it?
As per the original question, another added cost would be track maintenance. When Ross Rowland did the ACE 3000 project back in the 80s, didn’t they find out that steam locomotives really did beat up the track when compared to diesels?
…Chris…a modern design may not include the “pounding” action of rods powering driving wheels with counter weights.
The Northern Pacific Railway burned a lot of Powder River Basin coal in the long course of its eventful history.
It is certainly possible to build a steam power system with an efficiency equal to that of a diesel engine. It is simply a matter of getting the steam pressure high enough so the temperatures are high enough, and then off you go. Do it all the time in big central power stations. However… in a railroad environment? Well, in a sense, yes: both the Delaware & Hudson in the US and the French (Chapelon) built steam locomotives with amazingly high efficiencies. In both cases, the maintenance question ended the experiment rather abruptly: you have to get upwards of 900 psi to get the efficiency you are looking for, and that means compounding – at least double and preferably triple expansion or turbines (and NOT gas turbines; steam turbines – there is a world of difference).
So… probably not. On an overall cost basis, the diesel is going to win. In fact, it is not possible to justify the cost of electrification these days, either, even on really heavily travelled freight lines (the Sunset or Transcon come to mind). The electrification cost balance could change, though, as the cost of oil goes up – provided the cost of electricity does not. But that is a whole 'nother ball game.
The question, though, seems to be getting confused with the question of could coal replace oil and make a comeback? Different question. Same answer, though, but with somewhat different reasons. Coal can’t be burned directly in a gas turbine (it’s been tried, and the results were lamentable). It can be burned in a gas turbine or combined cycle if it’s gassified first, but that is not practical, in my judgement, on a railway locomotive. Thus it has to be in a steam boiler, and see above. Second, even if you could, the emissions from coal burning are much harder to clean up than those from oil – and carting the necessary anti-pollution equipment around just isn’t feasible.
So… Sorry guys, I don’t th
Didn’t they require special fireboxes for burning the low BTU stuff (Belpair fireboxes ?)
True, but would we really be witnessing the “return of steam?” If we were to see steam driven turbine locomotives or steam turbine electrics, would it be steam as railfans know it?
On that note, wouldn’t coal gassification as RWM brought up be a better route for such locomotives? It seems like adding the step of boiling water to the process of converting chemical energy into mechanical energy is just a way to lessen efficiencies to me…
Interesting. Were there special fireboxes or other changes made to accomodate the PRB coal?
…I suppose that would be the job of experts, that is…to design a powering unit, with some different energy source other than oil to do a 21st century job of powering our railroads. Whether of steam or other designs. Guess that would be the question at hand.
And you are probably right…A “new” steam engine you and I would like as “fans” may not be the end result of the designers.
Virtually all of the studies I have seen from the transition era show that the costs of track maintenance increased, albeit slightly, as a result of dieselization; even as investment in track maintenance declined as a result of the costs of dieselization.
But why?
At the current U.S. average delivered cost, coal already would enjoy a 2.7:1 price advantage over the current cost of diesel fuel, adjusted to the same BTU output at 6% efficiency.
If a company could justify the cost of the technology, at 32% efficiency coal would enjoy an adjusted 14:1 advantage in price.
Take your pick, I guess.
Larger fireboxes. What else they might have done, I do not know.
What would cause an increase in track maintenance for dieselization? In addition to the pounding that a reciprocating steam locomotive can deliver, later steam locomotives featured some very long wheelbases that must have been real rail straighteners. Is it a result of higher weight per axle, or something along those lines?
