As some of you may know, I rather want to manufacture model trains and sell them for very inexpensive pricing, for which I was roundly ridiculed. Having had done one of my typical things (that is, ignored said ridiculing), I am continuing to come up with ideas. One is for transformers–I aim to have a complete product line of O Gauge supplies, after all. So, to start with, here’s why I don’t like the transformers available from other sources.
Lionel: Expensive, and produces a chopped sine wave. Yuck. Prices range from $195.99 for an 80-watter to only $999.99 for a top-o’-da-line 620 watt transformer, plus they also have junky DC wall-warts. Any pure DC source is immediately disqualified, as that does diddly-squat to run vintage trains. Especially if it has no voltage control, as that does doubly nothing.
MTH: Seemingly nothing on their useless website. Plus, chopped sine waves (though better ones) on the stuff that is hanging around used.
MRC: AC? What AC? Moving on…
Menards: DC wall-wart. No! No! No!
Used: Good stuff, but no way can I sell it with new trains.
So, that leaves me with no option but to manufacture the transformers myself. Too, there is another issue: Large transformers suck. They’re neat, but they are too inflexible. A modular system would be much more useful: 100-watt transformers (with no voltage controls, just 18 fixed real AC volts and nothing more), control modules, and the like. Let me outline my plan:
Power Transformers: Convert 120VAC into 18VAC, with a rating of 100 watts. Will feature a circuit breaker, pilot light, and an on/off switch. What else do you need? They are designed to be connected in parallel, so that we only need to offer one transformer. The transformer itself can be purchased from Mouser for less than $20, the circuit breaker, light, switch, case, and other hardware will be inexpensive. Guesstimated Retail Cost: $50.
Control Modules: Fully separate modules designed to be wired in series with a power transformer. There will be multiple control modules available. Diesel Control Module (DCM): Features a notched controller to simulate that of a real diesel locomotive, a direction lever, a horn/whistle button, and a bell button. Capable of handling 10 amps. Steam Control Module (SCM): Same as DCM, but throttle is not notched and has more speed steps (how does 16 sound?). Voltage Control Module (VCM): Just a throttle, which is notched and drops the voltage by 3/4s of a volt every notch. It can be used to limit the output voltage of the locomotive control modules (for example, to just 16.5 volts so that no locomotives go around the curves at Mach Stupid), to provide a conveniently-limited voltage to accessories or the like, or even just to run something like a trolley.
This single transformer and these three control modules are the basis of the system. However, here’s the real question that I struggled with for a very long time. How do I control the voltage? The ideal solution would be a variable transformer, just like Lionel made up until they switched over to abominable systems using various forms of chopped sine waves. Sadly, there don’t appear to be any applicable variable transformers for sale, and, worse, they would be exorbitantly expensive to manufacture from scratch. Excepting outsourcing, which I would like to avoid for a variety of reasons, then, a true variable transformer is not practical. Of course, the simplest method would be a cheap-cheap rheostat, but I do not want to use a rheostat. That would cause a lot of issues. So, what other simple ways are there to have an consistent, controllable voltage drop? Since this is AC, what about diode drop? By using a rotary switch and a bank of diodes, I could keep a true sine wave, have a consistent voltage drop, and it would not be expensive. For the switch, I could either purchase a standard notched one, or I could make a switch myself–which would be much more practical for the SCM, while the DCM could probably use a pre-made switch. The VCM would probably also have to have an in-house switch. There would also be a little slide-switch on the back of both the DCM and the SCM, which would prevent turning off power when the throttle is notched down to zero. The reverse lever still would turn it off, though. In this way those control modules would function like the deadman’s handle on old American Flyer transformers.
What do you all think?
