I heard you mention 100 ohm before. I think I have a bunch of those. I’m not going to disect it to find out which decoder, as I’m having a bad day with fixing things. I’ll include a resistor when I set up my programming track.
I have a crapload of decoders, I may just switch the wierd one out.
So what do you guys think is causing the wierdness with AD4 addresses? It’s like my DT400 is not recognizing the Y+ button. This happened on a variety of decoders and I have programmed all these decoders before. I was just forced to renumber because I failed to write down the numbers I had previously assigned.
Well, had you left all the short addresses as 3, and made the long addresses the number on the side of the cab, you wouldn’t have had this memory issue.
