another ? from someone of little ex in dcc .still looking at starter systems and like the two locco knobs on dt400 so ? is how long is the tether or cord on the 400 ,cant find that info any where. still thinking of a zepher plus a 400 but for a few bucks more could get chief /dt400 included…but cant find the lenth of the cord ?..Jerry
Jerry,
I just measured the cable on my DT400, it’s seven feet long. Remember, though, that you’re not limited to that length. You can put UP5’s wherever you need them.
Steve
Cord on wired throttle is about 7 feet long. Cord on a DT400R adio is less than 1 foot long. Besides adding UP5 panels, an extension able can be used. You will need at least a 4 conductor cord and coupler. Plan ti always have a good battery installed if using 4 wires.
6 conductors would be ideal. Radio shack and wall mart sell them. They are telco style wired pin 1 to pin 6) but that’s OK if it’s being used to extend a throttle cable.
Martin Myers
thanks ,Very helpfull…Jerry
DT400 + Zephyr = 5 amp super chief set in cost.
Almost. At list prices, the Zephyr + DT400 would be about $379 vs $449 list for the Super Chief. But you also have to add the power suppyl for the Chief, $50 list. So the actual difference is about $120 to add 2.5 more amps, 120 loco/throttle capacity, and routes.
The other difference is that the Zephyr has it’s own throttle (with a neat “brake” feature), plus the two jump ports. So if you go for the Z plus DT400 (plus two DC throttlepacks), you can control up to 5 trains at the same time. With the Chief set, you can only control two (without buying more DCC throttles).
Paul A. Cutler III
Weather Or No Go New Haven
Most people can usually manage one or two trains without problems. If there is a operating session extra throttles usually are brought in by others or bought rather cheaply on Ebay.
DT400’s F7 airbrake procedure works well once it is set up, just need several cv’s to be adjusted to make it work.
Finally but not last, the 5 Amp Chief has the horses to program power thirsty QSI engines in my stable.
Both systems are prefectly fine, it may have to come down to actually picking up either one and trying it out for yourself before buying. Such test drives sometimes hammer out choices.
Thanks for info,but whats this mean “chief has enough power for my power thursty Qsi loccos” im thiking of some qsi sound decoders is this something I need to consider before I PICK a system ? …please explane …thanks Jerry
I have not noticed any issues programming engines from a system such as mine with adequate power.
Some other systems may experience a need to have a booster installed to the program track to feed the Factory QSI decoder/sound units during programming, if any. My situation sometimes gets extreme when you have 4 F7’s in ABBA formation sitting on the track at once. As far as Im concerned, they are considered one engine.
Some DCC control systems are so basic as to be ineffective and not worth considering.
I have experienced engines that really are terrible at recall. Program them and they “Brick-out” or forget everything a few minutes later.
It all depens on how many you intend to run at the same time. An old Blue Box Atheran loco typically draws more power than a QSI equipped Broadway Limited loco. Check the spec boxes in the Model Railroad reviews and note the max slipping current and max stall current of the various brands of locos they’ve tested that have QSI decoders in them. Most have stall currents of about half an amp.
There seems to be some thought that if you put a sound decoder in a loco it MUST draw a relatively huge amount of current. The electronics don’t draw much power, and it doesn’t take a lot of power to make a small speaker loud. Plus these decoders are mainly in new and relatively high quality locos which have good motors.
The issue of programming a sound decoder is independent of the ability to actually run them. Some sound decoders have a rather large capacitor in them, to keep the sounds going over dead spots (where the motor can coast over via the flywheel - but the sound would stop instantly if not for the capacitor). The problem is, a capacitor appears as essentially a short circuit until it is fully charged. The program track of a DCC system does NOT have voltage to the rails constantly liek the runnign track - it only gets power when the pulses are sent to send programming information to the decoder. On many sound decoders, the capacitor causes those pulses to be totally missed by the decoder electronics, thus they can’t be programmed on the programming track. The Tony’s PowerPx or Soundtraxx PTB-100 boost the power to the programming track to overcome this. IMO, leavign oen of these on all the time is not a good idea. Part of the benefit of the low power ont he program track is that it is generally too low to damage a miswired decoder - when you install a new decoder, you should test it first ont he program track - if you can;t program it, it’s probably not wired correctly, and placing in on the runnign track will probably damage it. If
OR…use a DB150 to program. I wonder why everyone misses this unit when they are talking about programming issues? Beyond me.
A DB150 coupled to a computer is more powerful than any other DCC system in terms of programming. It will program ANY decoder (regardless of make or soundage) the FIRST time EVERY time.
However, it lacks CV read back. That is why God invented computers and JMRI where you can create a profile for your locomotive. Easy.
David B
I agree, JMRI with a DB150 to pound CV’s into a engine is a very easy way to do things these days.
But once in a while I will have the chief over on the layout “Ask” for a cv readback but not too often.
Profiles are kept one to each engine sorted by road number. Once you have the little things all nicely programmed and written to the engine, your profile stays on the computer. Should you need a reset, simply place the engine onto the JMRI track, hit “Write all sheets” off the profile and go get some coffee.
My problem is keeping the specific engines apart in the profile. The JMRI likes to lump everything to just one profile. Must be my error in trying to assign a profile title to seperate all the engines by cab number.
I will type in “CP Rail GP38 3015”. That way I track it by Road, type, then number. Of course with cusomer units I type in “John Doe CPR GP30 5000”.
David B
You can control more then 2 trains with the Chief set or any other Digitrax system for that matter with only one throttle. All you need to do is punch in the address of the train you want to control using what ever throttle you have. I regularly control 4 separate trains with my clubs DB150 and a DT400 throttle at train shows. Sometimes it makes for some interesting “situations”, lol.
One can control up to 120 trains on a Chief sytem with one DT400 throttle, but not all at the same time (which was my point).
Paul A. Cutler III
On my own layout at home I’ve ran 6 trains with one DT400, if I need to make a change in speed, direction or what ever on a loco I just need to program the address of the loco into the throttle, it takes like 2 seconds. I think our interpretation of being in control is different. On the DT400 yes only two loco’s are visible on the screen but that doesn’t limit you from running more. Once you type in a new address the loco address that is being replaced stays at its setting and still runs. If you need to change its setting then all you do is retype its address and it reappears.
Control, to me, means having instant access to a train’s speed and direction. Setting them up and then letting them run without anyone at the helm is a train that is not under control. I call that a runaway.
Say you are running a half dozen trains, with 4 of them without being controlled directly. For whatever reason, a train derails. First, you have to identify the derailed train. Then you have to remember the DCC address for that train. If you’re operating with a Digitrax radio, then you have to find a UP5 to plug into and wait a second for the throttle to synch up with the LocoNet. Then you have to hit “LOCO”, punch in the DCC address, then hit “ENTER”. At this point, you can slow your train down.
Meanwhile, say your train was moving at 60smph (which is 1 foot per second). I see it as: 1 sec. to hear and react to the derailment sound, 1 sec. to look up and see which train it is, 2 seconds to find and plug in the DT400 into a throttle jack, 1 sec. for the DT400 to synch, 1 second to punch in the number and hit “ENTER”, 1 more sec. to actually stop the train with the throttle.
That’s a 7 second delay from the time of the derailment to a full stop under the good circumstances with a DT400R. That means your train has continued on it’s merry way at least 7 feet and dragging derailed equipment all over the place.
Paul A. Cutler III
Press Emergency Stop twice and the whole shebang comes to a quick stop. One second.
-Crandell
Of course it depends on ho wmuch space you have - when I had 8 locos going, that was one on the zephyr console, two on my DT400, and the other 5 were throttles in JMRI. Absolutely imposisble to actually ‘control’ them all - I resorted to the 0-5-0 method just to keep them going for a while before I shut the whole thing down so I wouldn;t have a serious collision. Unde rnormal circumstances I stick to a max of two on a DT400 so a quick twist of the knob will stop either one, or a minor tweak will slow the faster one down. Emergency stop can be a handy thing to have too. Didn;t stop the Atlas Trainamster from shoving 4 cars off the unfinished end of the track - but it did keep the loco itself on the rails.
