I’ve read a few previous threads that touched on this subject, but not for such a large area. My one river is about 29 sq. ft. in size with one end being about 2 1/2’ by 4’ and adjouring section about 1 1/2’ x 3 1/2’ and the other end about 2 x 2’ with about 9’ of 1 foot wide area in between and a small stream off the river of 10"x18". I bought 4 gallons of Envirotex Lite and was hoping to do this in two layers, but not sure if 2 gallons will be enough to cover the first layer.
I read the Envirotex instructions and I think I’m going to have to mix up each gallon separtely to do the first layer and get the 2 gallons poured right away.
Previous threads indicated that tinting with several drops of acrylic paint should be all thats needed, but nothing covering this much epoxy.
The river is made with pink insulation foam board for base and side walls. I painted everything with laytex paint, a special gossy paint, covered with Lite Plaster, wetted powdered grout and finally a watered down acrylic paint for the final coating. It’s primarily black and slightly grayish. I was thinking of tinting epoxy using black acrylic paint. I’m modeling the New River in West Virginia.
I would appreciate anyone’s help with this subject.
Thanks
Gary (Coastie71)
