I cannot type any reply with sufficient detail on this crap phone before the crap forum system resets the page and blanks the answer. PM me and I’ll send you detail later.
Feedwater is the make-up water that has to be pumped from the tender to make up what has been ‘boiled’ to steam and used in the engine(s).
This is almost like the discussion about “hot water heaters.” People in the trade simply call them “water heaters.” You put cold water into them and hot water comes out because that is what happens when you heat water – to call them “hot water heaters” is what grammarians call a “tautology.”
Feedwater is the water you by some means inject or pump into a boiler, so yes, it is the “make-up water” to replace the water that makes steam or is discharge by “blow down” to remove boiler contaminants.
The oldest type of way of feeding water into a boiler, locomotive, marine or stationary, is with a piston pump operated by the motion. This type of operation is inconvenient if the locomotive has to be standing under steam for a long time – it is necessary to run the locomotive forward and backward to pump in more water to make up for steam losses.
The next appliance is the injector. This gadget combines steam tapped from the boiler with cold water from the tender to “inject” the feedwater into the boiler against the boiler pressure, all without moving parts. It has something to do with the Bernouli Principle that curves a curve ball baseball pitch and produces lift on an airplane wing. It also condenses the boiler steam to produce the motive power to inject the water. The injector is a standard apparatus on a steam locomotive, even if another means is used to inject the feed water.
A proper feedwater heater takes some of the exhaust steam, and instead of exhausting it up the stack to make the draft to supply air to the fire, this portion
I have just a casual interest in trains, but i was still a bit surprised i had never seen the term before.
I look at a circa 1930 steam locomotive, and i see all the pipes and valves and pistons and rods…the thing is COVERED with it.
It sort of reminds me of a jet engine. One reason jets replaced the IC Piston motor was because it was “So Simple”. Yet, when you look at a jet motor, there is all kinds of stuff. Plumbing every where. Hundreds of odd bits and pieces that are not seen on other things in life.
It does not have all the bearings and moving parts of a piston motor, but it does not LOOK “simple”
OK, OK, alright already, there is a check valve – what the British call a “clack” valve. But there are no moving parts in an injector in the way either a piston or a turbine feedwater pump has moving parts.
Nothing there disputes what I said. In fact, it supports what I said… Keep in mind that the feed water heater cannot provide heated water unless the loco is moving! That makes the injector the main way to feed the boiler!
My understanding is that you can have feedwater heated with exhaust steam in a device called a “Feedwater Heater” and you can have a seperately fired device or one using flue gas drawn from the main boiler to heat the feedwater and that is called an “Economizer”. The later are commonly used in power plants and maritime applications.
By the way, Elesco was known for a lot more than FWH’s. The name comes from “Locomotive Superheater Company” abreviated “L S Co” and pronounced as “El Es Co”. They were the North American licensees of the Schmidt patents applied to almost any steam locomotive after about 1910 or so.
Properly-designed feedwater heaters, including most of the ESIs, did not require exhaust steam to operate. Note that Part 230 says nothing about when the two systems operate, only that they have to be functional. This came up in the National Board ESC discussions a few years ago, whether the FWH could in a pinch substitute for a bad Nathan 4000 or whatever; the conclusion was that it could, be it ever so wasteful: in a pinch just running the cold-water and high-pressure pumps together will get water into the boiler…
The issue of economizers is an interesting one, as it represents a lavish source of remarkably high-grade heat to go into convenient points in the Rankine cycle.
The locomotive ‘feedwater heater’ is generally understood to be a steam-to-water exchanger. The Elescos and the early Worthingtons appear to have assumed the same exhaust-steam pressure (back pressure) as in the early automatic-control tests in the early '20s. Many of the evolved ESIs (exhaust-steam injectors) were said to function effectively on 1.5psi (that’s psig, not psia if course!) which is well below even advanced modern front-end spec and arguably in the range of practical drifting steam. The Snyder air preheaters ran effectively on the exhaust from a closed FWH; I do not now recall whether the jet pump of Cunningham circulation would, but presumably the combination of those devices would efficiently use whatever useful heat could be recovered from a modern engine.
We now turn to the gas exhaust, which may still be over 750 degrees F at the point it ceases to have meaningful heat transfer or overcritical boiler water (it can edge lower in a Chapelon/Porta sectional where the front 3’ or so acts more as a last-stage FWH than a meaningful power-steam generator). One of the ‘practical’ schemes to recover this were the Crosti and Franco-Crosti systems, famous and infamous in Italy and Britain, where the limit on recovery was down around the dew point of sulfur compounds derived from coal, where accelerated corrosion in penny-pinching portable construction became too extreme.
Note that this is well shy of the magic number for package boilers: the point where the water of combustion (and of steam injection for nitric oxide abatement) gives up its latent heat of condensation. The principal ‘catch’ here is to provide enough heat transfer to very cold feedwater to get the heat of condensation out – alert readers will be thinking about the fact that one gallon of
Most locomotive feedwater heaters bring the feed water near the atmospheric boiling point of water. Apart from Porta’s theoretical schemes, I know of no feedwater heater, even the closed heat exchanger type, that could bring the feedwater up to the boiling point at the rated boiler pressure. A feedwater heater would need to do that to realize the full thermodynamic benefit.
Wardale talked about a scheme where the “blowdown” pressure of the cylinder at exhaust valve opening would work against a check valve, providing higher pressure steam to raise the feedwater outlet temperature. Given all the troubles he had with Herdner starting valves, I question the practicality of such a scheme.
Like 4-wheel trailing trucks and boosters, the PRR generally did not use feedwater heaters. There were exceptions, but genrally, they considered the fuel and water savings not worth the additional maintenance.
