Looking for advice on modeling gravel in N scale. I’m building the Walton & Sons Lumber Co. kit from Walthers (here), and I like the idea of giving the whole lumber yard a gravel base. I’m using Woodland Scenics fine ballast for my track, and I’m guessing the bits of gravel should be even smaller than the bits of that fine ballast in order to be accurate. What materials do you use to model gravel in N Scale? Would painted Sculptamold or WS Mold-a-Scene plaster work?
There are some textured paints from Rust-o-lem and Krylon that should work nicely.
Real sand, sifted through a very fine strainer, then sprinkled on wet paint should also work. I have done this in HO, looks good. I have heard that a piece of nylon stocking allows only very fine materials through. I have also sprinkled hydraulic cement on wet paint successfully. Should be similar to using tile grout or similar dry products.
Must be my eyes,but I use Woodland Scenics fine ballast,Buff colored,once you put on the adhesive mixture and let dry,it looks like the real thing to me…I use it on roads and the whole area around a grain elevator…with some weeds,here and there…Have fun!!
