Lake Shore new routing
There has been some discussion about extending the new faster Wolverine service to major Canadian points: Toronto and southern Ontario. Several problems have come up: delay in getting through customs; Amtrak Michigan trains end up in Pontiac and not close to the CPR Windsor tunnel.
The Lake Shore Limited would be sent over the hign speed line to Detroit, through the tunnel to Windsor, and non-stop to Buffalo. The train would cross Ontario sealed without any passengers/crew on or off the train. This ought to remove the need for custom inspection.
The new routing would cut running time Chicago to Buffalo to 8 or 9 hours or less. It would open up large centers of population in Michigan for train service. Finally it takes the train off conjested lines in Indiana and Ohio. The train could actually run on schedule! Some cities would have lesser service. They would, however, continue to have the Capitol Limited. Unknown to me is if the Canadian government and railroads would allow the train to operate and at speeds necessary for a 4 or 5 hour schedule across southern Ontario. The new routing would require a station close to the tunnel in Detroit.
The route that train would have to use today is neither the same route the fast New York Central limiteds ran on 50 years ago nor the same route Amtrak used across southern Ontario in the 1970s between Detroit and Buffalo. That track is now mostly abandoned.
A train today would probably follow VIA’s (CN) route from Windsor (CP to Chathamfrom the tunnel)…onto Bayview (Hamilton) then CN to Niagara Falls (the Maple Leaf’s route)
IMHO…it won’t happen. This is the reverse of what VIA’s Atlantic did crossing Maine. It was sealed while in the US which took years to negotiate…and all pre 9-11.
OK. Time to take another deep breath.
Do you really think, zaleski, that Amtrak is going to run a train to Chicago from both Boston & NYC that bypasses Erie, all of Ohio, and a good part of Indiana, just to save time? Is it possible that you believe the Lake Shore Limited runs to get passengers from point A to point B in the least amount of time? Then why not simply “seal the train” as it leaves Penn Station and run it non-stop to Chicago? Can you think of a reason not to do that? So can I. For that matter, why not fly passengers to NYC/Boston to Chicago? Two hours versus 20? Why not?
By the way, how much support for Amtrak in Congress will Ontario’s MP’s be able to offer?
“Sealed trains” bring to my mind, anyway, images of Lenin & his Bolsheviks on their way to the Finland Station.
Bottom line: Ain’t never gonna happen. Ever. Period.
Sound like the idea is dead on arrival. There would be a major loss of ridership. I doubt crossing two international borders would ever save any time.
Railfans have to realize that everything railroads, even Amtrak, do is for their economic benefit. If it isn’t going to add to the bottom line the idea is dead on conception.
The name of the railroad, for heaven’s sake, is Amtrak … the ‘Am’ standing for ‘American.’ This idea is wrong side of the border.
As was so well put, it is not the time, it is the money which determines most everything. But, do not stop dreaming and proposing new ways of looking at situations because only with open minds comes change.
But, the rerouted train would not be serving Canada; it would serve cities in the United States only.
By your reasoning, Amtrak should not serve Montreal, Vancouver, or Niagara Falls, Ontario?
With all due respect to Deggesty, I don’t think that’s at all what dakotafred meant. Not at all.
Why would Amtrak switch from using their present line, which is provided by railroads at a favorable rate to ATK, to a Canadian line where they would have to negotiate a market rate.
With the exception of turning the equipment a bit quicker, how is saving a potential few hours help Amtrak or its passenger? Amtrak would be losing millions of potential customers on the american side with out benefiting any on the Canadian side.
Very few long distance passengers factor in time as a major element in their planning.
How about one New York City lake shore limited go from New York to Philly then west to Harrisburg, Pa to Chicago, IL on the Broadway limited route?? and the Boston train on the other route??
You mean reviving the Broadway, which is a good idea. But Boston business is not enough to support a Lake Shore, and that train does a considerable NY-Buffalo business anyway.You mean reviving the Broadway, which is a good idea. But Boston business is not enough to support a Lake Shore, and that train does a considerable NY-Buffalo business anyway.
I might be wrong but I thought a portion of the old prr main line west of Pittsburgh was either down graded or abandoned. This was part of the reason why the Broadway limited was discontinued.
Amtrak original choice for serving Chicago to new York city was train 48-49, the Broadway limited. All service west of Buffalo on the PC was discontinued. The lake shore limited was revived as a state supported service by Pennsylvania, Ohio and Indiana, late in 1971.
First lets buy enough equipment for the LSL so that it can meet any demand. Then worry about reroutes of some parts of the train .
Yes, the PRR line to Chicago was downgraded by Conrail, especially west of Alliance, Ohio. I think that it was in 1987 that I noticed that the signals had been taken out of service on one side of the track from some point in Ohio and across Indiana. In 1989, the Broadway Limited was running through Cleveland and then through Pittsburgh via Alliance, Ohio, on its way to New York City. And, the Capitol Limited now uses the same routing west of a point a little bit east of Pittsburgh.
It seems to me that the only possibility in the near future for through New York City-Pittsburgh-Chicago service is coupling/uncoupling a New York car to the Capitol Limited in Pittsburgh (which has been discussed here in times past).
The present day LSL was inagurated in October 1975. The “state” supported LAKE SHORE started several weeks after May 1, 1971 and was discontinued in early January of 1972. The states that had promised to pay for the service balked when Amtrak initiated the the NORTH COAST HIAWATHA and POTOMAC SPECIAL due to political pressure and were not designated as pay as you go as the LAKE SHORE was.
The BROADWAY LTD was forced off the ex-PRR in 1990. It was rerouted over the ex-B&O to Chicago. IMHO Amtrak made a mistake in not routing this train west of Fostoria, OH via the ex-NKP thru Fort Wayne which historically always had good ridership as did Lima and Canton. The combination of President Downs and the Mercer Report sealed the Broadway’s fate
The BROADWAY LTD never was scheduled thru Cleveland. The expanded PENNSYLVANIAN later ran over this route Chicago-Philadelphia.
Correct, the Pennsylvanian was essentially extended as a mail train. All three Cleveland to Chicago trains avrrived and departed in the wee hours of the morning. When Amtrak stopped handling the mail and express cars, the train was cut back to Pittsburgh. Did it carry sleepers, I don’t remember?
The “Pennsylvanian” operated as a Chicago-Philadelphia day train with coaches, a snack bar, and lots of mail and express in express boxcars and Roadrailers.
