Ed and Mo,
Several reasons to leave them running.
As was mentioned, it keeps the diesel engine lubed and warm…in cold weather the water jacket can freeze…unlike your automobile, a lot of locomotive engines do not have a thermostat, so the water circulates constantly.
If they were shut off, the heat would dissipate quickly, and the water would freeze.
If the locomotive is attached to a train, as you mentioned this one was, or in a consist, the main air reservoir for the airbrakes needs to be kept charged, and the batteries need to be charged as well.
You never rely on just hand brakes to hold a CWR train in place, or any train for that matter.
If the air brake system was not kept charged, the air in the brakes would equalize to a point where the brakes would slowly release, and you’r in a world of hurt if that happens.
Some components of the electrical system (number board lights, system monitors/ computers and radio come to mind,) are left on all the time, so the batteries are under load or discharging all the time.
The diesel must be running to both run the air compressor for the brakes and the alternator to charge the batteries.
Depending on the age of the locomotive and the builder, it may have an auto shut off and auto start system also, as a fuel conservative measure.
This system will monitor the battery charge and the main reservoir pressure, as well as the water jacket temp, and if any one drops below a given or pre set level, it will start the diesel.
Once the air is charged up, or the batteries are re charged, and the water temp allows, the auto start/auto stop system will shut off the diesel to save fuel.
Keep in mind that unlike most engines, locomotive diesels are designed to run almost continuously.
Starting a locomotive diesel is fairly easy if you know the steps, as was mentioned in the above post…but it places a tremendous strain on the batteri
