I like my Aztek really well. Its the one with the interchangeable tips.Easy to use and easy to clean. As for compressors I’d check garage sale and stuff to find something cheap. just use a decent regulator and moisture trap which you can get from the local Hardware store.
Compressors-Get at least a 3 gallon.(or bigger) You WILL use it for other things and you WILL be bummed out with a 1 gallon. Can’t go wrong with Craftsman.
I got a $100 compressor from Home Depot and added a water/moisture trap for another $10. Works very well. The tank could probably be bigger, but it’s fine for my needs.
I have a Paasche H model air brush. It works pretty well, but for some reason, my seems to clog a lot. It’s better with the #3 tip.
I have a full size Campbell Hausfield air compresser, you know 20 gallon tank for a contracter and a regulator. Would it work for an air brush? sorry to hijack your thread.
Look in the Sunday paper in the sale ads. Sears usually has an ad in there. They’re not the cheapest, but they are good quality.
I have a 1 hp Campbell Hausfeld that’s worked fine for a year but just started to crap out. I took it apart to fix it and it is the cheapest piece of crap inside! I doubt that I would buy another Campbell.
