After 30+ years I’m tearing down my model railroad. I bought a new home with a space for a new model railroad. 30 years ago I designed the layout with pencil and paper. Today, there are several products available that will do a better job. EACH says they are easy to use and have pretty much the same features.
Which have you used? Which do you like best? Why? Which is truly easiest to use and creates the most accurate plan that you can transfer to construction?
I used RR-Track to lay out my N scale. Cost varies depending on package you purchase. It has some flaws but it worked well for me. I tried some of the freeby versions available and none worked well for me. I have seen many comments by others that say they like other packages but I have no experience with them.
I should note that my layout was done with Kato Unitrack. If you are using flex track, I suspect that there are other packages out there that will do a better job.
Back in 2011 I used XTrackCAD. I decided to try something free first and just stuck with it, using it for a year or so before deciding to build. It has some learning curve, so use the tutorial to try it out. I got used to it and how to combine using the brand name (template) track pieces with custom drawn curves, etc. I would use it again.
I can’t compare to others as I did not try others. Someone here will be able to do that.
I don’t believe that I would classify any of them as easy-to-use. But time spent learning the program does pay off. I have designed a couple of hundred different layouts with 3rd PlanIt and I’m happy with the program. (I don’t routinely use the 3-D or train-running features, but they seem to work fine)
I also own a copy of CADRail and it works well. I’ve also used XTrackCAD and tried the demo of AnyRail. One of the differences between the programs is in the user interface, so try them before you make the investment in dollars and/or learning time.
IMHO, 3rd PlanIt works more like a familiar Windows program as compared with CADRail and XTrackCAD, whose user interfaces are more like a traditional CAD program (click-move-click). That was an easier learning path for me. Like 3rd PlanIt, AnyRail also feels to me a little more like a Windows program than the others.
Personally, I prefer a commercial product with support offered by the developer. Others have had good results with open-source offerings.
For any of these programs, the learning curve will be steep. For a single layout just for yourself, the time investment to learn the program may not be worth it compared to careful to-scale hand-drawing with accurate templates of the turnouts you plan to use.
My “software” is 11x17 graph paper with scale rule, drafters compass, erasor, erasor shield and mechanical pencils.
I measure the area the layout will go and draw it to scale on the paper and for me it’s easier to visualize what will fit there and where:
I only design a layout once in any number of years so for me I preferred not to deal with the learning curve and time investment that requires. For me careful to-scale hand drawing has worked quite well.
I don’t use turnout templates but I estimate the space required realistically usually I’ve had no problems translating the plan to full size. I don’t have a scan handy of the drawing for my last layout but all the major elements went in fine:
I have used 3rd PlanIt extensively and I am really happy with it. I first used it to design and refine my own layout (which I will never build thanks to back problems[:(!]). I played with a number of designs and it was easy to make quick changes to each of them as I identified problem areas.
More recently I used 3rd PlanIt to design a new layout for our club (which is being built as I write). The club set some parameters like 36" curves and 2% grade and I went to work with those in mind. It quickly became obvious that 36" was not workable in the space we had available so I changed the minimum to 32". The change was easy and the layout fit nicely into the 20’ x 25’ space that we had.
I was able to establish a 2% grade (± .2%) no problem, and calculating clearances at overpasses was a breeze.
When it came to building the layout the program proved to be really worthwhile. We used cookie cutter sub roadbed for about 2/3rds of the layout and the rest was flat. Using 3rd Planit I was able to draw out each piece of the cookie cutter roadbed and the flat areas and lay them out on a scale 4’x8’ sheet. That allowed us to minimize waste big time! There was less than one sheet of scrap plywood out of 12 sheets.
Perhaps the best use was made when cutting each of the pieces. I simply established a 0"-0" starting point on the drawing at one corner of the sheet and measured out the coordinates of each cutting point from there. I was able to plot points every six inches so drawing accurate compound curves was a breeze. Just connect the dots.
I was able to draw the benchwork framing piece by piece. That allowed us to calculate how much lumber was needed, and it showed detailed assembly directions for each section of the benchwork. Putting the frames together was quick and easy. In addition, the program allowed me to plot the future locations for all the Tortoises so we could adjust the positioning of individual frame pieces to avo
I’m a long time CAD user (30 years) and I’ve tried several of the model railroad packages and all worked pretty good. Basic differences are the individual program ‘accessories or tools’. They all have a steep learning curve but not much more than any other Windows software program now days.
Most have either a freebee demo or startup package so that you can test drive them before they cost you money. Actually several of the freebee open-source programs work pretty good too but like Bryan said having support makes a big difference.
I still prefer using my CAD over the custom programs but that’s just me. I make my own turnout and special track drawings and then copy and paste. Worked out great for my Mel Double Crossover.
I made my own double crossover from four Atlas code 83 #6 Custom Line turnouts and their 19° Crossover. Works great! I normally get my drawing accuracy under 1/64&r
Tried several and my vote is for Anyrail. I like the familiar MS Office-like interface. Free to try. I guess you could “cheat” a bit and just have it free if you design your layout in sections to overcome the 50pc trial limitation.
In my early days before I started using software, I discovered that a simple paper drawing would quickly trick you into a design that would not fit. I then covered the floor of my layout space with big sheets of cardboard. I then used that as my full size drafting board. That allowed me to verify that a curve and turnouts would fit as I wanted. That also gave me good dimensions for my benchwork. Once I got benchwork built, I transfered the cardboard cutouts of my design to my homosote and started laying track. Worked great.
Atlas and Scarm are both free and reliatively easy to use. There is a learning curve, but I found the youtube vids a help. It helps to first figure out how much room you have for the layout before planning it, so you confine yourself to those paramets.
Plenty of options available, but I prefer not to spend the money knowing that the design changes from paper to the layout.
I started with the old free Atlas program. After finishing that section of my layout, the program was no longer available and I switched to XtrakCad. By that time, I knew what I wanted and only used the program as a first cut guideline.
I will warn you. Using software can trap you in “analysis paralysis” and actually delay your layout.
I agree, a simple paper drawing would give you problems.
The “trick” to using paper is to draw to scale. If you buy a tablet of 11x17 graph paper which has the squares on it to help scale things out, use a compass and be faithful to the scale (in my case 1" = 2 feet) and allow for actual turnout size, you should be fine.
On the graph paper used, each square represents a 6 x 6 inch space in the real world.
The second step is optional if you do your scale drawing correctly - and I’d say the same if you use a software scale drawing using one of the availalbe applications.
When it comes to turnouts, rather than full-size photocopies, I just use the real thing to check locations before actually laying track.
Here I am test fitting turnout locations with centerlines drawin in on painted Homasote for control.
I did make a scale drawing but don’t have digital copy atm - part of it is visible in the photo below.
Here is a scale drawing of a previous layout I had nearly finished the plywood Pacific phase before it had to be dismantled for moving.
Not on a scale drawing it’s a best practice to draw in an actual scale or bar scale for reference. I use those to set my compas
Long-time 3rd Plan-It user. I foud it as easy or easier than most (none of these programs is particularly ‘easy’ in the sense that you can open it up for the first time and in an hour have a basement-size layout designed). I do think it takes a specific mindset to use a CAD package, it’s not for everyone. Hand drawing can work well - in fact one of my favorite things in school was mechanical drawing becasue it was a kind of drawing I could do - using tools for accurate lines - I can’t draw ‘art’ to save my life. But in part I think that allowed me to move to CAD because I was thus familiar with the concepts, and having the ability to click on a line and alter it or just erase it instanatly is a whole lot faster than pulling out the eraser shield and carefully wiping out the aprt you don’t want. Especially in the early stages, unles you don’t mind going through lots of sheets of paper and tossing the false starts. You also need to be disciplined to do it by hand - it’s far too easy to cheat and make turnouts far sharper than they are, or curve radii tighter than you want. Using templates solves this problem. The computer won’t let you cheat - you place a #6, that diverging route is going off at a #6 agle and that’s it. You can usually set other limits, like radius and grade, adn when you attempt to go outside those settings, it either won’t let you or will flag the problem areas with a different color so you know it’s substandard.
One thing I don;t do is tyry to print the whole thing full size and trace it. My main purpose for using CAD is to use the layers capability to compare multiple options, and get somethign that I know will fit. I once tried the full size printout thing, and it was a whole lot more trouble than it was worth. Instead, I’ll pick a critical area, print it to some reasonable scale where it is easy to take measurements, and use a good reference point, such as the edge of the benchwork. The rest just sort of fits in as
That sounds like a pretty easy software to learn and use!
Back in grad school I did part-time work for the Indiana Geological Survey and used AutoCad. I was far from an expert but I’d think a package made for layout design with built in templates would be more user friendly for a beginner. I never had a copy of AutoCad to install on my personal computer and it’s not cheap if I remember correctly.
Hand drawing with controls like paper with a grid, and a scale rule and a room drawn to scale first, works well for me. Maybe I just have the “knack” but I drew the above recent layout plan on a single sheet of paper. What helps me to avoid throwing sheets of paper away on false starts is past experience and using the outline of the room to visualize what will fit. I can take a 180 degree curve turn back minimum radious and aisles and other features and estimate what type of configuration will fit before I s
First job out of college, they switched from hand drafting to CAD. Only they went with Cadkey (what-Key?) because at the time, it was native 3D. AutoCAD at the time was still faking it. I got to go to class along with the drafting team because guess who was going to provide all the support when they had problems? And considering none of them had ever used ANY sort of computer-based CAD in their life - and all were at least 15-20 years older than me… I at least had a tiny bit of experience playing with OrCAD for electronic schematics in college. I’ve always found AutoCAD to be downright hostile to use - but 3rdPlanIt works more like standard Windows drawing programs and a bit like CadKey.
Before 3rdPlanIt, I used two different products, one was a model railroad specific program called Design Your Own Railroad. Kind of limited, but it did work for my shelf switching layout that I built that had a pair of the 101 Track Plan bits on 2 sides with a custom piece connecting them. Then on some railroad forum (probably CompuServe, going back that far) I found people using a generic PC CAD program called PC-DraftCAD. It was sort of AutoCAD Light, Shareware I think, and some people had made templates for some common track. It was OK, but having to make up my own templates for every piece of track I wanted to use got old real quick.
I did give XTrackCAD a try, hard to beat free, plus I did have a Linux machine for JMRI to run the layout in addition to my usual Windows machines. I redrew one of my plans from 3rdPlanIt. It sort of worked - while XTrack has elevation, there is really no visualization in 3D. Whereas with 3rdPlanIt, you cna switch to the 3D view and literally step into you plan, walk through the room, etc. Look from any angle. I can get a prety good sense for a room layout looking at a 2D blueprint, but there’s nothing liek having the whole thing visually right there in front of your face. Especially when you take the time to color backdrops and place some scenery. T
I’ve been using Cadrail for a very long time. I try other software but I alway end up going back to it. I’m now up to version 10.0 and I’m prety sure that I started with 2.0. I went to Parallels so I can run it on my Mac.
