N&W Class J
We rode behind the 611 on several excursions and before the wreck when it could still go fast, I clocked it running between 80 and 90 for a ways on the stretch east from Petersburg to Suffolk, Va. with a long train of various vintage coaches.
I’m somewhat surprised by all the speculation of comparisons of the J with other 4-8-4s, because the information is readily available. When Kalmbach published the Classic Trains special on 4-84s, they made available in the “On-Line Extras” graphs of drawbar horsepower versus speed for quite a few (maybe all?) of the 4-8-4s. With the singular exception of the NYC Niagaras, and then only above ~95 mph, nothing was even close to the J. The J’s superiority was most striking exaclty where the application on the N&W profile needed it to be - in the 40 to 80 mph region. If you look at the maximum authorized speeds on the (old) N&W, except for the well-known Great Dismal Swamp straightaway and a short segment in Appamatox County, nowhere was the speed limit above 65 mph, and through the mountains it was less. So, the J’s mission was to accelerate hard out of the curves up to the speeds allowed on the (short) tangents so as to keep the average speed up. This it did extraordinarily well, with the reserve high speed capability that’s formed most of the discussion in this thread.
If you research formulas for calculation of starting tractive effort of steam locomotives and apply them to the J (I have…) you soon conclude that the 80,000 lb. rated starting tractive effort was almost certainly "invented’ (as the nice round number would tend to imply from the git go…); the real number is almost certainly significantly higher.
As for twin sealed beam headlights, 611, 1218, 765, 730, etc., etc., etc. have them because the FRA says they have to have them. Since ditch lights are to enhance visibility of the on-coming train approaching grade crossings, and that’s never exactly been an issue with steam-powered trains, they may have gotten a waiver on them. I do not know the answer to that; perhaps someone close to the excursion programs can comment here.
Dave Phelps
In my opinion. the superiority of the J was in part due to its lightweight rods and excellent driver-wheel balancing, allowing top speeds comparable to locomotives will larger diameter driving wheels, while its smaller driving wheels permitted a higher tractive effort. Note, I am saying “in part,”
That’s because that graph is useless. It was completely made up, The results were not based on actual testing of the locomotives, but somebody playing a numbers crunching game. None of the numbers crunched explains what is going on inside a boiler of a particular design at a particular moment.
Most of the stuff you read in Trains is written by railfans, not Mechanical Engineers. A ME isn’t going to waste their time writing an article on something that they have no actual data on. That would be stupid. However, railfans seem to love making up “facts”, then spending countless hours arguing the “facts” on internet forums.
That is why it is best that the locomotives are tested, and not rely on mechanical data. The data that exists on the J is mostly estimates by the N&W mechanical engineers, and regarding the 611’s performance history, I have to wonder if even these numbers need to be revised. Any locomotive who can easily run 29 passenger cars on an upgrade is worthy of more respectable numbers. I wonder if any consideration has ever been made regarding testing 611 to see what she could truly do. lois
[8D]I took my first wife and children on an excursion out or Alexandria ,Virginia in the late 70’s early 80’s. when u have a program so deeply entrenchment as the union pacific program it does not matter who is chairman or ceo. there is a corperate environment that does not change with the wind!![banghead]
That has proved to be the case. And, unfortunately, we did not have that at Norfolk Southern, though it appears to have been the case to some degree at Southern. Such corporate flippancy does little for the public image of the company. I hope that there has been some understanding at Norfolk Southern that there are dividends to the company having a good public image. And a good public image is often best provided by steam excursions, as the public are invited for train rides instead of being shut away from the railroad. Only time will tell how things have developed at Norfolk Southern. But in the meanwhile, let’s hope that arrangements are being made so that 611, 4501, 630 and other locomotives participating in the new program will be allowed to run regardless of who occupies the CEO position. For unless such arrangements are made, it can all be quickly shut down, and we are left in the same mess as before. lois
It would be not only all the 4-8-4s in question would have to be tested, but the testing would have to be standardized. What are we testing for? Power at economical operation or maximum power that is uneconomical to sustain? At what speed are we concerned about? How about the power curve itself? Are we looking for a locomotive that has a peaked curve,or a locomotive that might not have as high peak power, but can sustain power over a broad speed range? If the locomotive is coal fired, shouldn’t the coal be the same? What happens if we take a J and fire it with western coal? Think the power output will be the same? Conversely, what happens if we take a western locomotive and use high grade eastern coal? What about the operators? Steam locomotives are very dependent on how well the engineer and fireman work together. How do we assure each locomotive is operated at its best? Even after doing all that, you may still not know which is the “best”. Steam locomotives were not only custom designed for each railroad, but they were custom designed for specific divisions on that railroad. A locomotive that scores high in general testing might not work as good as expected if placed on a division with different operational needs. I don’t know if we can ever compare steam locomotives like we can compare an ES44AC to an SD40-2. Every ES44AC made is basically the same. It works the same on NS and CSX in the east as it does on UP
I think she has gone on past the ‘comparative 4-8-4s’ issue and is now looking at a correct testing modality for 611 alone. (This also accords much better with the purpose of the thread itself.) This is not to disparage the points you were making, in any way.
I don’t think anything would or could be gained by taking 611 in her present condition and conducting grate-limit tests on the boiler, or repeating some of the PRR high-speed testing with better attention to the valves. I’m also not certain whether, at present, numerical simulations of the locomotive would produce meaningful results showing what the J design ‘could truly do’ at the limit.
I would find it strange if N&W did not perform a reasonable amount of indicated dynamometer testing on the J locomotive, but I’d also understand why practical assessment of actual sustained high-speed operation would be of more interest to PRR to conduct, for example. As has been noted elsewhere, railroads wouldn’t operate a locomotive at its physical limits for long periods in ‘ordinary’ operation, and the concern of issues like ruling grade is to proportion moneymaking operations to what the locomotive can reasonably … and cost-effectively … achieve, rather than what yo
I certainly agree with not comparing the J to other 4-8-4’s. The J’s were in a class of their own, being designed for operation on the N&W, to keep passenger trains to schedule regarding the grades and curvature that defined the N&W mainline. However, the J was able to operate successfully on other railroads, 610 on the PRR and 611 on the Southern and railroads that became part of the N&W (Wabash, Nickel Plate, etc.) The design was flexible enough that 611 was able to conquer Saluda Grade, something the N&W designers never intended a J to do. Of course, back then, it was never thought that a J would be operating outside the N&W in excursion service, or now, that a J would be on the brink of a third operating career. lois
Great video !! And that throaty whistle, too !!
Years ago I had the pleasure of witnessing (and hearing in approach) #611 under steam when it came thru Charlottesville VA on track just 200 yards from my house. One time I even got the excursion schedule beforehand so I could be trackside when it went by.
Having graduated long ago (in the decline of the steam era) from an engineering school in PA where the CEs, EEs, and MEs had many of the same courses in the first two years, I as an EE have the utmost respect for the capabilities of the designers of such magnificent machines, truly the pinnacle of the mechanical engineering art. The thermodynamics of squeezing nearly the last ounce (metaphor, not unit) of available energy out of coal and water plus the kinematics of balancing the movement of a ton or so of side rods jumping up and down several times per second is a now-lost art, perhaps surviving, but now fading, only in China where steam locos lasted the longest. MEs of the past, I salute you !! RIP.
Hope I live long enough to hear and see 611 come thru town again.
With the present progress of the Fire Up 611 project, with the organization of a restoration crew and research in progress, as well as the always necessary solicitation of big donors, 611 may be on the way to being sent out for restoration. lois
And there may be a dynamometer car hooked behind it in the future.
The N&W dynamometer car is at the Virginia Museum of Transportation, though I doubt that it is operational. lois
There might be an effort to restore it to operation or to use another if available.
However, I have to wonder how much the high speed capabilities of the J’s affected the crews that ran them. There had been other locomotives before the J’s who could run fast- notably the old class J 4-4-2 Atlantics who were known as sprinters. And the E class Pacifics and K class Mountains were certainly not slowpokes either. There were others, but these I note specifically as preceding the J. But the J was the first locomotive noted on the N&W with the capability of going over 100 mph, and with the profile of the N&W, the J on a few occasions came to grief. In 1946, 604 wrecked with the Powhatan Arrow, turning over on a curve at Powhatan, WV, due to high speed. Then in 1948, 607 turned over with the Arrow near Franklin Furnace, OH, clearing a switch at 92 mph. This resulted in a rail going through the entire locomotive, from the nose to the cab. Excessive speed was also the cause of this wreck. Then 605 turned over with the Cavalier and on January 23, 1956, 611 overturned with the Pocahontas on a curve in Cedar, WV, with high speed also being the cause. To me, I see some kind of pattern. These wrecks nearly or all being from one cause and all with the same result- the locomotive turning over. What do you think might be the issue here? lois
This is not terribly unusual. Look where the center of mass of the locomotive is, and then look at the offset to the outside rail in a curve. The locomotive can easily tip enough by the time it derails to continue going over. When there are no rails to hold it up, equilibrium concerns alone will have the locomotive tend to roll… and this of course will be exacerbated by high speed. All the kinetic-energy moments increase as the square of the speed, not just the momentum that has to be counteracted by braking. And once all that mass gets rolling on the axis of its center of mass, the inertia will make it slow to stop.
I would defer to someone like BigJim on whether the N&W had a greater danger of relatively sharp curves at the end of its high-speed stretches, so that the effects of a little confusion or forgetfulness would be dramatically greater than a higher-speed railroad. Something else potentially contributory is the stiff and relatively long effective wheelbase (due in no small part to the stiff lateral that was part of the high-speed balancing scheme). This might facilitate ‘popping’ the lead or perhaps trailing truck over the railhead into derailment, after which drag and run-in would rather quickly induce a roll down the ballast prism and then embankment…
The ‘pattern’ you see, I think, is too high a speed for the curve, quite possibly compounded by the engineman closing the throttle too quickly with the run-in from the train giving a good launch. See the NYC Little Falls wreck for an illustration of the forces involved.
I do know, with the two wrecks that occurred on the Pocahontas Division (the 604 wreck in 1946 and the 611 wreck in 1956) the wrecks occurred on sharp curves. These curves, along with bridges and tunnels, were part of the normal profile of the Pocahontas Division, which then had a maximum speed limit of 50 mph. The J had a calculated overturning speed of 53.6 mph (according to the ICC report of the 1956 wreck) on a 13-degree curve like that at Cedar, WV. I am not familiar with the data on the curve in the 1946 wreck, but expect it to have a similar restriction. The wreck in Ohio occurred under different circumstances. The train was being directed around another train but was traveling too fast to navigate the switch safely. The track on the N&W mainline (as I have seen on Google Maps) in this area is mostly straight, with an easier profile than that on the Pocahontas Division. High speed operation would be expected here, but would be completely out of character in West Virginia. The engineer on this particular wreck survived, and I am sure he would have had some questions thrown at him. The fireman, unfortunately, did not. He jumped, but the tender turned over on him. As for the fourth wreck, I am still collecting data. What information I have at this point the engine was swaying before it turned over. Both engineer and fireman survived, and walked away from the wreck. lois
A “J” pulling a south bound Tennessean turned over about 5 miles north of Bristol. This was a fairly straight location. The J hit either a local freight or the Va. Creeper that was fouling the main at a location near a dairy plant.
Deggestry ?
I have not heard of this particular wreck. I do know that J class 613 ran into the rear of a freight train, but she did not turn over. lois
