Old or New AC Transformer Questions?
I am looking to add power to my “Really Old School Layout” but the layout is very small ( two small loops in 3’-6 x 4’-0") which means using todays larger size power packs may not be do-able as the ones I was shown are very large in footprint. I wanted to place them in the left over cornerspaces. I was thinking since my layout is very small, of using 2 older smaller packs that use to come with the older starter sets. I was warned at a LHS do not use older packs as they were not as good electronicly and would be a fire hazard, so I want to ask here what you all think, are older smaller power packs OK or should I rethink how I’m going to add power to my tiny layout.
I am a real novice with AC power, having done DC stuff up till now.
If I go old, how old is too old before they really do become iffy?
If I go new, what do you recommend?
Is there a minimum wattage I should try to stick to? I was looking at some 40W packs on Evilbay being pretty affordable
Remember the layout is only 3’x4’ and I’ll only be running one older Marx or Lionel engine at a time on each loop.
Thanks
See that fire in that photo you have attached? That should be your concern. Those 55+ yo starter transformers were underpowered back then, so you can assume that they have had their internals [xx(]. If you find them cheap, then they are cheap for good reason. The main transformer coils, rollers, circuit breakers, insulation, the main power cord are all suspect. Now ask your self: how many 55 yo high current electrical devices would you be willing to bring home & operate? Without a fire extinguisher nearby? [:|]
Since I run only a overhauled PW-ZW for light duty & Z4000s otherwise, I will leave + recommendations to others …
I am using a 1946 Type R100 tranformer to run my small, 4X6, layout. Only one track, but the Transformer has 2 variable and several fixed outputs. I did replace the power cord this summer, but other than that I don’t have any problems with it.
I run a #224 and a #2035 Lionel, a #999 Marx and a plastic shell Lionel that i don’t remember the number. Only bad thing about the R is, no whistle button. Have to use a 167 whistle controller. I may get a later 1940s or early 50s transformer with a whistle button this summer.
Hope this helps.
That would be an inaccurate assumption without any basis-in-fact.
There are hundreds of thousands of modern postwar transformers in perfect operating condition, original & refurbished. Most from 1948-on are still working or easily serviceable.
For your needs, the 1044 & 1033 units would work just fine, or a couple of RW’s even if you want a little more art-deco flair. The whole layout could be run on a single KW too.
If you are considering modern transformers, two newer CW’s(with “G” in the mfg. date code) would be economical choices(~$55 each on the street) and will give you up to 10 amps continuous output(about the same as the continuous duty rating of a postwar ZW).
Welcome to the forum! I love Glasstream boats.
The Type R is a great transformer. That’s why I recommend it’s successor, the RW, for those that have horns & whistles.
Thanks for the welcome. I need a newer, by at least one year when they put whistle buttons on them, transformer, and i’ll bw looking for one this summer. And that #224 Prairie was my 4th Christmas present. Of course, it was several years before my father and my uncles allowed me to play with it.
Too bad Glasstream is gone. Those older bass boats were great and I wish i could replace my 1987 boat.
I second Rob’s motion on the 1033 and 1044.
Thanks everyone, I know now what to keep an eye out for, I’ll update when I get one.[:D]
Another great little PW transformer is the LW, I really like the looks of those, at 125 watts, maybe a little more than you are looking for, but more watts is definitely better than not enough.
Doug
This thread is all very interesting to myself.At present I am running my trains with a 1025 45 watt Lionel transformer that came with a set that I received in 1967.It works well but I have been thinking about getting something a little more powerful.I was using an old Marx transformer to operate switches until I changed the layout and took out the switches.
My own transformers consist of two Lionel KWs, both from the Fifties. No malfunctions of any kind, ever. I also have the Lionel 1033 that came with my first train set in 1951, and for a long time, it was my only transformer; it’s very versatile. In addition, I’ve got a couple of smaller transformers that I picked up somewhere, and they still do duty powering lights. One of them is a Lionel 1028 that came with my mother’s #1700 set in the Thirties.
The only maintenance I’ve had to do on any of them was to replace the cord on the 1028.
For all-around use on a small layout, the 1033 would be hard to beat. Whatever you get, don’t throw your 1025 away. Those small transformers can still do a fine job running your lights and accessories.
!(http://1stclass.mylargescale.com/vsmith/Lionel Transformers.JPG)
OK this happened alot faster than I expected, I but in a bid on a guy selling a Lot of powerpacks, I got these 2 Lionel packs, one 30W one 40W, plus and old 25W Marx pack and 2 small HO DC packs all for, less than $50, on top of that it was overnight mailed to me! I plan to use the 40W on the larger loop, the 30W in the inner loop and keep the elevated loop wind-up only.
!(http://1stclass.mylargescale.com/vsmith/Marx Warbonnet 02.JPG)
BTW This is why I needed to look for a powerpack [;)]
Live and learn they say, OK the power packs I picked up in the above post, only the 40W pack is of any use, It works fine, but these old trains suck a lot of power to move, my 30W pack will not move anything, which is a surprise considering that most packs that came with the Marx sets were only 30W, which also means my Marx 25W pack is also nothing but a neat looking paperweight. The way I’m setting up the new layout, I’m going to need another 40W minimum pack, looks like I will have to fork out a few bucks for the Lionel 80W pack, forgive me for not using the model #'s I’m simply not that familiar yet with alot of this stuff yet.
My thoughts: stop playing to cheap. Get a modern transformer like a Lionel CW-80 or MTH Z1000, you get something new and it has whistle and bell controls if you add a new engine. Use the old ones for accessaries.
You need to be concerned with the transformer’s output voltage, not just the power rating. For example, you could have a 1000-watt transformer; but, if it put out only 5 volts, your train is not going to go anywhere, even though it can supply 200 amperes at that voltage.
Marx transformers typically put out 13 volts at most. American Flyer transformers typically do 15 volts. The Lionel 1033 and its cousins go up to 16 volts. The ZW reaches 21 volts; and the Z goes to 25 volts. What your trains require, I don’t know. If you can borrow a higher-voltage transformer (Z, V, ZW), you can find out what your needs are.
The power rating tells you, for older transformers, how much power they take in at the line voltage (probably assumed to be 110 or 115 volts). The power available at the output is probably about 70 or 80 percent of that. Newer transformers are rated by the power that they can put out. The power out of the transformer is the voltage, which is what you adjust with the speed control, multiplied by the current that your train draws. For example, if your trains will go fast enough for you at 16 volts, you could use a 1033, which is rated at 75 watts. According to Lionel, your train can draw about 50 watts continuously from this transformer, two-thirds its power rating. This corresponds to about 3 amperes at 16 volts, which is a reasonable amount for a typical train to draw.
I wasn’t planning on playing it cheap [;)]
I put a bid on those not really expecting to win, so I low-balled it, when I did I was really surprised! That being said I am looking to go the CW80 route, I’ll keep the 30W pack in storage for now. The 40W works fine for what I want it to run and will be used on a small loop on the new layout. BTW the Lionel 40W does have bell and whistle buttons on them.
Thanks for the info Bob, I’m probably going to have to educate myself on what these things run on, I am an electrical Luddite, so this may take some effort and get some electrical measuring gear as some of this older stuff I’m getting may require serious reworking and knowing what the power output requirements are for each engine would be helpfull
If you do buy a voltmeter (probably the most useful “measuring gear”), you need to know that an ordinary voltmeter cannot accurately measure the voltage out of some modern “transformers”, like the CW-80. I have in the past posted correction tables for voltage measurements of this particular model. I would stick to analog meters for such measurements, since it is hard to know just how digital ones respond to the non-sinusoidal outputs of “transformers” like that.
Speaking of the CW-80 by Lionel, I saw a new one at the hobby shop in Lantana FL today for $125.00.
Lee F.
Beware of early CW-80 production. They have a botched output design and a poor reputation for reliability. You can read (much) more through the forum’s search function.
