continueing with this theme I am posting a how to on quick, easy and cheap trees that are good looking and can be mass produced.
Materials needed are: filler material from the floral department ( about $5.00), fl;orist wire, at least 2 or 3 differant shades or green spraypaint, brown spraypaint,white glue, sissors,and wire cutters.
the first step is to break apart the bundle and take 1 or 2 “branches” out. cut these in to a lenth about the size of the tree to be made.
Group the trimmings together putting the tallest at the center and working outwards from both sides with the smaller sizes. Tightly tie a small (about 5") peice of floral wire around the trunk, starting at the top and working down to the base. Make sure to keep this as tight as possible.
take the brown spraypaint and paint the trunk area. On the pale tree I paint the ENTIRE tree as a base.
