Painting Passenger Cars
I am about to paint another passenger train and was looking for some suggestions for a good “stainless steel” paint formula. I have been using Floquil bright silver and would like something that looks a little better. I used glosscote to seal the decals for the last train that I did, and although it didn’t look bad, I wasn’t completely satisfied with the outcome. Thanks in advance for the suggestions.
csmith9474,
Hang in there and AntonioFP45 should see your post. He has the exact info your looking for.
[:)] REX
You da man AntonioFP45!!!
Go to the mocel car and airplane paint section at your local hobby store and get “Testors Metalizers” paints. They come in many shades and I’m here to tell you that they make plastic look JUST like metal. They are easy to use too! [8D]
Oh, and thanks rexhea!! I didn’t mean to forget you. I am still just a little disturbed by the whole suckin’ and blowin’ smoke unit post earlier.
I guess I should clarify that my biggest gripe was when I oversprayed with glosscote to seal the decals it dulled and blotched the paint a bit and I want to avoid this.
Hello CSSmith and Rexhea,
Guys, I’m humbled by the recommendation. I hope I can be helpful.
For VERY realistic looking stainless steel passenger cars, ALCLAD II CHROME is an incredible product. Not all hobbyshops carry it so you may have to call around. Be aware that this is lacquer based, not acrylic, so ventilation is a must.
Here’s the procedure I use:
(1) Completely strip the passenger car shell. I use 91% Alcohol in a small pan. A few minutes after I see paint “floating off” I use a toothbrush and scrub the shell. Wa***he shell with warm soap and water. At this stage, your hands must be clean, no sweat! Use latex gloves if needed.
(2) Final-Clean the body and spray it with a high GLOSS dark gray. You can use Acrylic or Solvent based paints for this stage. For the dark gray mix 5 parts Gloss Black with 2 parts of a Gloss White. Make sure every square inch of the surface is covered with a smooth, glossy coat. Allow to dry.
(3) Apply Alclad II Chrome in light very thin coats. Do not try to “hide” the gray color all at once. Allow 2 to 3 minutes between each thin coat. By your 4th thin coat, you should see some amazing results! Your car will look like real stainless steel. Do not touch it, even after it’s dry!
(4) Airbrush a high gloss clear. Allow to dry and then apply your decals.
(5) Airbrush semi-gloss clear to tone down the shine a little.
You’re done!
I used this method on my Metroliners. I used a black undercoat originally, but the result makes it look darker, like an aircraft. With gray, the results resemble stainless steel.
I heard of people using the ALCLAD before and was a little apprehensive as I wasn’t sure of the application method nor the result. I will definately give this a shot now. I typically don’t buy anything painted so I won’t have to fool with that step. I detail before painting so it makes prepping the cars for painting a pain, but I have tried detailing post paint and it can really mess things up. Thanks a million for everyone’s help, with special credit to AntonioFP45.
Thank you.
I can’t take the credit though. It was the July MRR, 2003, where a modeler used this method to redo a pair of N scale RDCs. They looked great!
Suggestion:
Though it costs extra I think it’s worth the effort to experiment on a piece of scrap styrene or a “scrapper” model railroad car like an old Tyco boxcar or caboose to check results before doing the passenger cars. The secret to the Alclad II Chrome effect is THE UNDERCOAT, which is your foundation. So I experimented with various shades of dark gray. I used an HO Tyco F unit shell that I got free at a train show.
BTW: The reason for putting on “thin coats” is due to Alclad being a “hot” paint product. Put it on too heavy and the plastic may be attacked. That’s why it’s important to let the gray “foundation” coat cure properly as it also acts as a barrier between the Alclad and the bare plastic. Don’t worry, though. Just take your time.
Check out this link and look at the results on the test panels. George McLeod used various metalizers.
http://www.largescaleplanes.com/tips/MikeMcleod/NMF/nmf.html
I think you’ll be impressed with the test panels. Just my opinion, but I think Alclad II gives an incredibly realistic Stainless Steel appearance! [8D][:D]
Let us know what you do, whether you use this or another metalizing system.
Peace and High Greens!
Alclad Chrome may be too shiny, depending on what you are trying to accomplish. Alclad also has stainless steel paint, as well. Not as shiny as the Chrome. Might be what you are looking for.
I sell the Alclad paints at my hobby shop, and have had great results from all the Alclad I have sprayed.Depending on the effect desired, will determine the base color needed. Black base color is the recommended (by Alclad) color for their Metal color finishes. Other base colors will give you different results. Don’t be afraid to experiment on scrap materials.
Your results may vary! [;)]
Rotor
Hello Rotorranch,
Alclad II Chrome is shiny, however, it dulls down after the gloss clear coat is applied and dulls down even more when a semi-gloss or satin clear finish is applied. I have successfully experimented with two of my HO Metroliners. One car I left in chrome while the 2nd car I dulled it down with clear. Difference is like night and day! When I finish 4 car set, I’ll post the pictures on this forum. They will be in Penn Central.
You’re correct about the black being recommended, however, as I pointed out above it is too dark for HO passenger cars (not as noticeable in N scale). The high-gloss grays are what work well in this case.
Don’t take my word for it, though. Check out the Model Railroader Magazine article I mentioned above. Those N scale RDC cars look incredibly realistic!
Peace out.
i just picked up a bottle of floquil bright silver. it is good for headlight lens simulations. although it is a very bright silver, it may work for the stainless steel look you want. but test it first. good luck!!
matt arentzen,- northeastrailworks.com
I’ll second (or third) the Alclad. I did a Santa Fe high level El Capitan train (10 cars worth) and got great results. I used Tamaya gloss black for the base and Floquil Crytal Cote for the sealer. I went with stainless steel’ One thing to watch for is to have the first car you do where you can see it as you do subsequent cars. The final appearance depends on the number of coats and you’ll get better results if you’ve got a visible sample instead of relying on memory.
It is good to see someone else modeling the hi levels. I am doing a late 50’s El Cap/Super Chief, and has it ever been an project so far. I have found a seemingly endless supply of the Detail Associates detail kits for the TSP hi levels. I wanted the yokes more than anything. I have also been able to acquire a set of the Microscale hi level decals. It should be interesting to see how the paint turns out as I am using a mix of brass car sides, Walther’s, and TSP hi levels. There are also some Soho cars mixed in there as well. I hope a good primer will get me going with the plated brass. I want to get this done so I can move on to the Budd Sunset Limited. If not for Train Station Products I couldn’t get half the modeling done that I do.
Just checked the Alclad website and found a hobbyshop about a mile from my house that sells the stuff. Gonna pick some up and give i a try. Sounds like it will be just what I need for my N E-5 shells with a Zephyr scheme. Need to look as shiny as the 9911 out at IRM.
Hi guys,
Check out this link: http://www.alclad2.com/alclad-home.html
Impressive work by modelers, especially on that DC10!
Enjoy!
Tamiya’s “flat aluminum” is pretty close to weathered stainless steel. This stuff is actually a plastic-compatible lacquer. However, even though you don’t need a primer for it, I still primer my plastic cars before I spray them. That way, there’s less risk of chipping the paint.
Hey guys, something I forgot to mention…
If you should decide to try out the Alclad Chrome method there are two versions. One is “Chrome” and the other is “Chrome for Lexan”.
Use only the Chrome which is designed for styrene and similar plastics. The Stock Number is: ALC 107.
So go ahead and experiment! Try the Chrome and Stainless Steels versions.
I use Polly S Stainless Steel or Aluminum. They don’t shine like the Alclad does, but do have a pleasent weathered metallic sheen to it. The paint is a more fragile then regular Polly S, so take care when handling. I used glosscote to seal the cars.
Nick
What about that Bare Metal Foil stick-on stuff!
