Action around 1949 at South Hills Junction. The car with standee-windows is a 1946 all-electric; the others pre-WWII air-electrics.
Lived in the Pittsburgh suburb of Bethel Park from 1953 to 1955 and again for a short period of time in 1967. The cars with a âheadlightâ above the destination sign were considered âcountryâ cars as opposed to the âcityâ cars that did not have the light.
One house we lived in had the Castle Shannon line running at the back of the property across a small creek from the property line. From out 2nd house I would have to walk across the Library line at the intersection of South Park Road and Brightwood Road to go to school. In 1967 our house was on a hill above the Library line.
When the Port Authority took over from Pittsburgh Railways, and bus conversiuons started, the single-enfd, deck-roof, lightwewight Peter Witts were the first cars to be scrapped. But in 1949 there were many to ride. A downtown viewe:
A view from the Mt. Washington Incline:
Most cars were citiy cars and did not have the upper headlight.
A small group of double-end deck-roof Peter-Witt lightweights did have it and provided all service on the Donorra Shuttle.
A larger group of single-end deck-roof cars provided rush-hour cutd-back service on the interurban lines, including use just as far as Castle-Shannon.
About 25 arch-roof single-end cars were country cars, had very confortable seats, inlcuding a rear-facing âobservation-carâ seat at the rear, and were the mainstay of the through interurbans before the standee-window post-WWII 1700-series cars arrived, of which about 25 were country cars and then provided base service on the Charleroi-Roscoe and Washington interurban lines, with the arch-roof cars still used during rush hoiurs. I think only one of the preWWII air-electric cars was made into a country car.
The coontry cars had small pilots, âcow-catchers,â instead of the life-savers of the city cars. Also, I think the coiuntry PCCs had a modified or heavier truck, similar to what what used on the CTA âSpam-canâ 6000-series rapid-trransit cars.
Pittsburgh Railways had begun scrapping cars a long time before the 1964 PAT takeover. The loss of the West End lines in 1959 allowed retirement of many of the earlier PCCs as well. By the PAT takeover it was rare to find a PCC numbered lower than 1500 in service.
Pittsburg had 666 PCs, all bought new. Except for one car in the 1600 series which was all-electric, and the postwar 1700 series all-electrics, the PCCs were air-electric. All cars built by St. Louis Car, about 60/40 Westinghouse/GE, though most later cars had Westinghouse equipment. Pittsburgh car 100 was the first PCC used in revenue service.
The CTA 6000s, except for 6001-6200, used Clark B2 or B3 trucks depending on whether the trucks came out from under a Pullman- or St. Louis-built streetcar. 6001-6200 had new B3 trucks. CTA put a number of sets of experimental trucks under high-speed test cars 6127-6130 and 1-4. Car 1 still has its Clark B-20 trucks from those tests.
Then, refreshing my memory, some double-end deck-roof Peter-Witts outlasted some of the earlier PCCs! They were needed for the miniority of lines that lacked loops at both ends. The last line to use PeterWitts insstead of PCCs that reached downtown was the Evergreen Line, which was the route to downtown used by the Pittsburgh, Butler, and Newcastle interurban, and had a nortthern terminus with a simple crossover between the double tracks that obviously had continiiued further north. I had forgottejn that the west-end lines were abandoned before the PAT takeover. The conversion was forced on Pittsburgh Railways by the rebuilding of the Point Bridge with the citiy insisting no streetcar tracks.
One of the West Emd lines, Sewickly, could be considered an interurban, but was operated with city cars.
I recall the Clark trucks under the interutban 1700s as visibly different but donât know the details.
The last of Pittsburghâs shuttle lines requiring double-ended equipment was discontinued in 1953, the 38A Mount Lebanon -Castle Shannon Shuttle. Most of the shuttle lines were discontinued between 1950 and 1952.
The West End lines lasted until 1960, when the Point bridge was closed.
Pittsburgh âinterurbanâ PCCs 1700-1724 had St. Louis B3 trucks, the balance of Pittsburghâs fleet had Clark B-2 trucks.
Contrary to my earlier 60/40 division between Westinghouse and GE electrical equipment each series from 1000s to 1400s had 75 westinghouse and 25 GE. 1500s had 50 WH and 15 GE, 1600 and 1700 series went back to 75/25. 100 had WH. In each series lower numbered cars had WH gear.
Pttsburgh 1600 was the prototype all-electric car.
100 was later redesignated M-11 and used mainly as an instruction car. The 1500 series (1500-1564) was the âshortâ series, all other groups having 100 cars each.
I now remember the 1600s. They were a rare type, all-electrics without standee windows. Kansas City also had all-electrics without standee-windows, and I think the ten double-end Illinois Terminal cars may also have been all-electrics.
Thanks for the truck information. I had thought the B-3 was also a Clark product.
Pittsburgh 1601-1654 were air-electric and looked like prewar cars. 1600 had standee windows and looked like one of the 1700s.
PCC#1600, Rt. 76 Hamilton | Digital Pitt
The B-3 was definitely a Clark design. I think St. Louis built them under license.
Thanks for the correction and information, and it is great to have that terrific photograph.
But all the 1600s did arrive after WWII?
Also, the Mt. Lebanon - Castle Shannon Shuttle was not abaondoned, but incorporated into one of the rwo major through routes still operating, I believe now double-track. I do remember it as a single-track shuttle, but with loops at both ends, and at the end operated with a PCC car.
Bob Dietrich supplies the information that the three towers in earlier postings are the ventilation towers for the âLiberty Tunnels.â the twin double-llane highway tinnels constructed after WWII under Mount Washington.
He has a website with lots of information about Pittsburgh Railways, South Hills Junction in particular, an all-time car roster, and many beautiful photographs of a great model railroad, mostly streetcars and inteurbans, but also with 2-ft-gauge steam with Maine prototypes, modified for coal hauling. Recall that there was a steam coal-hauling narrow-gauge railroad at South Hills Junction, and that the via Overbrook (not the via Mt. Lebanon) route waa originlaly that steam railroad, and for many yeats was dual-gauge.
RC may wish to add and/or correct.
Some more pictures, for which RC msy wish to comment:
The former Castle Shannon shuttle was incorporated into a rush hour extension of the 38 Mt Lebanon line. Not long after the outer end of 38 was combined with 42 Dormont into the 42/38 so PRy did not have to do a track renewal on the inner part of 38. This is more or less the configuration the lines were in when PAT started the light rail conversion to route 42, todayâs Red Line.
One of the âfeaturesâ of the loops at Castle Shannon was the âmud switchâ, one of the reasons the 38A usually got double-ended cars.
The local service in Washington PA was operated by low-floor cars until it was discontinued, also in 1953. Those were single-enders, since the local line had a loop at one end and a wye at the other, also used by Washington interurbans from Pittsburgh.
All of the 1600 series were delivered in 1944, including 1600. It predated other all-electrics by a year or more. Some of the 1600s acquired by PAT were rebuilt to all-electric and given vacant 1700 series numbers. 1600 itself was destroyed in the Homewood Barn fire in 1955.
You remember only the last local Washington, PA line. There were two others in
1949, which needed double-end cars. At one time double-enders were used n all t
hree, including the one with loops.
So the Red Line Light Rail incorporates the entire Dormont Line from P&LE Stationn on, the former Liberty Line from the Dormont Line terminal to Mt. Lebanon. and the Mt. Lebanon - Castle Shannon Shuttle with former interurban tracks from there, where the via-Overbroook line is joined. Itâs all double track now, I beleive.
Two more photos:
l
The Red Line now goes under Dormont in a tunnel instead of running in the street. The Beechview segment is still street running.
The Overbrook line was built for coal by the Pittsburg Coal Co. and converted by Pittsburgh Railways to Penn gauge (though dual gauge track remained until 1916) and electrified for interurban operation in 1905. Conversion to the Blue Line (after a long period of operation as route 47) was completed in 2002.
Two more, on the Charleroi ibterurbanm possibly inCharleroi itself.
The actual southern terminous was in Rosce, about six miles further south.
One passing siding on the mostly-single-track line had the northbounf cars going through the Xharleroi Carhouse.
Another Charleroi interurban picture:
Three more:
Previous posting: 1st probably in Charleroi, 2nd 3800 interurban car turning into Liberty fom Grant, downtown Pittsburgh (in front of the PRR Station), 3rd, back at South Hills Junction.
