Enhancements of a photo posted esrlier:
From
Russ Jackson. |
From
Russ Jackson. |
Is M555 the correct number for this crane work-moter? There was a big white hole in the number as originally scanned, and I my best to piece together what remained, but I can be corrected on this matter. And location?
Edward H. Lybarger |
It is M555 on the inbound track at County Line siding.
Somewhere, the PCC we were riding paased a line-car with wiremen doing sometning, like checking a slice or remving slack.
Back to Suoth Hills Junction, steel RR-roof interurban 3703.
The folks on the line car are working on a new pull-off. At some point they will put a clamp and hanger over the other track. You can tell because the pull-off wire ends at the line car, and just crosses the other track without a hanger. You canât see the half-yoke hanger because the lineman is in front. The other PRyCo photos show the hanger types.
Thanks. A very infrmative comment. Infrmation on 3603 is from Bob Dietrichâs website (and his model railroad is most intereting):
Another June 1949 Washington Junction picture:
And Richard Allman provided a view looking south some 62 years later:
And Ron Yee of the existing new station, obviously quite different. I assume this is north of the actual junction:
I made a n error: The car I labeled as 3603, wod interutban, is 3703, steel.
I had forgotten Pittsburgh Railways had steel RR-roof cars:
Here is a side view:
Bob Dietrichâs website says Brill 1917. I think I have an explanation fr the extra-long trolley-pole. First, anyne else have ideas?
Still another view at South Hills Junction:
And another at Washington Junction:
And one more in Charleroi, with John Sternâs back to my camera while he is takinig a reflex camera photo:
When I first posted this photo:
I thought it was at the opposite end of the Washington, PA, East & West Line from this photo:
which Ed Lybarger identified at the west end of the line at Caldwell Avenue. I now think it might be at the same location, just looking in the opposite direction at the east end of the car after the operator âchanged ends.â Any commenta?
I believe older steel PR interurban cars had longer trolley poles because of spots of remaining high wire from the days when sercice was provided by heavy, high, large wood inzerurban cars. By the time PCCs for interurban service went on-line, 1946, wire hight was more uniform. Any comments?
Most pre-PCC PRyCo cars had poles that were longer than normal. In addition to having some high wire in downtown Pittsburgh and elsewhere PRyCo liked cars with long platforms (the overhanging part) and also liked to center trolley bases over the truck centers. From an overhead wire maintenance standpoint the tradeoff was a little more wear on frogs and tight curves in exchange for very reliable pole tracking. Poles flexing are common in old Pittsurgh photos.
Ed Lybarger confirms this and notes that 1711 in the Charleroi photo with John Sternâs back ti the camera:
1711 is northbound entering 7th Street Siding on Monongahela
and that two photos are indeed at the west end of the East and West Washington linr.
Here is 4908, a local car, not an interurban, route 17 for (Castle) Shannon only, after crossing the bridge over PA Highway 51 at Oak. Ed informs me that the area has been deveoped for many years, and only the high elevation of the RuW gives a false rural impression:
In the photo above on the right side track, there seems to be an outline of an inside rail. I understand the trolley tracks were wide guage. Could there be a trace of a former standard guage rail.
3-ft. gauge, not standard. Coal=hauling steam raiload, until 1914.
You may wish to review an earlier post wher I posted information from transit expert Russ Jackson.
The history of the Pittsburg & Castle Shannon is very tangled and and actually involves two gauges as the line was built to 3â4" gauge but later converted to 3â before Pittsburgh Rwys dual-gauged it with a 5â2" rail. Whatâs in the picture is a missing âbridge guardâ rail which was used on approaches to bridges (note the one in the background). This wasnât a running rail and was set to no particular gauge.
Pittsburgh didnât get the final âhâ officially until 1911, though it was in use on and off since the late 1700s.
I saw the bridge in the distance, but the rail ghost looked to far from the gauge rail to be an effictive gard rail.
Effective - maybe not. Standard practice - sure. They were a common feature on the Overbrook line. Doubtful if they were ever narrow gauge rails but even if they were they were set that way deliberately.
During rush-hours, some trips of the Mt. Lebanon line, via the tunnel to South Hills Junction and then Liberty Avenue and Beechwood, was extended over the Mt. Lebanon - Castle Shannon Shuttle route to Castle Shannon. In June 1949, although nearly all service on the Mt. Lebanon route was by PCCs, some rush-hour trips were still overed by single-end Peter Witts, as here downtown.
Fare collection inbound on Pittsburgh Railways was the usual one-man-car way, with boaring at the front door and cash or pass-display used fhere. Exit downtown via both doors. But trips from downtown, had boarding via both doors and exit only via the front dooe with cash or pass-display on exiting.
And back to Washington, PA, and another spot on the East & West local line
PAT continued the pay on entry inbound/pay on exit outbound well into the 1980s. It may still be in effect on buses.
