Did railroads in the 1950’s ever run commonly run short freight trains with a single F unit on the point?
I have found lots of pictures of trains pulled by a single GP-7 or RS-3, but very few with a single F unit. F units always seem to be in groups in photographs from 1954.
The deciding factor would be turning facilities at the end of the run. Most employee timetables from the 1950-1970 period when F units were plentiful greatly restrict the speed of these units when operating in reverse. Also, if you really want to upset your operating crew, give them a cab unit to perform switching with. That was one of the driving factors in the introduction of the road switcher. Of course there is always the odd exception like everything else in railroading. One railroad that regularly ran trains with single F units was the Wellsville, Addison and Galeton but, one could almost be certain the engine could be turned at each end of the run.
With no rear footboards or rearward visibility, F-units were not well liked by crews on local runs because there was a lot of switching and reverse running. In the mid 50’s with the introduction of GP7/9 switchers, F-units were used in through trains or unit service where there was very little or no switching to be done on line of road.
Keep in mind these locomotives were bought before two way radio systems became common so this was a major point of contention.
Short freight trains generally were local way freights, picking up and dropping off cars. Technically, you could do that with a single F-unit, but due to the lack of rear vision for the crew, it was harder than with a road switcher. Plus, many such trains would be on branch lines. Railroads bought GP-7s and RS-1s in some cases specifically to replace steam on branch lines, so that they could eliminate having a turntable at the end.(Yes I know the Ipswich and Dippsidoodle Railroad or whoever operated branches with steam running backwards on part of the trip, but railroads generally tried to avoid running steam backwards pulling trains when possible.)
Not sure when, but seems to me at some point a regulation was put in to not allow F-units or similar engines (Alco FAs) to be used in any type of switching service??
The Nickle Plate road tested the F7’s against their Berkshires and ordered more Berkshire’s instead. The major complaint was the F7’s could not be easily used in the many switching moves that were required on the railroad. The NKP never had any Freight covered wagons and dieselized finally with GP7’s and their successors.
By the way the Berks’ had radios installed for communications, which is why they had three generators on their boilers.
If I uderstand all this correctly… F units were rarely used individually because most short freight trains that would require only one diesel locmotives would need to do switching while on the road, and this was difficult with an F unit. Instead, F units tended to be used on longer through run trains where multiple units were needed and they would be arranged with a cab unit on both ends so they would not need to be turned at the terminus.
That’s a pretty good general rule. There were exceptions, but most major mainline roads considered cab units to be road engines, usually in multiples; and road switchers were usually thought of as general purpose utility engines. As such, road switchers could be used in yards, on locals, work trains, passenger trains, or as helpers or mainline power in multiple. Nevertheless, I have seen single F units at the head of through freights on major mainlines at times of motive power shortages, and I know of situations where cab units were used on local freights. Poor visibility made this highly undesirable, and even dangerous. I also remember seeing a single Baldwin Shark A unit hauling a high-wide load westbound on the PRR mainline through Orrville, Ohio in the early 1960’s. The train consisted of the Shark, a flatcar with the oversized load, and a PRR cabin car. .
The Escanaba and Lake Superior used its one running Baldwin Sharknose singly on way freights while it still was able to run, and they didn’t have turning facilities in many places. So it was done.
Of course, when you’re a northwoods shortline with a ton of 10 mph trackage it’s less of a strain.
It may be helpful to understand how railroads diesels in the 1st generation era. Railroads were used to buying specific steam engines tailor made to their specs for the freight or passenger trains they wanted it to pull. When they started buying diesels, it was the same thing. Four unit sets of F-units (usually two drawbar connected A-B sets running back to back) would be bought to replace freight engines like Mallets or 2-8-4 / 2-10-4 types, with all four units considered one ‘engine’ and often having the same number, like 800A / 800B / 800C / 800D. (Partly, this was because work rules at the time required each ‘locomotive’ to have an engineer and fireman, so they didn’t want to have to have a full crew on each engine in a four-unit lash-up.) PA or E-units would be bought in sets for the top passenger trains, with GP-7s or RS-1s for local wayfreights, and end-cab switchers for yard work.
By the time railroads started to understand the ‘building block’ idea - buy a lot of interchangeable 1500 HP diesels and use 1, 2, 3 or more together as needed - they also were realizing that F-units weren’t that great on things like wayfreights. That’s also part of the reason that railroads that dieselized late, like the Missabe Road for example, never bought F-units in the first place. By the 1960’s, many of those early F-units were being traded in on new GP or SD or other road-switchers.
I have seen photos of an Aberdeen & Rockfish F unit used “solo” to haul a freight train. I also think I have seen a similar photo of a Santa Fe F unit on a branch line freight, similar to what the Soo Line did as per Jim’s posting, above.
Somewhere on these Forums, on a thread long ago and far away, someone posted a wonderful photo of an F unit equipped with footboards on the front to facilitate local switching (presumably there were no footboards on the rear of the unit just the front). I have some recollection that it was NYO&W.
Maybe railroads and the manufacturers did not feel forced to make design changes due to crew complaints and comments about locomotive design inadequacies, but the railroads surely noticed the dollar impact when work started taking longer or caused more injuries. EMD created the BL2 to address the sightline issues caused by F units even as the obvious and eventual “road switcher” solution of side walkways was staring them (and Alco) in the face.
Oddly it was Alco that had the first true road switcher the RS-1 in 1941…EMD would stumble and fall with the BL-1(one unit) and the BL-2(57) until 1949 when EMD released the GP7.Alco released the RS-2 to compete against EMD’s GP7 in '49.
The BL-2 suffered a lot…The EMD designers did not like it,the sales department did not like it and above all the Railroads did not like it.
I believe the STRATTON & GILLETTE dieselized early. My roster consists of eight F units arranged as follows:
F7 ABA set for express freight train.
F7 AB set for express passenger train.
F3 AB set for manifest freight train.
F3 A unit for short freight train.
I guess I will add another F3 A unit to that last one and have another set that will not need to be turned. That sounds more plausible than what is current.
I also have 2 GP-9, 1 SD-7 , 1 Trainmaster, and 1 RS-1. Road switchers are not as prominent on the SGRR.
I think I will add a BL-2 to replace the single F unit on that planned train. Proto-2000 BL-2s are not too hard to find.
Doing roadswitching with a single F unit “backwards” seems curiously similar to doing the same thing with steam road power. Except, of course, there’s footboards on the back of a tender.
Now, if you’re switching with a four unit F set, the nose of the other F will have those teeny little steps, for your safety and convenience. A person could wonder if the engineer walked back to the other cab to do the reverse operation.
Ed,The engineer would simply turn the seat sideways and lean out the window like he did on a steam engine or the head brakeman would relay the signal to the engineer.
Your plan sounds reasonable. You have focused on EMD power, with one small Alco and one large F-M unit. You might consider other options instead of the BL2, such as a Fairbanks Morse H15-44 or H16-44 (Atlas) or an Alco RS2 or RS3 (several sources). And of course, Baldwin was a player (Bowser).
You could also operate your single F3 back-to-back with one of your GP9’s. That would give you a road set that doesn’t need to be turned. However, this was rarely done in your 1954 time period, except in emergencies. It became a much more common practice in later years.
Found this on earlier threas - no othe info Picture link broken and website gone:
F-unit road switching
Posted by Lyon_Wonder on Sunday, August 03, 2008 3:42 PM
20 or so years before starting their CF-7 rebuild program, ATSF tried to use a handful of F-units as road switchers by adding footboards at each end. Even with the footboards, I doubt the conversion was very useful since the cab still had poor visibility. This is similar to EMD’s briefly-marketed BL-2. This was the first time I’ve heard of this being done to an F-unit. In recent years, some former Amtrak F40s had footboards added to the front and rear too, and they are probably about as useful as F-units in yard switching too:). The pic shows a “cat whisker” FT in this configuration, which means the conversion was done sometime around 1950.
