Some Basic Ques. re locos rattling around in my Brain.
Not a very well-informed brain re locomotives. But I have been wondering:
  1. I know the advantage of diesel-electric locomotives over a straight coupling (via a transmission say in a caterpillar earth mover) of a diesel engine to driving wheels is the full torque even at low speeds. But what is the actual physical mechanism of that? As the traction motor receives “juice” from the ramping up diesel via the generator, what factor is at full play at all speeds…is it amperage, voltage or what? You can tell I am not conversant, but curious.
  2. What was the limitation to the DC traction motors? I heard that the actual physical wiring, coil size etc. has limitations in DC, such that the higher power required means unmanageable sizes of physcial wiring etc. Is it that the AC current is only energizing the coils half the time that give the edge to AC over DC in efficiency so that they can be of useful size even carrying huge currents?
  3. In loco information where is sometimes is said that various types of trucks are swapped for another, say in a rebuild do the traction motors always mate in some universal way? So if the old AAR trucks say, are swapped out for Blombergs or HT-C trucks, are the traction motors kept or do they have to be matched to the type of truck coming in, or do they come in a set of trucks with traction motors?
Just wondering.
Well #3 is pretty easy just wires to the motors but there is also a blower duct so a fan can blow air on them to cool them. Don’t know if this is a universal location or not.
Hello,
On #1, I’m not sure.
On #2, the limitation on DC motors is that they overheat if run at slow speeds for long periods of time. AC motors can stand much hotter temperatures, as well as other advantages, such as less complexity and better dynamic braking.
On #3, I believe that the same traction motor will fit on HT-Cs, Blombergs, and AAR-Bs and AAR-As.
Voltage and current go opposite of each other. Current “does the work”, voltage is “the pressure” behind the current. Think of it as a garden hose. With no nozzle, maximum water flows, but the stream doesn’t go very far. Put a nozzle on, not as much water flows but it flows more forceful and a lot farther. At starting you need maximum power. Thus maximum current goes to the motors. As speed increases, less force is needed to do the work, so voltage increases and current decreases. A generator has a maximum load, lets say 120 watts for example. it can provide 12 volts / 10 amps or 120volts at 1 amp. Either way it’s 120 watts. It can’t go more than that.
Matching the right combination of voltage and current to the particular load on the locomotive and particular RPM - throttle setting of the diesel prime mover is the job of the load regulator equipment, which includes the governor that controls fuel supply and these days by electronic control the field current to AC-generator (“alternator”). These days it is all done by “smart electronics” computer control. This equpment also includes the speed of the invertor that delivers ac to the field coils of the hysterisis-non-syncronous or induciton motor. With modern ac motors and ac generator it is possible to match what is delivered to the traction motors for even better than 90% efficiency of diesel prime mover HP to the rails. In DC days, much was done with relays and with some loss is callibration resistors, and the efficiencies were between 85% and 90% depending on type of service. DC motors require commutators and brushes, which are serious maintenance items. The commutator windings that can overheat on a dc motor are replaced by rotating aluminum or copper bars in an AC motor, and these can stand far, far greater heat. So the only windings that can overheat on an ac traction motor are the field windings, and because they do not rotate, they can be much more robust. They will overheat of course, long before the rotating bars could be deformed by heat, so there still is a limit on current for ac motors but it can be as great as five times that for dc motors. In general, ac diesel electrics are limited in tractive effort only by their wieght and not by the limitations of the ac motors.
Overheating occurs when the current in a coil is so great that the resistance of the wire produces so much heat the insulation starts to fail. With the oldest diesels, with cotton insulation, it woujd actually burn. Modern plastic insulation will melt, and the short circuit will cause brreaker to trip and the locomot
  • Amps can be translated into “power” for this…the more amps you push into a DC motor, the harder or faster it turns, (pulls for us)…voltage play a part…kinda like an octane rating for a gas engine, the higher the voltage, the more amps you can feed the motor.
  1. What was the limitation to the DC traction motors? I heard that the actual physical wiring, coil size etc. has limitations in DC, such that the higher power required means unmanageable sizes of physcial wiring etc. Is it that the AC current is only energizing the coils half the time that give the edge to AC over DC in efficiency so that they can be of useful size even carrying huge currents?
DC traction motors can and do “stall”…in that they can no longer overcome the physical forces of gravity and mass…when that happens, the brushes begin to arc to the commutator (the part that switches the polarity) and can burn a section of it, ruining the motor…and as stated, the windings and feed cables can over heat due to the high resistance created.
AC motors have no brushes, and even if you stall them, they will not overheat in the same manner as a DC motor…(think ceiling fan)…AC motors in simplest form simply switch magnetic fields, with no electric exchange between a brush and commutator, therefor under stall cond
