The purpose of this posting is to clear up some misunderstandings.
Normal DC Traction Motors: Require brushes, which provide electrical contact to the rotating commutator that has connections to the rotating armature (on the same shaft). Permanent magnet fields may be used in model trains but the real ones have dc coil fields. High efficiency, but requires brush maintenance. They do wear out. Stalling under continuous current under load can burn out the coils through heat build up.
Induction Synchronouse Motors Used early in a few tunnel electrifications, these are constant speed motors. Not very practical, but were used in the first Cascade Tunnel three-phase electrification. No brushes required and more difficult to burn out though overloading.
AC commutator motors. This is basically the first kind of motor, with with compensating coils to reduce hysterises lags from the alternating current. Such a motor can be used both on low-frequiency (like 25 cycles per second) and DC. New Haven EP-1 through EP-4, EF-3, PRR P-5 and GG-1 had this type of motor. Not quite as efficient on ac as on dc, and does require brush maintanance.
Hysterises non-synchronouse motor. This is like a squirel cage or regular induction motor except that the rotaing copper or aluminum bars that have the induced current are slanted, rather than straight across. The development of this motor, quite efficient and resistant to stalling and burn-out, depended on computer technology and solid state switching so permit field coils to be powered in the right sequences with proper timing and current for the speed and load conditions. This is the type of motor on all current ac-motored diesels, electric locomotives, and ligh rail cars, except as follows:
The wheel motor: This is an inside-out motor, with the field coils stationary on the axle and rotating permanent magnets or slanted copper or aluminum bars, the first considered possibly as an inside-out dc moto
daveklepper, you are boss! II love the tech talk about electricity and electric motors! Why don’t they teach this in our high schools instead of social analysis and party planning!
Perhaps our European friends would enjoy hearing that, very early in the 20th Century, North America might have adopted DC as the standing household current. But DC by its nature has to have its transmission “refreshed” by means of a booster station or intermediate way current station (surely someone out there knows the correct term?) – several times more than AC. In essence, Thomas Edison had hissy fits until AC became the American norm.
On a recent trip to Las Vegas, halfway to the southern I-15 border at Primm, NV, I saw such a “whatchamacallit” electric facility out in the middle of nowhere where there were no residents, agriculture, or industry, just I-15, Uncle Pete’s banged-up diesels, and the electric wires; about 22 miles from anything else either direction.
In Europe with its, I believe, 220V standard, such “refreshers” have to appear much more often, but they’re hidden by other aspects of civilization. Recall that in the greatest number of EU countries one is rarely out of sight of the next town or village – no real Mohave Desert to cross grid wires with.
There is practically no “hinterland” left in Western Europe. But America still has a lot of hinterland. Some people believe that this (relative) isolation creates isolationists politically – the red-state effect to use an increasingly inflammatory but nearly meaningless term.
Your “refresher” is a “substation.” Actually, all long-distance transmission both in Europe and in the USA is at very high voltage, not house current voltage, and then the substations bring it down to intermediate voltages, and then transformers near or innsde homes bring the voltage down to 115V 60 cycles per second (“Hz”) in the USA and 220V, 50 Hz in Europe. Until you reach the home, transmission is three phase, and there are usually five wires, the three active phase wires, a neutral, and separate from the neutral is ground. If everything is OK, there should be zero voltage difference between neutral and ground, the voltages between phase wires should be close to identacle, and ditto from phase wires to neutral. Modern electronics makes possible high voltage transmission at DC, and this has even less loss over long distances than the same voltages and currents at AC. The Finns generate some of their own power but also buy from Russia. They had all kinds of problems with fluctuating voltages and phase or frequency with the power from Russia, so they put in a high voltage DC link and have eliminated the problem.
At the transformers to house voltage, the attempt is made to divide the load among the three phases. Perfect match at one street or at one home or set of homes is not required, because despite variations locally, the overall balance can be maintained by the randomness of loading producing averages that are nearly equal.
All AC diesel electrics are somewhat similar in that three-phase alternators can be used. But so can single phase, like the alternator in a car including hybrids. Note that electrification, you can have any combination of current source and motor type you want, today. The Virginian and Amtrak E-60 and New Haven EP-5 electcrics picked up high voltage AC power (except the EP-5 in New York Central third rail territory) and used dc motors. The AE-7 and Acela are all-AC. The tyypical most modern low-floor European tramcar and the latest New York
Do 3 phase AC motors exist? In the US some motors, typicaly HVAC equipment can run on either 240V or 208V. If I understand correctly, 208 has 2 phases 120 degrees apart instead of 2 phases 180 apart. How do these motors compensate for that? Would a 3 phase motor produce smoother torque?
3 Phase AC motors are actually the standard for industrial use. They are very efficient. A 2 phase motor with the phases 120 degrees apart would not run very well. Generally when someone specifies a motor to operate on 208 volts instead of 220 or 240 the reason is that they live in an area that suffers from serious and frequent voltage sags. A motor can absorb slighly higher voltages much better than it can lower voltages. By purchasing a motor that will operate efficiently at the lower voltage they are protecting their operations from all but the worst voltage sags.
The AC commutator motors are also known as universal motors as they run on AC or DC. The motors in Lionel and American Flyer toy trains are this type.
Motors are specified for “208/240 volt” operation because they are designed to be used on normal house-supply voltage (240 volts, actually two 120v. circuits 180 degrees out-of-phase) OR on 208 volts, which is the phase-to-phase voltage of three-phase power that is normally supplied to (small) industrial or commercial users.
I worked at a TV station that had only 3-phase (120/208) power. To install a window air conditioner, we used a small transformer to boost the 208 v. to somewhere around 232 v.
Ye gods, there’s some wacky stuff out there!
208V is, by definition, a three-phase rating (that weird-looking number is the resultant). Not at all ‘unusual’ when you recognize the physics involved. You were right about the 120 degree phase angle… but note that there’s little advantage to having traction motors – which one assumes are intended to run smoothly – with ‘two phases 120 degrees apart’. You can indeed build a motor to use such a supply, but it wouldn’t turn smoothly, as the definition of phase assumes ‘per cycle’, and the 2-phase 120-degree power would produce no torque for 1/3 of each rotation…
Europeans had synchronous AC systems, too; at least one of them was a three-phase system with multiple collectors. I believe the AEG high-speed electric test car in the very early 1900s (which went to speeds well over 100mph) had three separate collectors vertically spaced on a mast. This stuff is very efficient when train speed can match the motors’ synchronous speed as expressed through the gearing and drive, but torque getting up to synchronous speed is not as high, and overloading that makes the motor speed drag down below a certain percentage of synchronous can result in the motor more or less abruptly dropping out and losing power. So where you saw this stuff was predominantly on mountain grades or in long tunnels, where you could start more or less on the level and get to synchronous speed, not have to go very fast or accelerate very hard, and then work the train consistently at the synchronous speed through the entire track range where efficient high power was desired.
Technically, the problem with overheated motor coils isn’t that the copper in them melts, it’s that the insulation on the wire melts and causes short-circuiting (which then can melt the copper, but perhaps more importantly causes significant loss of magnetic-field generation (which is what actually causes the motor to develop torque) because there are now fewer loops to produce the B-fiel
[8)]
Overmod, I deserved the good whoopin’ you gave me. Guity as charged about being really, really ignorant about “American technical history”; in my high school – mind you, this was 30 years ago – there was no course in engineering, nor even pre-calc; just physics that had to do almost entirely with the Newtonian system, next to nothing about electromagnetism, and nothin’ at all about electronics, elec. engineering and so on. (If you think this thwarted would-be engineers and architects, by gum you’re right–the error was eventually eliminated). But in my case, I left high school thinking that “Dynamo” was the name of a liquid laundry detergent.
Anywho, I bet you (and a couple of others on this post) can tell me (us) why the Chicago CTA’s “L” cars exhibit almost no brake screech when they come to a halt at the station. In my dark past of READER reading, I think I remember the term “linear induction,” in the sense that the some motors impelling forward motion could be used (in reverse??) to slow the train down to about 4 or 5 m.p.h., leaving the brakes free for relatively light duty, which I guess would mean not having to overcome so much inertia (impetus), the brakes just didn’t wear out as quickly or in the same way–or perhaps a better Newtonian way to say that is that there was almost no need for the brakes to convert energy/momentum into energy/friction heat (??)
But since every time I make a suppository remark (?) I get busted[:0], and rightly so. Is there truth in the above paragraph, notwithstanding the fact that I probably abused about half a dozen terms? [:(]
Here’s another thought for food–in railwaying, or interurbaning (CSS&SB), or light rail, does third-rail or “shoe” tend to make use of differing currents whether it draws from catenary or shoe; or whether it’s AC or DC? (Is there a clever term that means “whether current is AC or DC”? “Modes,” or something like that.)
Y
Oh my gosh, I have such a headache since reading this thread as my brain has tripped out (no, not that kind of trip!) on information overload…seriously, you guys are really wonderul and full of great information on this subject. Thanks, Jim
Again, both the regular “comstant speed” induction motors and the nonsynchronous hysterises motors do not require bruishes or sliprings, because the current is induced in their rotating bars by the magnetig field of the field coils which are fixed and which have the computer controled waveform described, which is derived from dc or semi-dc, when then comes from usually single-phase ac from the catenary or the three-phase ac provided by the alternator on the shaft of diesel. Why are the bars slanted? A simple, but possibly not extremely accurate answer, is to point out one bar is then capable of slipping between one field coil and another at a different rate than the magnetic field rotation produced in the field coils. The hysterises effect can be roughly defined as magnetism continuing to exist for a while after the current producing the field ends. If this seems like gobbldygook to you, it may reflect my still imperfect understanding of the precise physics involved in this effect. We all know what a permanent magent is (and for the sake of Stored Emergy Technology’s and Magnet-Motor’s Wheel-Motors or “Hub-Motors”, I hope their permanent magnets are permanent", but even ordinary iron/steel field magnet cores have a bit of pemanency, they don’t just switch off the magnetic field when the current stops. The rest is matter of geometry, this effect can be exploited by the slanting bars, but not the straight across ones.
[quote]
I worked at a TV station that had only 3-phase (120/208) power. To install a window air conditioner, we used a small transformer to boost the 208 v. to somewhere around 232 v.[/quote
It is possible that the small transformer was installed for the purpose you state, but it is much more likely that it was installed as an isolation transformer to protect the motor in the air conditioner from the radio frequency “noise” that the TV station equipment puts on the power. Unprotected motors tend to burn out the first winding of the stator if there is a lot of RF harmonics in the power. Isolation (otherwise known as smoothing) transformers are very common where there is equipment like transmitters, variable frequency drives and the like.
Just a slight addition to Overmod’s excellent commentary, and relating to rdganthracite’s commentary…
on 208 volt vs 240 volt 3 phase power vs 120 volt (in North America) ‘household’ power.
Without getting too technical… oh dear…
The 120 volt/ 240 volt household power North Americans are familiar with is derived by a transformer (you see them mounted on poles or on the ground quite often) from two of the three wires from the power company’s power station. The voltage between those two wires could be almost anything, but 23,000 volts is pretty common (yes, that would fry your toast pretty quick) and the transformer reduces that to 240 volts, ‘single phase’. There is also a third wire, which goes to the centre of the transformer’s output, and is connected to the ground (the Brits refer to it as the earth, which makes a good bit of sense!). So it you connect a light bulb, for example, from one of the two outer wires from the transformer and the third (ground/earth wire – or, more exactly, the ‘neutral’ wire) you will get half of the 240, or 120 volts, whereas if you connected it (don’t!) between the two wires from the ends of the transformer, you get 240 volts (for your electric range, for instance).
Now if you go look at a utility company’s power line, you will see that there are also three wires up there (or six). But they aren’t similar to the three wires coming into your house. Rather, they are arranged so that they provide what is termed three phase power, in which there are three different currents available, with the peak voltages on the three different currents (oh dear – this is getting complicated… trying to explain three phase power without using trigonometry is difficult!) occur in succession – in North America, again, the three currents peak 1/180 th of a second apart, with the whole thing repeating 60 times per second.
Now the hard part. If we take all three of those wires,and hook up three transformers to make three hous
