I would like to know a little more about spring switches. I assume that most sidings (that are so equipped) would have them at both ends. To enter you would have to manually open them, right?. Would the trainman have to wait to line them back? Do they show their alignment the same as other switches? This has probably been discussed here many times but I haven’t caught it, so I am asking you all.
Since the points would spring back to the default position in a trailing move, it is not necessary to line the switch back… In all probablity, the location of spring switches would be noted in the Employee Timetable, and there would be a sign (at the points?) showing “SS.” I am not certain, but the target/light on the switchstand I believe would indicate only the position determined by how the switch was thrown manually or by remote control. not by how the points are moved by a trailing movement.
If you enter a track (facing points move) that has a spring switch, the switch must be lined for that track and then lined back, since the spring works only on trailing moves.
In the last 30 years spring switches have increasingly fell to the wayside. This is because of the increasing popularity of Centralized Traffic Control (CTC) that maximized track efficiency and return on investment without great expense.
Spring switches of yesterday were most popular on double-track (NOT two-track) lines, where each of the tracks were Automatic Block Signaled (ABS) in only one direction, and each track had a current of travel. To get out of the way of a faster train, a train would stop, thrown the switch, and enter the siding. The caboose crew would normalize the entrance switch when they were off the mainline. Once the faster train passed, the head end crew would just head out onto the mainline without having to throw the switch (the weight of the locomotive moved the points), nor would the train have to stop so the caboose trainmen could throw the switch back, because the points would just automatically ‘spring’ back to normal with the last car’s passing, hence, the term spring switch.
Old time railfans grew up with double-track ABS, so knew the term well. Today’s upcoming crop of railfans hardly experience one train passing another in ABS territories, hence, it is not surprising this thread’s question surfaced.
I see them everyday, they are the best thing to have in dark territory as it speeds things up from not having to walk the train. The spring switch will have an indicator light either green or red to let you know the position of the switch. A few miles before getting to that switch will be a non automatic block signal which will tell you in advance what the position of that switch will be. You get either a clear or an approach. Spring switches can hang up, they can also get debris in the points which will cause the switch to not line back to the main. This is why we have the signals ahead of time to let us know so we dont round a curve and find a red switch marker light and a switch that did not spring back. Bad news at 49mph.
Spring switches were the standard practice for classic single-track streetcar lines. Both ends of the short stretch of double track that would constitute in railroad terms a main line and siding would have spring switches, usually insalled so a streetcar entering at either end always takes the right-hand track. Typical applications included the Counsel Crest line in Portland, OR, the Warburton Avenue, Neperhan Avenue, and Tuckahoe Road lines in Yonker, NY, the Charleroi and Washington ¶ innteruburban lines of Pittsburgh Railways, the entire West Penn system, and many, many more. Also, on double track lines using double-end streetcars, there would be trailing crossovers, with both switches spring switches. A “short-turn” streetcar could thus simply end its run short of the end of the line, by reversing and allowing the spring switch to cross it over to the opposite track for the return move. In Manhattan, the Broadway - 42nd Street line (1st Avebue and 42nd Street to 129th Street and Asterdam Avenue) had short-turn trailing crossovers at 3rd Avenue, 5th Avenue, 57th Street, one on the 10th Avenue tracks at 72nd Street used by cars from the north reversing, and 106th or 107th Street.
Of course, for some emergency purpose, it was always possible to defeat the spring action.
Most streetcar switches were constructed with only one movable point, the :ouside rail of the curve. Where the inside-curve point would be located, there was simply a flangeway that divided to tow paths.
In Jerualem light rail, all switches are powered, controlled from a central locaton, and all have two points.
The South Shore Line is single-track east of Gary and most of its passing sidings (generally around a mile long) are equipped with spring switches at each end. This set-up made meets both scheduled and unscheduled a lot easier to arrange and was sometimes described as a “poor man’s CTC”.
This is somewhat of a rare use for a Spring switch that centers at Garden City, KS. Yrs ago the siding in town was about 12000ft w/ Spring switches at both ends.Later a crossover was installed about 1/3rd of the way east of the west switch. The trk to the east of the XO was the 'siding" while the trk to the west was changed to a storage yd trk. However, the west spring switch was never taken out and still remains in use to this day. So basically you have a yard trk protected by a spring switch. Not a very efficient when switching and having to line such a device several times back & forth. Also a good way to define how a spring switch works to someone who may not understand how it works can be made simple comparing such a switch to a screendoor w/ a spring on it: open the door manually and the screen on the door will allow it to close on its own.
The reason spring switches were more prevelant on interurban and streetcar lines than on major freight railroads was the matter of wear and tear. When a train moves through a trailing spring switch set against its route for the oncoming traffic, the points move back and forth with the passage of each axle! With a single streetcar or interurban car, that is four times, but for a 100 car freight train with say a good 2-8-2 steam locomotive pulling, that is 406 times, or 410 times with a caboose.
Strasburg uses spring switches on their sidings to minimize crews having to throw switches at each end where the engine runs around the train and at the grove siding mid-way where two trains meet, when they run two trains.
There are several situations where I have seen them. One is at the end of double track in ABS territory so trains going onto single track could continue through without stopping. Another is in CTC, where a siding has a power switch at one end and a spring switch at the other, thus saving the cost of a switch machine and its controls. When setting up meets the dispatcher was forced to put trains into the siding based on direction, not priority. Since the switch returns to normal after the train has passed through there is no need for the train to stop or a crew member reline it. But if for some reason the train stops and has to reverse, the switch has to be manually lined FIRST. I have also seen a crossover with a power switch at one end and a spring switch at the other. A balloon track is another situation where a spring switch can be effective.
On a main track I think it safe to say the switch will always be protected by signals. An oncoming train approaching the facing points needs to know positively that the points have returned fully to the normal position. A switch hung up part way over is a certain recipe for derailment. Even a reversed switch may result in a derailment if the train is travelling too fast.
Good point. To counteract that, some spring switches (and spring frogs) are/ were equipped with hydraulic dampers/ ‘dashpots’ / shock absorber-like devices which slow and delay the spring-driven return of the switch (or frog wing rail, etc.) for several seconds. By then, the next wheel/ axle is usually passing through, so there’s much less cycling back-and-forth until the last axle of the last car clears the switch, minimizing that wear-and-tear.
While not a Spring Switch - back in the 70’s there was a lot of advertising for Racor Switches. The Racor switch could be trailed through and line the route that you could then shove back through without having broken the switch lug as happens with a standard hand operated switch. With previously run-through switches being a leading cause of yard derailments, this just seems to be too simple of a fix.
I haven’t seen or heard much about them in the present world.
Sounds like a 22-P/ 22-E variable switch stand (not a spring switch)…thousands of them out here in yards (never on a main track), often called a “barrel switch” by trainmen, it has a large coil spring under the barrel housing…competitor for the CTM/Pettibone Hub Safety Switch and the much older Racor/Ramapo Ajax box stand variable switch. All use some type of spring to cushion the points and rods when lined over under the weight of (force of) the railcar wheels pasing over the switch points.
Nortrak/RACOR and CTM/Pettibone are still cranking them out. The old box stands are museum pieces, haven’t been made for years.
I always heard they “cost too much to maintain”. Yet calling hulchers out and shutting down part of the yard for a day, fixing equipment,and having trials always seemed expensive to me. Guess I don’t see the “big picture”.
I worked at a small yard for a mill that had switches you could run through. I heard some of the hoggers would play a joke on new conductors that didn’t know about those kind of switches. They’d go down the ladder plowing through all the switches as the brand new conductor is convincing himself that he is now fired.
Out here BNSF has a fancy switch on the mane lion that the conductor called a “poor man’s interlocking”.
When taking the siding, he would climb down ahead of the locomotive, and would align the switch with a pumping action. He would climb back up onto the locomotive and when the entire train had cleared the switch it would snap back to the main line. I do not know the electronics or the mechanics involved, but these appeared when the caboose disappeared.
