Suspension bridges on railroads seem to be fairly rare. I can only think of three of the top of my head. The Niagra River Bridge and the Manhatten and Williamsburg Bridges which are used by both cars and the NYCTA Subway. Is this because suspension bridge decks move around too much for trains? Or is it that carrying heavy trains would require bigger heavier cables?
Also are there any examples of the suspension bridges cousin, the cable-stayed bridge being used to carry rail traffic?
Most likely the railroads don’t use suspension bridges because they move from side to side. The Mackinaw Bridge is able to sway 25 feet left to right! Of course it is 5 miles long…
Suspension bridges use the cables attached to the (usually) 2 towers, not the tower itself. if the cables snap, so does the bridge. the actual bridge part goes through the towers. not attached to the towers, like many people think.
A suspension bridge deck could be made sufficiently stiff to support the weight of trains. But it would be so expensive to fabricate and erect the cables, towers, and anchorages that a truss or arch span would be less expensive, which is the case so far. The suspension bridge has a very low dead-load to live-load ratio, which makes it a very good choice for very long spans where live loads are low. Railways inherently have large live loads. In fact, in large truss bridges – either simple, continuous, or cantilever types – the live load of the train is quite small compared to the dead load of the bridge.
I’m not aware of any cable-stayed bridges supporting freight or heavy passenger train loads, but some are in use for trams, streetcars, and other light-load rail passenger vehicles.
…A 15,000 ton train would impose much of it’s weight to the bridge as it crosses…Wouldn’t that require much, much heavier construction materials to handle that much weight…?
If you look closely at all three bridges you mention, you will note that in addition to the normal vertical suspender cables, they have diagonal brace cables as well (so does the Brooklyn Bridge, which also carries the subway). You are partly correct in the move around too much, but not only do they sway sideways, which is not a happy thing, but if you were to start or stop a train the longitudinal forces could be quite large, and cause the deck to move longitudinally. Won’t go into the dynamics of it here, but that longitudinal would cause the cables and deck to rise in the direction of the applied force, and fall in the opposite direction; end result, most likely you would get very wet.
In addition, as others have noted, suspension bridges are not particularly designed to handle large, moving, concentrated loads – which is what a train is. They could be, but you would lose most of the advantages.
Cable stayed bridges are a different story, although again you have both the longitudinal forces to contend with as well as the concentrated moving load. Haven’t done the arithmetic, but my gut feeling is that the cables would have to be much bigger and the deck stiffer – and again you would have lost most of the advantages.
Note that subways and interurbans and the like are very very light in comparison to a ‘real’ train.
If memory serves me correct there is also a suspension bridge (or a close kin) at Woerden. Where there is not a normal concrete flyover but a modified one with a long concrete trough hanging over the tracks.
An old bridge is the one still in use on the “petit train jaune” / ligne de Cerdagne in southern France (in the Pyrenees Orientale), an electrified narrow gauge line that connects a French branch line with the Spanish’French border station of La Tour de Carol. It is on the Gisclard system (named for its engineer). youtube has a couple of items on this line. Try this one: http://www.youtube.com/watch?v=VJZuaE30R2Y . The bridge appears around 1:10, 4:30 min and at the end.
There is a huge suspension bridge in Denmark that I’ve traveled across many times by train & car. It’s called the Great Belt Fixed Link and is quite impressive. I’d post a photo but our internet poilicy here at work is tight. A Google search gives good results, though
If my memory serves me right did not the Japanese recently complete a suspension bridge connecting two of the countrys Islands with high speed rail. By recently I mean within the last five years.
A suspension or a cable stayed bridge would probably cost a $100 million or more to build, and a railroad would probably beg their congresscritters to get taxpayers to pay for it, not to mention the weight of heavy freight other posters mentioned. Truss bridge construction isn’t as popular as it was decades ago. Most recent long-span highway bridges are either box-girder, concrete or cable-stayed. However, practially all long-span railroad bridges in the US are truss, and many on the mississippi river were built a 100 years ago or more. Many of these are low height trusses with swinging or vertical lift spans. If any of these bridges are replaced, the railroad would probably opt for a box girder or concrete span, or maybe a bridge with a single large truss span and concrete approaches, like the recent I-72 Mark Twain Memorial highway bridge across the Mississippi at Hannibal, MO.
