Let’s see if we can brainstorm and get by the theoretical limitations of speaker size and sound wave length. What can we do to create a realistic sound environment? Let’s not get too involved with “reality.” Rather let’s look to expand the envelope. I’ll start with two ideas.
Stereo or quad speakers that broadcast sound based upon the location of the decoder. In other words. A computer circuit picks up the telemetry of the loco (or anything else) and adjusts the sound balance to appear to come from a specific location. A single sound device can then generate sounds to appear at any location on the layout–sawmill at G3, creek at H9, dirt bike at A2. There can be a library of sounds or you can record your own. Sub-woofer under the layout, of course.
This might be tougher.
Create a larger sound wave that a speaker can handle by staggering sound waves to create resonance.
I thought about doing this using something called DirectSound3D built into the windows DirectX API. Like a bird chirping a flying from point A->B. But I have so much on my plate right now like wireless controllers with my own custom program that I dropped it.
Neat idea though. Having 40->50 sounds playing QUIETLY in the background so they are barely noticed, controlled by a computer sounds like a neat project.
For example, stopping a train at a coal loader and the detection block lets the computer know and the coal dumping sounds begin. (Or hearing cars stop and go in a city at lights)
Or have a torpedo car back up into a blast furnace and have the block detection go off, thereby signalling that the sound of hot metal flowing can start (as well as activate the proper black light to light the pig iron)
Blast furnaces are noise beast when they open the top of the furnace to the atmosphere.
Like I said, it was too ambitious a project on top of everything else I have to do from finishing the basement to coding the wireless cabs.
I did find a small working clock electronic recording of westminster chimes though, and stuck it under my church. That way I know what time it is.
The former suggestion is actually doable. The easy part is moving the sound volumes. You do that by setting detectors around the track. As the loco passes a certain point, volume on the speaker nearest is increased while volume is decreased on the others at proportional rates based upon distance from the loco. In an earlier thread I suggested perhaps using a sound decoder with a speaker system rather than mounting it in the loco/train. That way you have matching decoders, one in the loco and one with the speaker system so that the sounds come through the stereo rather than the tiny train-based one. I’m stilling mulling that over, however.
Regardless, the problem is with replicating the doppler effect of the sound waves. Volume control is easy, as I posted above. However, as a train approaches (or any sound producing item) it APPEARS to increase in frequency, IE: the sound waves app
DirectSound3D API simulates doppler effect automatically. Problem is you have to assume the operators position relative to the object that is moving to realistically simulate it.
I think that’s going to work much better for ambient sounds than moving sounds. Setting up the audio wavefront with quad speakers will be much less localized than you would want it to be. (Stereo alone would only give you one dimension of position. You could “position” the sound left-to-right, but not front-to-back.)
Actually “locating” the moving locomotive on your layout is a difficult challenge. You’re going to need some sort of radio-frequency transmitter with a coded signal in each engine, and at least 3 receivers, plus some computing power. Like today’s sound decoders, you would need one transmitter for each engine.
Technology marches on, of course, but with today’s equipment I’d suspect you’ll get the best results with local speakers, both for a few ambient sounds and for engines, even given all their limitations.
You’d only need one receiver. We know the engine will be on the track so we need only locate the receiver in the center of the layout very high or very low. That will give us triangulation.
Computers are very fast, but even so, the computer can anticipate where the engine will be based upon location and speed of the engine.
Transmitters are cheap and can be programed when the decoder is programed–only 1 CV.
I’m not sure I want sound that is greater than what is produced now. I like the fact the sound is scaled down relative to the size of the trains. I don’t think I would want something blaring anywhere near prototypical volumes. I do model in HO so I’m not sure what you guys in N-scale have in the way of sound so maybe upgrading sound is an issue to be addressed. I think the sound I get from my factory equipped BLI locos is outstanding, both steam and diesel.
Ok, how about motion detectors to track the listener. The volume of the various sounds coming from each surround sound speaker could be changed so a certain scene’s sounds get closer as the listener does. This could also be used to control some of the reflective sound.
Some of this discussion is over my head, but I think I’m on the same page with some of you. I would love to see sound get to the point where, if for example, you as the engineer actuate your locomotive’s horn and you can instantly hear the reverb or “echo” effect bouncing off of buildings or mountains. Of course that’s not what would really happen, but it’s that effect that many of us would like to have.
If I read this right, this effect may be technologically possible in the near future by combining onboard locomotive sound with middle and low frequency response speakers located at strategic points on a layout. I think that this is what Soundtraxx is planning with their Surroundtraxx but I hope we won’t have to wait 5 years for this! My hair is starting to turn gray [(-D].
As a teen, I always enjoyed listening to this effect on the prototype as I watched approaching SCL and Amtrak trains in my town. For me now, it’s pleasant and memorable, especially with Amtrak’s SL4T horns on their SDP40fs. Seaboard Coast Line’s U36Bs had incredibly loud 4 cycle prime movers that could be heard 2 or 3 miles away in a city. These brutes at full throttle sounded like they could pull down a big building!
This is why I became so excited back a few years back when BLI and hit the scene and sound for HO became so much more popular.
This has been done by Soundtraxx, but I do not think it was ever released. It was called ‘SoundAround’, or something like that. They had it on display at shows several years ago, but the estimated price was steep(about $600). Each DCC engine needed a Digitrax ‘transponder’, and the layout had to be blocked into ‘sound areas’. The unit would poll the engines and get thier location on the layout/speed/etc. The sound would then be sent to the speaker in that zone. IIRC, there was a limit of about 10 engines running at one time. The system would ‘pass’ the sound from speaker to speaker so that it followed the train. This was to be marketed to N scale as getting a sound system in an engine was very hard(and still is). I see nothing on their web site now, and I suspect the idea was dropped.
It was a ‘black box’ (an Industry term for a featureless electronics package) that read ‘back emf’ to send sound to multiple fixed locations as the train moved.
MTH’s threat of patent infringement re: use of back EMF muddied the waters, BUT I suspect COST of multi-channel analog sound systems (over and above the ‘black box’) may have been the real reason it became stillborn.
Cheap Sub-Woofers are around $200 (‘good’ ones start @ $500), and current ‘Theater- Surround’ 4 OR 5 Systems start @ $600. 2 MRC Sound effect’ speakers and a sound-effects box sells for $85. Think of what 4 Computer speakers and a small sub-woofer could do?
Electronics can be minaturized but sound waves cannot. They are ruled by the laws of physics. A tiny Transistor Radio cannot reproduce a Symphony Orchestra, nor a steam locomotive by a 1" speaker.
A Stereo amplifier can move their sound image L to R. with 2 speakers using it’s ‘Balance’ control. An EMF fed electronic ‘balance conrol’ with 2 speakers will give us moving image - As soon as someone figures out how to make money with it.
Good 5.1 self powered surround speakers are easy to find on the cheap. Here are some EXCELLENT ones for $269. This system has 500 watts. Enough to shake your rails as your train comes down the line.
If you have an old computer, (500MHz will do, even a Pentium 100MHz) then surround sound can be had for $60. It would work well providing that the room is fairly rectangular/square.
I wonder if we have any programmers in here besides me? It would be a neat group project I could throw my coding skills into.
In the future, universal medical coverage will cover the costs of installing a chip in you, so that each model seems to sound exactly how you think it should. This will eliminate the problem of any model not having the perfect whistle or a ‘wrong’ sounding bell. Actual sound systems in models will of course be obsolete. The sound you hear on your chip will be interruptable by the government, so they can broadcast the latest food warnings, medical side effects warnings, global warming warnings, unsafe toy warnings, weather or civil defense warnings and weekly test tones, civil rights threats for various groups, and terrorist threat levels, directly to you in a manner the TV, cell phone, or model railroading cannot interfere with.
I have heard these. Two people here at work bought them and love them. They are loud, clean, with good solid quick punch. They are nothing short of an excellent buy. And yes it’s 500 Watts Total. Not 500WPC which is impossible off any household outlet.
You say that like it is something easy to do. This is what I’ve been talking about on the other threads about sound. A baffled-chambered-ported design (that is NOT air-tight) that is tuned to the frequency of the exhaust sound of that particular locomotive. The internal path of the air would have to be tuned to get the low freqency sound “wave” coming out the port to be exactly in-sync with the originating “wave” from the speaker cone. Note that this would require a different speaker for each type of locomotive. The “perfect” speaker for an EMD 1st generation would not be the same as one for a GE whale.
I stumbled across really good one for a 3/4" speaker tuned for the EMD 1st generation (as re-created by Soundtraxx), but it is still too large to fit even into dummy B unit. When I use that exact length in a double-back scenario it doesn’t work. The “wave” won’t go around the corners without changing their pattern too much and ruining the effect.
