i am new to this hobby. my father in law retired w. Virginia coalminer. like the virginian plan. are there other coal mining plans that are detailed to build like the virginian? is the virginian too much to tackle for newbie? thanks.
ed
ed
Happy New Year,
Most 4 x 8 plans are good starting points for “newbies” (and there are other options available other than a 4 x 8). The Viriginian is a nice plan and I would say go for it. No matter the plan, take your time and learn as you go.
I agree with Bill, above.
I’ll concur that my recollection of that layout is that it had an excellent design–something difficult to pull off in 4 x 8.
Ed
Google search Turtle Creek Central Track Plan, or use the MR database. It consists of two MR project layouts, so there is a 2x6 appendage for the actual mine.
Its on one grade and has less track than the Virginian and should be easier to build. The loop could be modified to include a marshalling yard like in the Virginian, which makes operations more interesting.
I always liked the Virginian. There are sooooo many track plans out there. I thought this plan was cool too! It’s the Feb., 2011 MRR.
http://mrr.trains.com/how-to/track-plan-database/2010/12/rosston-joelberg-holly-rr–csx-branch-line
Mike.
The Virginian is MRR’s most popular starter track plan that I know of. There’s even a couple threads dedicated to it.
-Don
thanks. its a cool looking layout. where would i find the thread dedicated to it?
ed
The Virginian is perhaps the most detailed, and well thought out project layout MR has done, IMO. As for building it as a beginner, perhaps start with one of the extensions instead of the main layout. The Turtle Creek extension, which was used as Kelly on the Virginian is pretty simple, and would be a good starting point. It’s also smaller, so size isn’t as intimidating.
If you’re not on it already, I’d recommend MR Video Plus. You can watch all the videos about the Virginian, and the Thin Branch project too.
I helped work on the Virginian layout with a club in WV - it is difficult and too narrow. Widen it to about 5 1/2 feet and take out the two curved peko switches and place the crossover where the weighin platform is located and it would work much better.
That is my take on the plan too. Its probably not for the beginner since I think it requires a lot of precision in order for the marshalling yard and the scenic divider to fit on the 4x8 realistically.
Its probably why the OP asked for alternatives that are simpler.
If you don’t have the original series of articles on building it, get the special issue Build a Small Model Railroad listed above under special issues where they are reprinted.
While this might be considerd an advanced beginner project, I think you could build this as a first layout. Because it is a very packed layout, I would follow the construction articles in building it. Use exactly what commercial trackage they used, even small deviations can make it difficult or impossible to fit it all in. Buildings can be a little different, but watch the footprint as there isn’t much room for them.
Good luck
Paul
Since they have the book, and/or the back issues and/or MRVP to refer to for construction, the Virginian, while not the easiest layout, is VERY well documented with fairly step by step instructions. I’d say it’s easier for a beginner to build than a slightly simpler plan that is lacking all that documentation.
I actually built the Virginian, though I repurposed it to create my version of the Georgia Northeastern. The trickiest thing was getting the track plan right. I ended up laying it all out in AnyRail, and I never did get the tracks to line up 100% where the two curved turnouts create a cross over by the rail yard. Of course, this was my first attempt after having taken a 40 year hiatus. If you are patient it will all work out. You would be better served to go with a slightly larger table top, 4 x 8 is very tight and was a big part of my struggle as well.
Overall I was very pleased with the results. I would recommend reviewing the articles in the series, as well as watch the videos, especially the ones on laying the track.
I used the Virginian project techniques for my different cookie cutter layout. The articles were early 2012 IIRC. And the videos are good also. I think those can be viewed without Video Plus subscription.
The benchwork approach is nice. And the stages of track laying, painting, sceney, etc. are helpful.
Yep, the articles started in the Jan., 2012 issue, with an overview of the project, and the operations, and the bench work and nitty gritty starts with the Feb. issue, and continues on each month.
Videos started in Nov., 2011. On the black bar at the top of the page, hoover over videos, click on Project layouts, in the column on the left.
I’m not sure, but if you are a magazine subscriber, you should be able to watch them.
Mike.
