PRR and NYC were the main users, there might have been others but those are the two that usually come to mind. It was pretty common in Britain, and I think started there.
None in our part of the world however. In the US it was pretty much limited to the eastern states.
I’d like to know just where the PRR’s track pans were located. I lived around the PRR for all my life (well, until it wasn’t the PRR any longer), and although I heard about track pans, I never saw one anywhere. Is there a reference somewhere, that documents where the track pans were installed?
There were also track pans on the Royal Blue B&O route between Jersey City and Washington. At least one may have been on the Reading or CNJ for use primarily by B&O locomotives that ran through with B&O engine crews JC-DC. The Reading locomotive may also have used them on their runs between JC and Philadlephia, but I doubt the CNJ engines did since their runs were relatively short, Except for the Queen of th eValley route to Harrisburg.
Did not the IC also use track pans on their main line?
Don’t forget those track pans were good for depositing the occasional “surprise package” in the tender, you know, such things as frogs, snakes, or the odd snapping turtle now and then.
There’s a story, probably apocryphal, that if there was a medical school nearby the srudents would drop things like arms and legs from cadavers in the track pans, but I’m not so sure I believe that one!
The through B&O passenger trains between Washington and Jersey City scooped four times.
First at Swan Creek which was near Aberdeen, MD, then at Stanton, DE, and then when on the Reading at Roeloffs, PA and finally on the CNJ at Green Brook, NJ.
The track pan stations also had pen stocks for freight engines to take water since they were not equipped with scoops
The magazine of the Baltimore and Ohio Histroical Society has an artcle on the operation with lots of photos. It is in Vol 33 Number 4 Fourth Quarter 2011 titled “Track Pans and the B&O and the Royal Blue Line”" and is still available for now, on line, from their Company Store.
The four track pans on the “Royal Blue Route” came later, with all three of the participating railroads (B&O, RDG, CNJ) installing them in the early 1890s.
The last track pan on the B&O was at Swan Creek, MD and it closed in January, 1953. The one at Stanton DE closed in November, 1949 as the use of steam power for passenger trains past that point was reduced and tender capacity was increased…
Not sure of the closing dates of the of the track pans on the RDG and CNJ, but I assume it was 1953.
The B&O pans were not the same “high speed pans” as on the PRR and NYC. The B&O had a speed restriction of 50-mph. Most locomotives scooped at between 40-45 mph. Below 30-mph, there was not enough force for a good water pick up. The B&O pans and scoops were smaller and the run was shorter than on the PRR and NYC…
Each of the 1200-foot long track pans on the B&O, made of 3/16” sheet steel in 30-foot sections riveted together, was 19” wide and 7 ¾” deep and held about 8,000 gallons of water. Small by industry standards, they were specially designed at the time when the through route was at first assigned the B&O’s relatively light 4-4-0 type locomotives, which were changed at Philadelphia. As the engine size increased and operating procedures changed over the years, the pans would prove to be only marginally adequate.
The pans on the PRR and NYC were wider and longer…
Sorry about the Normal 0 MicrosoftInternetExplorer4 in the message. I copied the text from my notes and I guess for some reason this post picked that up. I have no idea what it means.
I’m aware of 2 locations of track pans in NW Indiana. The NYC had pans about a mile W of Ind 51 in Lake Station (East Gary) Indiana. Another was on the B&O in Portage (McCool) Indiana adjaciot to Robbins Pond.
I never knew that there were track pans on the B&O at McCool, Ind. My recollection is that the only two pans on the B&O were on the Baltimore Division at Swan Creek, MD and Stanton, DE.and that only the passenger engines so assigned, had scoops.
I just found a listing for McCool, Ind and it only lists a “water station” which is not necessary a track pan.
Furthermore, what engines would have had scoops attached to scoop at McCool?
Probably everyone’s agreed B&O didn’t have any track pans west of Pittsburgh in, say, 1940. He must be talking about a century or two before that.
PRR always listed track pan locations in the empl TT, didn’t they? NY Central too? But can’t promise that no track pans in the B&O timetable means none existed.
As far as the two B&O tracks pans that I know of for sure (Swan Creek and Stanton), they were not listed in the B&O ETT as such, but were referenced to in regard to speed restrictions when taking water and procedures during freezing weather.
The only locomotives that were scoop-equipped were those used in passenger service between Washington, Philadelphia and Jersey City. After 1927, this was mainly the (20) class P-7 Pacifics, 5300-5319 and a class P-9a Pacific, 5320.
At the two water stations that had track pans, there were also pen stocks for the other locomotives, not scoop-equipped (freights, work trains, etc). But one freight locomotive, 4485, did receive a scoop as an experiment… This experiment gave way to the use of auxiliary tenders on some of the freight locomotives assigned between Washington (Potomac Yard) and Philadelphia.
The reason for the track pans was to reduce the running time of passenger trains between Washington and Jersey City in an attempted to compete with the PRR’s (direct) New York service. B&O buses using a ferry across the Hudson River, provided the service for the B&O passengers between Jersey City and New York…
The water station at Stanton, DE was closed on November 19, 1949.
The pumping station and track pans at Swan Creek were discontinued on January 24, 1953. Pen stocks using “city water” remained there for the rest of the year until steam was gone from that part of the B&O in November, 1953.
Stix, your right, here in brittain we called them troughs, prob after the countless troughs all around for the horses. They were approx at 60 mile intervals on main lines, all exept the south of England where journeys were much shorter.and troughs were not fitted, average tender water capacity for an express engine was approx 6000 gallons (imp) , Now all troughs removed in the late 60’s after the end of steam in uk in 1968, Plenty of main line steam excursions, but many delays due to water supplies, (usually from a road tanker at a pre-arranged location. Norman from Chorley uk.
Track pans in the U.S. were also referred to as “water troughs”, perhaps since the technique was learned from the railroads in Great Britain.
The two track pans on the B&O where slightly shorter (1200-feet), than those on other U.S. railroads, but were adequate when installed in 1893 when locomotives were smaller and tender capacities were less.The average length of pans on the other U.S. railroads was 2,000-feet, thus more water could be scooped each time.
As the locomotive size grew, the B&O pans were only marginally efficient, with each scoop yielding about 5,000 gallons and simply “topping off” the existing water supply… The more modern locomotives,with an average consist, consumed about 6,000-gallons of water and 3.5-tons of coal per hour. Coal was never an issue on the Washington-Jersey City route but water was. As a result, the four track pan locations were spotted about 30-35 miles apart. The other two pans were located at Roeloffs, Pennsylvania (Reading Railroad) and Green Brook, New Jersey (Central of New Jersey Railroad), which the B&O used to get to Jersey City. The B&O locomotives on passenger runs worked through.
There was a move to extend the length of the pans to 1800-feet but instead, the tender capacity on some locomotives was increased from 11,000-gallons to 20,000-gallons and that sufficed. By that time diesels had made their appearance on the B&O and the “writing was on the wall.”.
