Transition era B&O boxcars?
Hello, I am planning to buy one or two transition era B&O boxcars for my small layout. I would appreciate any comments on quality and accuracy of these candidates:
  • Accurail RTR #93511 M-55A 40’ boxcar
  • Accurail kit #4306 wooden 40’ boxcar
  • Athearn RTR 70871 M-59 double door boxcar (due July '08)
  • … or any other worthy model I do not know about…
My layout is small L shaped dogbone - not much space for cars on it, so I would rather have one good and correct car, than 2 or 3 of lesser quality and accuracy.
Thanks!
Nothing says “B&O” like a wagontop… I’m sure there are models of these available in HO. This is from a Fine N Scale resin kit.
Lee
Appearance wise, both Athearn and Accurail are very good for low to midrange kits. A lot of the detail is molded on, such as the ladders but that is what you should expect in that price range.
With either kit, make sure the metal weight is perfectly flat before you install it. Often these have a slight bend to them and the plastic floor and chassis will conform to the bend making it difficult to get proper coupler height. The metal weight is soft and easy to straight out. Just place it on a flat surface and either gently pound it with a hammer or stand on it.
It has been a while since I bought an Athearn shake-the-box kit but I think they come with plastic wheels. I have built quite a few Accurail recently and I know they come with plastic wheels. I would consider replacing them with quality metal wheels. I use P2Ks but there are other good ones. Also, a great investment is a Truck Tuner, available from Micro-Mark. This is a simple device that you slip inside the truck in place of the axle and turn it to grind out some of the plastic. This makes the wheels turn more freely. It costs under $10 and is an excellent investment.
Except that the B&O wagontops were really just a bit player in the grand scheme of things, when it comes to the B&O boxcar roster of the 1950s. Yes, there were something like 4400 of them built, but when compared to the over 35,000 boxcars the B&O owned at one time or another between 1950-1959, it’s a drop in the bucket.
I just waded through the 1950 ORER listing for the B&O to get some feel for what boxcars are REALLY correct to model a “typical” B&O boxcar (something I needed to do anyway for my own roster, since I’ll need six or eight of their boxcars). The B&O owned 102,190 revenue freight cars, or the third largest car fleet in North America (after only the PRR and NYC). They owned a total of 28,266 boxcars, or the eighth largest fleet in N.A. In GENERAL, their boxcars can be broken down into the following types:
  • 38’ double sheathed, classes M-8 & M-13: 12 cars (0.04% of roster)
  • 40’ double sheathed, class M-15: 2426 cars (8.6% of roster)
  • 40’ single sheathed, class M-24 (USRA): 447 cars (1.6% of roster)
  • 40’ steel, classes M-26 & M-27 (1923 ARA; X29-type): 15,665 cars (55.4% of roster)
  • 40’ steel, classes M-15 & M-53 (wagontops): 4376 cars (15.5% of roster)
  • 40’ steel, class M-55 (1937 AAR): 2985 cars (10.6% of roster)
  • 40’ steel, class M-59 (1944 AAR): 897 cars (3.2% of roster)
  • 50’ steel, classes M-57 & M-58: 1450 cars (5.1% of roster)
So the “typical” B&O boxcar of the 1930-1955 period is quite obviously the 1923 ARA box (X29 to most folks), NOT the wagontops, which are outnumbered almost four to one by the ARA cars.
By the mid-1950s, the B&O would start buying huge numbers of 1944 AAR type boxcars, until they were the do
You are correct about the proportional representation, but, the Wagontops were home-built at Mt. Clare, and were unique to the B&O. PRR and probably others had their own variations, but not the same.
A 50’s era B&O layout without at least a representative smattering of wagontops (I only have one on my roster… and it represents a 30-year old survivor…) lacks the vital seasoning that provides that true B&O flavor!
Lee
I like to check the fallenflags website to verify paint schemes and numbers. I’ve found many kits have the incorrect numbers or paint so I don’t buy them. Red Caboose and Branchline kits seem more accurate to me, not to mention nice models to build if you don’t mind taking your time and doing a careful job. Since you’ve got a small layout, devote more time to the details. Also, look into getting good books of the railroads you’re modeling, even if it is not your primary railroad. These provide great examples of what trains looked like in your era (ratio of home road vs foreign, type (50’ vs 40’ vs 60’) and various paint schemes of the same road) and they are great references to keep on hand.
I’ve found the locale determines the kind of cars in a train, C&O had all hopper car trains in the east, but brand new Hi-Cubes in Michigan for the auto parts industry (as a rough example).
I would definetely replace plastic wheels AND couplers for durability and performance (I’ve seen 3 broken/worn out plastic couplers and never a broken KD in my 100 car collection, now all get KD’s before they hit the layout).
I know about using the tool to resurface the truck journals, but what about the axle points? Branchline axles are terrible sometimes! Lots of flash and even deformed axle points. I would put them in a lathe and reform the ends but I don’t have one and I don’t want to make the axles shorter. Any solutions short of buying new wheelsets?
Vow, great data! Thanks, everybody, especially Ray! [tup]
I am thinking about Funaro M-15k car, but there are still many questions about doing resin cars… which trucks, which glue, how to paint, decal, will it look good enough… [%-)] You know, Floquil paints and decal finish are not so easy to find here in Central Europe… [swg]
For now I completed five or six Accurail/Bowser kits, and two Branchline Blueprint PRR boxcars, so resin kits are definitely in future plans. For now, I will try to find some easier kit or RTR B&O boxcar as a start.
Trucks: Accurail “Bettendorf” (really AAR common) trucks will do fine.
Glue: the cheapest, thinnest super glue works the best.
How to paint: clean with dish soap or isopropyl alcohol, primer, and paint with a “darkish oxide red”. Use the paint chip from Polly Scale’s “Special Oxide Red” and if you can’t get Polly Scale, find a Humbrol color that’s close.
Decal finish: glosscoat over the paint, add decals using Solvaset, dullcoat once dry and weather. I have no idea what a decent solvaset alternative is over the pond, but I’m sure there’s something close.
Look good: that’s entirely up to you!
If you want an easy car, try Branchline’s Yardmaster 1937 AAR box. Unfortunately, they don’t have one predecorated for the B&O…
B&Os M-26 class were an unashamed copy of Pennsy’s X-29 class. Painting one in B&Os bright red oxide and decaling it with any of the B&Os heralds used over the years would look right at home, and would not be a tough project at all. As was previously mentioned, it was also by far the most common boxcar on the B&O by a huge margin. Funaro and Camerlengo have a nice resin wagontop kit, but it sure isnt an easy build. Both would scream “B&O” if you wanted to take a step away from RtR stuff.
B&Os red oxide was quite a bit brighter “red” than Pennsy’s, which always looks sort of orange-ish to me. Maybe Red Caboose will give us a model of an M-26 already painted and marked for B&O sometime. Luckily the B&O, strapped for cash by the mid 50s, would run cars for years and even decades without repaints, so inexact coulours, coupled with some weathering, could produce models that are both prototypical and striking. By this time, C&O had began to donate used equipment to the B&O as well, broadening the rolling stock possibilities.
And regardless of how many they had, lets face it. Wagontops are way classier than an ol’ M-26 anyday[:)]
Pick up a copy of B & O Color Guide (Morning Sun books). Lots of great pictures for comparison.
Does Funaro resin kits allready have holes for mounting trucks?
Most have a “dimple” in the center of the bolster as a starting point for a hole you drill yourself. The resin is EASY to drill, and doesn’t need to be tapped to add a screw, so F&C has left it up to you to figure out how big the hole needs to be.
The Funaro kit I got (which has summarily ben destroyed by yours truly) had mounting dimples, and I believe that it even came with some 2-56 screws in the packaging with the truck assemblies, which look a lot like the tichy assemblies that come in their (Tichy’s) kits. I believe that the Funaro kits do make use of a lot of Tichy detail parts, or it may just be an addition specific to the model that I bought…
Next question… [;)]
What year did B&O start to change freight car scheme from above (my favourite) to below?
Also, when did they change nice looking blue/grey/black to plain dark blue on diesels?
Thanx!
The solid blue diesels started appearing around 1963 when the C&O bought the B&O. I believe the GP-30’s that were delivered that year were the first to wear the simplified scheme.
Lee
There was also another variation of the origional paint on the F units. This was the Enchantment blue with the black band w/ Baltimore and Ohio. This scheme appeared on F7s delivered in '59. Still a handsome paint compared to the all Royal blue w/ C&O yellow B&O and sill stripe described by Lee for 1963. The short lived “Sunburst” w/ dashed yellow stripe appeared in '63. This Sunburst was also found on delivered GP30s.
For more in depth info on Fs, MR did an extensive and informative article on B&O Fs in the Aug '95 Model Railroader.
Pending the time frame you model, the complex B&O no. system was changed in the roster wide renumbering system in 1957.
Yes they do have a location dimple for the truck mounting screw. You do have to drill the hole as you do for all of the grabs and other details. I built one of these cars about a year ago and found it to be fairly easy for a resin kit. Definatly not as easy as an Athearn kit but, with some practice they are very doable. I found the hardest problem to be the poor instructions that come with the kit. some steps leave a bit to imagination with some of their stuff. The boxcar was fairly straight forward though and if I remember right, it was a one piece casting for the body so getting everything square is not a problem. The glue I used was a gel type superglue made by locktite and purchased at my local hobby shop (Home Depot).
The trucks I used were a garden variety that I had laying around here (possibly Proto 2000) All of the brake components are Tichy brand and work well for the model. A sharp exacto knife, a couple of grits of sandpaper on a flat surface and patience is all you realy need to make a good model from one of these kits.
Dan Pikulski
www.DansResinCasting.com
Great looking car, Dan! [tup]
You will need to check the weight. I have found most Athern, Accurail, Bowser and Branchline kits are 1/2 to 1 oz light. Weigh the parts of the car before it is assembled so you can put in the additional weight as you are building it.
Adding weight is more difficult for assembled cars. Try to find an out of sight location to drill a hole and add BBs that have been coated in matt meduim or silicone caulk. Many box cars have the weight in the bottom that blocks a hole there. If you can remove the roofwalk without damaging it, that is a possible location for a hole. If the weight is acessible and removable, replace the steel weight with lead; that usually makes up the difference. Check WallMart sporting goods section for BBs.
Also, if the model has plastic wheels, replace them with metal ones. Fortunately, many models are coming with metal wheels in recent years.
Hi gang, next question… :slight_smile:
I presume this Athearn RTR is also of M59 family?
Did Athearn made accurate scheme for this “fast freight” B&O boxcar?
Judging by the lettering, I would say it can pass for mid-50’s period.
